Dynamic Green Products Inc.
Author Topic: Sawmill shed  (Read 7838 times)
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Sawmill shed
« Reply #20 on: October 13, 2014, 07:31:10 AM »
Just wanted to let you know that there are two boards on the left side that are trying to get away  :D.
Offline jrose1970
  • Feller = One who fells trees.
Re: Sawmill shed
« Reply #21 on: October 13, 2014, 08:30:07 AM »
Thanks for the ideas. My favorite tip in all of this is the use of a beam to span 30'. I would like to span 24' and could not figure out how to do it. I must say that I'm a little jealous of the sheds. (Just kidding)
HFE-36; International 424-37HP; McCullogh Pro 10-10
Offline Banjo picker
Re: Sawmill shed
« Reply #22 on: October 13, 2014, 05:48:24 PM »
No need to worry about being jealous.  I got a pretty good shed and I am still jealous, esp of those big openings.... Banjo
Online Peter Drouin
    • A&P Saw mill LLC
Re: Sawmill shed
« Reply #23 on: October 13, 2014, 08:23:15 PM »
They wont go far. :D
A&P saw Mill LLC.
License NH softwood grader.
Offline ozarkgem
  • age 65 yrs old
Re: Sawmill shed
« Reply #24 on: October 13, 2014, 08:31:51 PM »
D12 series 3  28hp at the wheels and 25 at the pto  a fine lil tractor. needs brakes though,
I grew up on AC tractors. I have never heard of a D12. Must be a collectors item. Plus the same paint scheme as your mill.
Offline beenthere
Re: Sawmill shed
« Reply #25 on: October 13, 2014, 09:49:59 PM »
Offline mhasel
Re: Sawmill shed
« Reply #26 on: October 13, 2014, 10:35:43 PM »
How much headroom inside for the mill are you allowing? I like the idea of the raised tie chord, I used a similar design on a wood stove shed covering my outdoor Central Boiler
Offline brianb88
  • Still thinking
Re: Sawmill shed
« Reply #27 on: October 14, 2014, 06:03:26 PM »
Those are some mighty fine looking sheds you fellas have.
Measure twice, cut once
Offline drobertson
Re: Sawmill shed
« Reply #28 on: October 14, 2014, 07:23:42 PM »
ozark
Early 60's tractors
http://www.tractordata.com/farm-tractors/000/0/1/15-allis-chalmers-d12.html
Wow! thanks beenthere!  I have never seen this,  I was going on what I was told,, it does have good power for a little tractor,  picked it up for a mere 1800 bucks in the late 80's  less than 2000 hrs.  still hard to believe the brakes are shot, but they are,  if all goes well, I will get this done before the freeze hits.  As far as the shed goes,
a 12' ceiling is a good height, if lifts are to be in and out.  A drive through is a pretty good idea, just make plans for a close slab rack, the work triangle is critical for time in the log.
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
Re: Sawmill shed
« Reply #29 on: October 16, 2014, 09:12:45 PM »
 Heres what I'm working on to saw under. Its a 40'x52' covered building, 30'x50' is inclosed. Will set up the mill under the 12'x50' SHED.Building will be insulated & have an office/man cave/ living qtrs. on the opposite side of building I poured an 8'x12' joining slab, which will be a restroom with bathtub, urinal, sink,& storage space. 8) 8) Well my PICS would not upload since its jpg.Moderators this is a common format, whats up, am I doing something wrong?? ??? ??? ???
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
Re: Sawmill shed
« Reply #30 on: October 17, 2014, 03:49:05 AM »
You have to first upload the photos to your photo gallery, then link to it in the post.
This is done to ensure that your photo will remain available years from now so we don't wind up with red Xs where the photo has gone missing.
Here's a link to a guide on how to do it: http://www.forestryforum.com/board/index.php/topic,61788.0.html
Offline GDinMaine
Re: Sawmill shed
« Reply #31 on: October 17, 2014, 04:49:09 AM »
You can upload .Jpg files no problem.  The upload process is a bit different on this forum, but nothing you can't handle.
It's the going that counts not the distance!
WM LT-40HD-D42
Offline woodweasel
Re: Sawmill shed
« Reply #32 on: October 17, 2014, 12:11:19 PM »
ok , Lets see if I can get the pics up. I've posted pics before, dont know what the problem was
   The last pic is where the mill will be setup under ;D ;D
Offline Joe Hillmann
Re: Sawmill shed
« Reply #33 on: October 17, 2014, 12:33:05 PM »
If you are putting in a large opening for the logs make sure the beam above it is large enough to handle the snow  load.  This last winter was much worse than usual and just in Barron county thousands of building collapsed from the snow load.  Mostly pole sheds.  But some homes and lots of barns as well.
Offline WDH
Re: Sawmill shed
« Reply #34 on: October 17, 2014, 08:26:31 PM »
Weasel,
Looks awesome!  I am jealous.
Offline woodland84
Re: Sawmill shed
« Reply #35 on: February 01, 2020, 11:44:40 AM »
What size beam would be enough to support a 16 span for the side open to load logs?
Offline Don P
    • Calculator Index
Re: Sawmill shed
« Reply #36 on: February 01, 2020, 12:40:29 PM »
Impossible to say, need more info. I'm assuming rafters are supported by the beam?, how far is it to the other support end of the rafters (rafter span)? Overhang, how much? Snow load in lbs per square foot? Wood species and grade?
Offline woodland84
Re: Sawmill shed
« Reply #37 on: February 01, 2020, 01:24:15 PM »
Rafters would be 14 long with 1 overhang. So 12 wide. Full 8x8 vertical posts. Strapped and steel on roof. We have some snow load up here by times. Also 45 degree angle supports on either side of span as well.
Offline Don P
    • Calculator Index
Re: Sawmill shed
« Reply #38 on: February 01, 2020, 02:18:31 PM »
Find your snow load in pounds per square foot, it is probably published online or available from the local building dept or truss shop. "some snow load" is something between 10 and 300 lbs/sq ft x 112 sq foot area bearing on the beam.
Offline woodland84
Re: Sawmill shed
« Reply #39 on: February 02, 2020, 01:07:13 PM »
From what I can find the snow load in my area would be around 20 lbs per square foot.
sawmill shed
Started by woodlandmillguy27 on Sawmills and Milling
Last post October 29, 2013, 06:18:54 PM
by Happycamper
Sawmill Shed
Started by stanwelch on Sawmills and Milling
Last post September 22, 2020, 06:04:09 PM
by Biocmp
Sawmill Shed
Started by Junior437t on General Board
Last post May 29, 2005, 04:30:25 AM
by Bibbyman
sawmill shed almost done
Started by forrestM on Sawmills and Milling
Last post May 23, 2019, 09:14:29 PM
by boonesyard
