Author Topic: Getting custom beams certified for construction use?  (Read 1018 times)
Offline golddredger
  • Keep on Keep'in on!
« on: October 20, 2014, 12:50:07 AM »
Getting lots of requests for custom beams now but they will have to be stamped or certified for construction use. 14"x14"x10' beams needed now. Where or what do I need to do to get these beams stamped and graded officialy? Who should I call?
This is going to be a huge market for me. Big beams are the rage right now. Thank for the help.
Home built bandsaw mill and trailer for a mini logging operation. Lots of chainsaws and love the woods.
Offline highleadtimber16
  • Learning Everyday
Re: Getting custom beams certified for construction use?
« Reply #1 on: October 20, 2014, 12:59:25 AM »
Interesting, around here we don't need any certification on any wood. Good Luck.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline beenthere
« Reply #2 on: October 20, 2014, 01:18:22 AM »
There are agencies that will do the inspection.
http://www.wclib.org/
There are others as well. A place to start. Some are specific to certain species.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #3 on: October 20, 2014, 01:36:44 AM »
That is the grading service I have used. They over see all the graders at the production mills in the area.
I give them a call and with in 30 days the grader will be in the area. They charge by the hr figure 3 hr min. (time on site plus an hr in the office)
When you are sawing these timbers you need to have a good idea of grade as well to minimize rejects.
Offline FarmingSawyer
  • Gettin Older By the Day!
    • Claddagh Farm
« Reply #4 on: October 20, 2014, 06:47:03 AM »
I tried, once upon a time, to become a softwood grader for just this reason..... Our mill was producing mainly structural specialty timbers--that had a great, desired, looking circ. sawn face, but the building inspectors and architects only wanted graded lumber in their structures..... There were several mills in the area and I figured I could float between them and grade as needed and pick up some extra cash......boy was I disabused of that fantasy! No way! one mill, one grader attached to that mill. There was no way I could afford a grade stamp for just our mill, or one for each mill....Silly really. My plan was genius...genius, I tell ya.
There was a time that you could upsize any ungraded timber by 2" in each direction and it would pass.....doubt the International Building Code allows for that now....
Thomas 8020, Stihl 039, Stihl 036, Homelite Super EZ, Case 385, Team of Drafts
« Reply #5 on: October 20, 2014, 11:00:52 AM »
West coast lumber inspectors bureau over sees all the graders working in the mills in their service area and they do regular spot inspections (1 unit) to insure the graders in the mills are grading accurately.
The person doing the spot inspections is the one who comes out when you call for a grader.
At the mill I worked at we had 9 production graders (3 per shift) and 3 QC. The QC would do daily spot inspections as well.
Graders were required to be recirtified as often as electritions. Since I over saw both a sawmill crew and a planer crew I had to go thru all the steps except cert testing, right along with the graders on my crew.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #6 on: October 20, 2014, 12:03:18 PM »
I have to renew mine every 5 years :P
A&P saw Mill LLC.
License NH softwood grader.
Offline golddredger
« Reply #7 on: October 20, 2014, 12:47:30 PM »
Thanks for the link and info fellas. I found that same place but was not sure if they where the correct ones. I will call them. Good old California making us jump as many hoops as they can.
Using oak for construction beams
Started by Dionvh on Timber Framing/Log construction
Last post November 03, 2018, 02:51:27 AM
by Dionvh
Retail Husqvarna Displays from Custom Cut Beams
Started by sgschwend on Sawmills and Milling
Last post April 20, 2012, 12:24:33 AM
by Woodchuck53
Making Custom Timber Frame Beams as needed.
Started by prittgers on Sawmills and Milling
Last post October 29, 2019, 02:02:08 AM
by prittgers
Construction with green logs as beams...shrinkage issue.
Started by ayerwood on Timber Framing/Log construction
Last post September 11, 2013, 08:30:11 PM
by jander3
