Dynamic Green Products Inc.
Author Topic: 576 husky  (Read 1137 times)
Offline tj240
  • partner in Williams timber harvesting
576 husky
« on: August 14, 2014, 05:21:58 PM »
has anybody had problems with these? very cold blooded no matter how it is adjusted[carb] you still have to feather the throttle until its warm.
husky put holes in the clutch drum to cool i quess clutch fills will saw dust and binds up, why fix something that isnt broken?372 great saw oh cant build that anymore. any help with problem appreciated, just venting why change something that works
Moderator edited for language.
work with my father[jwilly] and my son. we have a 240 tj 160 barko[old] works great three generations working together
Offline Ed_K
Re: 576 husky
« Reply #1 on: August 14, 2014, 05:53:14 PM »
 I haven't had any problems with mine, i have learned that it starts easier if you put it on high idle each time you start it.The 357,359,562,576 385s all start better that way. I have to clean the clutch on the 562 every day too.
Ed K
Offline tj240
Re: 576 husky
« Reply #2 on: August 14, 2014, 08:43:11 PM »
thanks always start on high idle but if its not warmed up you have to feather the throttle till it is then it is semi ok. love the 372 tho really love the 460 series sthil
Offline Jhenderson
Re: 576 husky
« Reply #3 on: August 14, 2014, 08:57:08 PM »
I fellow I know told me if he had to make a living with a 575-576 he'd rather pump gas.
Offline tj240
Re: 576 husky
« Reply #4 on: August 14, 2014, 09:17:26 PM »
i see why ,its just a loner thank god, got the 372 back now the oaks will fall, still waiting for the other 372 to get fixed the 576 just back up now
Offline hamish
Re: 576 husky
« Reply #5 on: August 15, 2014, 08:44:35 PM »
You should try a 576AT, then you wouldn't want the 372.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Offline SawTroll
Re: 576 husky
« Reply #6 on: August 17, 2014, 02:52:28 PM »
I haven't had any problems with mine, i have learned that it starts easier if you put it on high idle each time you start it.......
That actually is what most operator manuals say you should, but with many saws it isn't necessary when the saw is really warm.
Information collector.
Offline superwd6
Re: 576 husky
« Reply #7 on: August 24, 2014, 08:34:11 AM »
Have had my 576XPGAT since 2010 and I had the same issue with the clutch. Installed aftermarket clutch for 372xp  (no holes)and last year  put the W clutch cover on for a huge improvment in clearing chips while splitting. My last 288xp sits under the steps now  ;D
Husky Prestique 61 (1980) Vs Husky 562XP
Started by Mikeinkaty on Chainsaws
Last post June 13, 2016, 06:09:49 AM
by SawTroll
husky 65
Started by ed in idaho on Chainsaws
Last post September 10, 2009, 06:13:47 PM
by Rocky_J
Husky 55 or 359
Started by Sprucegum on Chainsaws
Last post April 03, 2005, 01:28:50 PM
by Boozilla
new husky
Started by ktowne030311 on Chainsaws
Last post February 27, 2015, 08:45:55 PM
by HolmenTree
