Author Topic: Updating a old garden shed with cottonwood siding  (Read 2171 times)
Offline 21incher
« on: October 06, 2014, 06:52:59 PM »
I have a old garden shed that was pretty ugly and needed a new roof so I decided to give it a facelift. I moved it over 300 miles and wanted to save it.
I ripped off the old roof and framing and replaced it with a new look
Made the trim from some cottonwood that I had cut last spring and replaced the double door with a smaller opening.
I had cut 1/2" x 4 1/2 cottonwood for siding, but it curved so bad drying that I wound up cutting it into shorter pieces and could only get 4" wide pieces. I made a taper jig for my planer and planed it all with a 3/8" to 1/8" taper.
installed it with 3 1/2" exposed. Stained all sides before installing and used galvanized narrow crown staples to attach it stapling just above the top of each strip.
Made a door out of Ash and bead board exterior plywood. Added some hardware and the front is finished.
3 more sides to go. I placed a wall in the center and the front half will be garden shed and the rear now has a door and will be insulated and become a chicken coop. The shelter next to it will be turned into a greenhouse next spring. One thing I found out is thin cottonwood curves a lot when drying and I have to cut more to make up for waste.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline WmFritz
Re: Updating a old garden shed with cottonwood siding
« Reply #1 on: October 06, 2014, 07:19:26 PM »
That looks great! I like the look of the new roof.
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Online GAB
« Reply #2 on: October 06, 2014, 07:32:59 PM »
21incher:
You wrote: "I made a taper jig for my planer and planed it all with a 3/8" to 1/8" taper."
Would you per chance have some pictures of this tapered jig and also pictures of it in use?
Gerald
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: October 06, 2014, 08:44:15 PM »
That is a Snow Load Shed  :D
Offline m wood
  • How did I get to be a senior member :)
« Reply #4 on: October 07, 2014, 05:42:28 AM »
yup. there may be snow in your yard real soon 21incher...BUT NOT ON THAT ROOF :D
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Offline 21incher
« Reply #5 on: October 07, 2014, 07:56:11 AM »
GAB it was just a piece of 1 x4 that I hot glued a 1/4" strip to one side and ran through the planer to give me a tapered base, then removed the strip and stapled/glued a guide on the low side and screwed it to the bed. The only issue I ran into is I had to cleanout the input guard to my dust collector quite often because of the size and fluffiness  of the chips from removing 1/4" on the thin side. Right now I have my entire shop and dust collector lines torn apart trying to figure out how to fit a new bigger  jointer in it, but the middle of next week I be back up and run another batch with some pictures.
Bring on the lake effect, I am ready. ;D
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« Reply #6 on: October 07, 2014, 10:40:02 AM »
Cool. ;D
Offline m wood
« Reply #7 on: October 07, 2014, 04:13:24 PM »
 fudd-smiley :snowman:  some are expecting another doozy.  I think am hoping for something average :D.  Anyways, your shed proves that you are ready.  Woohoo!
mark
I am Mark
Norwood mark IV
4' peavy
6' peavy
stihl 034
check out FB
Offline VT_Forestry
« Reply #8 on: October 08, 2014, 06:46:22 AM »
Looks great, if I was a chicken I'd be mighty proud to call that home  :)
Forester - Newport News Waterworks
Offline 21incher
« Reply #9 on: October 16, 2014, 03:05:50 PM »
21incher:
Gerald
Today I got my shop back together and ran the rest of the siding. Took some pics  for you.
First I jointed all the boards, and then ripped them to the proper width. Next I planed the backside to make them all the same thickness which is 1/16" thicker then the finished siding.
Then I screwed my jig to the planer bed. It is just a tapered board with a guide on it.
The siding goes in a rectangle.
And exits tapered.
After about 5 minutes if planning the siding my dust collector stopped sucking. It turns out the chips are so light and fluffy and don't compress like normal chips that my cyclone can in front of the dust collector was full.
And even though my dust collector bag was still half empty, my canister filter was stuffed full of the fluffy chips. I have never had this happen before and it happened so quickly with the cottonwood which blows around in the collector and up into the cartridge like leaves.
Cleaned everything out and finished the siding. If I was going to paint it I would just mount the jig in my thickness sander and do a light pass with some fine sandpaper. :)
Online GAB
« Reply #10 on: October 16, 2014, 04:08:16 PM »
Thanks a lot for the education.
Pictures go a long ways.
Gerald
Using Cottonwood For Board and Batten Siding
Started by calb on Sawmills and Milling
Last post January 01, 2017, 03:41:31 PM
by AlaskaLes
Cottonwood for live edge siding and timber
Started by stickframer on Timber Framing/Log construction
Last post January 28, 2016, 02:58:24 PM
by jimdad07
Garden Shed
Started by Firebass on Sawmills and Milling
Last post January 14, 2008, 06:41:15 PM
by Radar67
using green cottonwood as lumber for drying shed
Started by ManjiSann on General Board
Last post November 06, 2019, 10:55:49 AM
by doc henderson
