Dynamic Green Products Inc.
Author Topic: How to encourage blue stain in pine.  (Read 3988 times)
Offline Joe Hillmann
« on: September 26, 2014, 11:50:57 AM »
I have a bit of an unusual problem.  I make rustic crates with the lumber I cut on my mill.  By rustic I mean the rougher and worse looking the lumber the better.  The pine that I cut in the summer naturally started growing blue stain.  Now that the weather is cooling it isn't growing anymore and some of my repeat customers are complaining that the crates I am sending them are not rustic enough.  So is there any way to get blue stain to grow in the fall and winter?
I have thought of soaking the piles with water than completely covering them with black plastic to trap the moisture and collect the heat from the sun. Any other suggestions?
Offline mmartone
  • I'm new! but I'm old.
Re: How to encourage blue stain in pine.
« Reply #1 on: September 26, 2014, 12:09:26 PM »
Can we get some pictures?
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #2 on: September 26, 2014, 12:21:00 PM »
Dead stack it :D
A&P saw Mill LLC.
License NH softwood grader.
Offline red oaks lumber
« Reply #3 on: September 26, 2014, 12:56:21 PM »
wet each layer and dead stack it, that will work until the logs are frozen.
Offline LaneC
  • Traveling Man
« Reply #4 on: September 26, 2014, 01:46:53 PM »
You may also try going to the "wood processing and drying" part of the forum and ask "Genewergart  wood doc" He is very knowledgeable in the stained, mold and fungus fields.
Man makes plans and God smiles
« Reply #5 on: September 26, 2014, 01:55:15 PM »
Pictures of the crates or the lumber?
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
« Reply #6 on: September 26, 2014, 02:19:09 PM »
This is interesting. Blue stain occurs naturally in Pines out here that have been standing dead for awhile - such as after a fire. Except for custom work, it is generally undesirable, and therefore there is a huge push to get the dead/dying out of the woods after the fires. I didn't know you could "encourage" it after cutting live wood.
« Reply #7 on: September 26, 2014, 02:30:43 PM »
I just looked it up.  It appears as if blue stain has different meanings.  In the Rockies and west it is a fungus that is spread by beatles that prevents the tree from defending itself from the beatles and eventually kills the tree, it ends up with the sapwood turning blue.
Blue stain can also be any type of fungus that grows in the wood after the tree is cut and before the lumber is dry,  it isn't the same as mold or mildew.  Mold or mildew grows on the outside of the lumber, the stain grows inside of it.  It can be caused by many different types of fungus.
The second one is the one I am trying to grow.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #8 on: September 26, 2014, 03:11:44 PM »
You are only going to have blue stain in the sap wood. Do you have a warm garage where you could dead stack your outer boards and keep them moist? Right after the blue stain comes the white mold. That's one step too far. :D
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #9 on: September 26, 2014, 03:42:58 PM »
Then comes those little grubby things that like to decorate your wood as they feed.
Still rustic ;D
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #10 on: September 26, 2014, 06:58:30 PM »
     If you lived down here, figuring out how to get pine to blue stain would be the least of your problems. :D
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Offline customsawyer
    • The Custom Sawyer
« Reply #11 on: September 26, 2014, 07:09:35 PM »
This is like asking how to herd cats. :D No one has ever done this before but we are all ears on what you learn.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline bandmiller2
« Reply #12 on: September 26, 2014, 07:39:41 PM »
You need heat and humidity for blue stain. The surest way is to cut as much pine as you think you will sell in the hot humid summer months. Before really cold weather you could try dead stacking and cover with black plastic. Frank C.
Offline Bandmill Bandit
« Reply #13 on: September 26, 2014, 07:57:23 PM »
Without Pine Beatle Pee you are wasting your time.
I have been told by a provincial government foresty guy that there really is no other way to get it. It contains a bacteria/fungus that when exposed to air and moister and warmth it will start to grow.
I would NOT however Recommend growing Pine Beatles.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #14 on: September 26, 2014, 08:17:54 PM »
The black plastic should work.  There is moisture in the wood and the black plastic will trap the heat that you need.  Not sure if it will work after freezing weather, though, as the fungus that causes the stain may not be active.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline WoodenHead
« Reply #15 on: September 26, 2014, 08:42:50 PM »
I still have about 20,000 bdft of pine to cut.  Since it has been sitting around through the summer, I'll be seeing lots of blue stain (caused by heat and humidity around here).  I'd be happy to send you some.   ;D
Offline justallan1
  • living and learning
« Reply #16 on: September 26, 2014, 09:04:03 PM »
How about contacting other local sawyers and either working a trade for you "undesirable" perfectly good wood or possibly just buy their logs with blue stain.
I've known guys that did the rustic look on things for people and understand what they are wanting. Another great trick they used was taking a chain with a bunch of bolts run through it and beating the heck out of the boards before building or burning them a bit then cleaning it up halfway and building.
Allan
    • A&P Saw mill LLC
« Reply #17 on: September 26, 2014, 10:28:10 PM »
Why would you have all that Pine lay all summer? Did buy it or just cut it off your land?
A&P saw Mill LLC.
Offline WoodenHead
« Reply #18 on: September 27, 2014, 05:41:05 AM »
I buy pine from loggers who only supply it during the months between November and February.  Since I sell lumber I have to guess how much I might need.  At the time it looked like milling was going to be my primary source of income, so I bought a good bunch of it.  Then I got busy doing other things.  So, I wasn't able to saw as much as I had hoped before blue stain set in.   :-\
Offline slider
  • sawyer,trucker,tree service
« Reply #19 on: September 27, 2014, 07:16:29 AM »
Jo I'm thinking a woman I know stained some pine by using vinegar and steel wool.It gave it a rustic look.
al glenn
blue stain on pine
Started by gtr on Ask The Forester
Last post April 15, 2006, 08:37:20 PM
by Pullinchips
blue stain in pine - make it stop!
Started by Engineer on Drying and Processing
Last post August 22, 2004, 06:22:56 AM
by Don_Lewis
Anyone purposely blue stain pine logs?
Started by oakiemac on Sawmills and Milling
Last post January 22, 2020, 01:34:04 PM
by terrifictimbersllc
Pine timbers, blue stain, resawing
Started by ethanbrush on Sawmills and Milling
Last post May 02, 2020, 08:44:42 PM
by ethanbrush
