Author Topic: Sawmill shed  (Read 6643 times)
Online EOTE
  • I don't suffer from insanity-I enjoy every minute.
Re: Sawmill shed
« Reply #40 on: February 02, 2020, 07:55:40 PM »
My sawmill house is a bit smaller than what you are looking for and it was initially built fully open with no walls.  Side openings are 22' so I can bring in 20' logs and take out 20' lumber.  Ends are 20' wide.  Overall size is 20' x 40' and 12' high.
My drying house and sawmill houses are the duplicates.  Used shiplap for the roof and then R9 metal panels.
( I built scaffolding on both sides of the sawmill house so I could safely work on the roof because I am vertically challenged :) ).
EOTE (End of the Earth - i.e. last place on the road in the middle of nowhere)  Retired.  Old guys rule!
Buzz Lightsaw, 12 Mexicans, and lots of Guy Toys
Offline DennisK
Re: Sawmill shed
« Reply #41 on: February 02, 2020, 10:26:57 PM »
Wow, nice job, I'm going to borrow that from you. Are you done yet? :D
Online EOTE
Re: Sawmill shed
« Reply #42 on: February 02, 2020, 11:05:38 PM »
I built scaffolding on both sides of the sawmill house so I could safely work on the roof because I am vertically challenged (Image hidden from quote, click to view.)
The scaffolding was actually pretty easy to build and allowed me to overcome that fear of heights I've had all my life.  Basically it is 2" x 4" s on 4' centers with handrails and sturdy foot boards.  The foot boards were sawn from a couple of dead standing SYP's as 5/4" material.  I used structural screws to hold everything together which also made it easier to take down once it was completed.
I had an old pair of Skecher's Shape Ups tennis shoes that were absolutely non-slip on the metal roof and "no cry" knee pads I found on Amazon.  It really made the job anxiety free.
Assembly was straight forward, screwing the columns to the floorboard supports and then screwing that assembly to the horizontal holding member.  Then as I laid 12' floorboards, I also added the hand rails. (My wife even helped with the assembly).
I was then able to lay the shiplap on the roof.
We laid an underlayment of tar paper just to keep the boards dry until we were able to add the metal roofing.
Offline doc henderson
Re: Sawmill shed
« Reply #43 on: February 03, 2020, 04:00:28 AM »
I have an intermittent fear of heights.  If it is something I am or have built, I do better.  I have to be a little psyched.  but in the right frame of mind, I can work and play at 40 to 50 feet.
me at Philmont 2016, at 42 feet.   :o :o :o
repelling from 50 feet
Offline jeepcj779
  • "Watch this" - Famous last words
Re: Sawmill shed
« Reply #44 on: February 03, 2020, 12:59:43 PM »
The US Army Airborne school thinks the scariest altitude/height is 34 ft. above the ground.
Offline richhiway
  • Rich
Re: Sawmill shed
« Reply #45 on: February 03, 2020, 01:07:18 PM »
Very nice building.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Re: Sawmill shed
« Reply #46 on: February 03, 2020, 01:26:59 PM »
@eote that is a sturdy building and will be around for a hundred years.  keep us posted on your progress.
Offline Old Greenhorn
Re: Sawmill shed
« Reply #47 on: February 03, 2020, 02:17:17 PM »
I have some serious shed envy.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here. OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker
Online EOTE
Re: Sawmill shed
« Reply #48 on: February 03, 2020, 07:31:29 PM »
You know, that's what my neighbor said too.   ;D
Offline Tom King
    • HistoricHousePreservation
Re: Sawmill shed
« Reply #49 on: February 03, 2020, 07:43:19 PM »
I built new houses for a living, with scaffolding very similar to that, for I forget how many years until I accumulated enough real scaffolding to do a whole side of a house. Now I have enough to do a whole house, and Alum-A-Pole will almost spoil you, since you're always working at a comfortable height.
The first couple of years, before impact screwdrivers, the wooden scaffolding was put together with double headed nails.
While I had the scaffolding up, since I did everything myself, I'd completely finish one side,and then take the scaffolding down to do another side.  People would say that it looked really strange to see a house with one finished side, and the others still had solid plywood sheathing.
Your buildings look great!
Online EOTE
Re: Sawmill shed
« Reply #50 on: February 03, 2020, 08:01:56 PM »
Tom King, thank you for the encouragement.  I have a thread going on building my retirement home at Building our Dream Home a.k.a. Delusions of Retirement.  I just started site prep today after spending the last 2 years sawing lumber for the home, building a sawmill house and drying house, and putting up an awning for my work area in front of our barn.
Re: Sawmill shed
« Reply #51 on: February 03, 2020, 08:34:56 PM »
@EOTE I have been following your posts from the very beginning and I finally have to tell you I have a heck of a lot of respect for your planning, your execution, your patience, and your steady follow through. I have done similar, but no where near the scale and the commitment you are showing. Nor do I have the skills you exhibit. My admiration is hard to describe.
 I just looked up your location to see if I could wangle a visit and maybe give you a days labor in the bargain but sadly you are about 8 hours fast drive from my family seat in Texas (and I live in NY). I used to travel (fly/drive) to Waco every year or two to one of our plants, but since I got a new boss 8 years ago, he would rather send a newbie/weenie that won't make waves. ;D I visit family on the gulf coast south of Houston every couple of years and we are due for that trip soon. But it's gotta be a full day of driving and there is now way I can talk the wife into that. The only way is if we drive to Texas and stop along the way. I guess I will have to start working on that plan. ;D
 Anyway, just now some of us are really enjoying and admiring what you are doing and how you are doing it. Good on ya mate!
Online EOTE
Re: Sawmill shed
« Reply #52 on: February 03, 2020, 09:00:54 PM »
Old Greenhorn, you have absolutely humbled me with your praise.  I really don't know where to begin but maybe start by telling my wife all those nice things. ;D ;D :D  No, really, she appreciates what I am doing and supports it 110%.  She still works full time but she comes over (200 miles one way) on the weekend to help me.
You are always be welcome to come by to visit.  Jacksonville is about 4 hours east of Waco and I think its about 3 hours from the north side of Houston so Galveston is probably another hour and a half if you have to drive through Houston.  Either way, if you decide to, just give me a holler.
As far as my skills and patience and other traits, I have to say I am my own worst critic.  I always review what I have done and try to learn how to improve on it; even if I did a great job.  I always see the things I could have done better.  I am also curious and have never been afraid to learn a new skill.  I also value input from others because they see things in a different perspective than I do and often times can offer their experiences or knowledge.  The more I learn the less I know...I guess that is my addiction.
Thanks.
Re: Sawmill shed
« Reply #53 on: February 03, 2020, 09:19:00 PM »
Indeed, I have suspected for a while that we are of like minds, but you seem to learn much better from all those 'lessons' than I do. :D
 You are closer than I had thought. My cousins I visit are in Angleton, Lake Jackson (my Uncle Gus designed the city of Lake Jackson as a side job in the evenings), and Freeport on the coast. I don't expect to ever get back to Waco since I will retire (hopefully) in a few months. Sounds like you are about 5 hours north. I just have to wait for the opportunity and I am patient. Of course, that may mean we are sitting on the porch of your finished home by the time I make it. ;D
Offline Cruiser_79
Re: Sawmill shed
« Reply #54 on: February 10, 2020, 01:59:25 PM »
Nice sheds you all have! Great inspiration.
Don't wanna highjack this topic but need some advice as well. Just bought a 'new to me' mill, a Mebor. We can pick it up next week together with an old edger. I was thinking of building a back drag feature on the machine, with a roller table and a kind of sorting/storing table next to the edger. Big and heavy beams I would like to take of the mill with the chain turners back on the loader forks.
But in this topic I also see edgers parallel to the mill instead of in line, is that a better solution than in line? I have the feeling I might miss something  :)
I want to start milling some silverpine for building a simple shed, and I'm figuring out or it's better to make it long and narrow, or short and wide.
new sawmill shed
Started by cheyenne on Timber Framing/Log construction
Last post September 08, 2008, 11:48:57 PM
by Raphael
Sawmill Shed
Started by Junior437t on General Board
Last post May 29, 2005, 04:30:25 AM
by Bibbyman
Sawmill Shed
Started by bigD on Sawmills and Milling
Last post March 06, 2015, 08:50:05 AM
by bigD
Sawmill Shed
Started by Jstier on Sawmills and Milling
Last post January 29, 2020, 03:24:54 PM
by Frontier_Paul
