Author Topic: Slow growth or Fast growth?  (Read 662 times)
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« on: September 01, 2014, 08:05:05 PM »
 say_what
Which ever…..it'll make good lumber.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Slow growth or Fast growth?
« Reply #1 on: September 01, 2014, 08:07:25 PM »
No tension in that log?
« Reply #2 on: September 01, 2014, 08:09:01 PM »
Not yet.  :D :D :D Laid it on the mill……started to saw it……changed my mine because of the heat and went home. Forestry work Tuesday……will saw it Wed.
Online beenthere
« Reply #3 on: September 01, 2014, 08:34:45 PM »
Looks to have some compression wood in there, but you will know for sure after it is sawn and dried.
A real thin slice of the end grain (1/8" thick) laid over a light will show any compression wood easily. Light won't pass through.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: September 01, 2014, 08:50:45 PM »
That is very common with SYP and it will saw just fine.  As you are set up the flitch lumber might tend to crook, but the saw through lumber might bow, but it will not crook.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: September 01, 2014, 09:44:22 PM »
It is a bit off center.  Kinda like you  :D
« Reply #6 on: September 01, 2014, 10:01:46 PM »
It is a bit off center.  Kinda like you  :D.
 smiley_whacko
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: September 01, 2014, 10:21:25 PM »
Yes, it is off center, and I would have positioned the "egg" a bit more parallel to the sawmill bed, but that growth pattern is normal for a tree that was crowded on one side, etc.
Looks like money to me. $$$
Notice that on all three logs the close rings are on the inside of the sweep which was turned to the loader side for the first face opening.  I have found that setting up that way saves much misery and produces the best lumber.
Is slow growth or fast growth better?
Started by Lnewman on Ask The Forester
Last post November 28, 2014, 08:46:44 PM
by Ron Wenrich
grin
A way to slow my son's growth down
Started by Part_Timer on Wanted
Last post August 22, 2006, 10:19:34 PM
by katie-did
How many slow- or no-growth trees are there?
Started by Aranck on Forestry and Logging
Last post April 03, 2015, 05:24:31 PM
by SwampDonkey
Some fast growth
Started by customsawyer on Sawmills and Milling
Last post September 01, 2015, 12:43:57 AM
by stavebuyer
