The solenoid in the fuse box is for the hydraulics only. It would have no bearing on the up down. ...
Needs to be FULL, just some won't get it. WM says use ATF, I use 80W90 gear oil, not recommended in colder climates...
I replaced the lube with synthetic.
Started by Jwswan on Sawmills and Milling
Started by maple flats on For Sale
Started by geraldhale on Sawmills and Milling
Started by chet on Sawmills and Milling
