Author Topic: Did someone say hard?  (Read 1237 times)
Offline drobertson
« on: October 21, 2014, 07:59:01 PM »
this has been the case for a few days now.  Dead red and white oak.  This one got my attention, but wmz prevailed..
checking for any possible metal stain, stock was available.
The yield was not bad for a dead one, but will say,  I really don't like 1x6" patterns on certain logs,
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Did someone say hard?
« Reply #1 on: October 21, 2014, 08:06:09 PM »
White oak can be tough. What band did you use? I usually go to a 4 for the hard stuff. I did some resawing of a some old locust cants. It cut great, and the band could take the HP, which is good, because it wanted it. :D
Offline drobertson
« Reply #2 on: October 21, 2014, 08:11:09 PM »
Dave, I used a resharpened! ;D cooks super sharp face grind on these.  I did start slabing a lil heavy due to breaking off stuff.  Those who know, know what I mean.   done, and glad of it.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #3 on: October 21, 2014, 08:23:34 PM »
I cut w and r oak with 7x 55x1 , And it cuts like w pine ;D
A&P saw Mill LLC.
License NH softwood grader.
    • My homepage
« Reply #4 on: October 21, 2014, 08:27:14 PM »
Do you run 7 for everything now? I've been thinking of switching.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #5 on: October 21, 2014, 08:31:52 PM »
On dry W & R Oak, Maple, Pecan and HickoryI simply use the 4, without looking back.  :)
Offline drobertson
« Reply #6 on: October 21, 2014, 09:21:53 PM »
I reckon in the northern climates, everything cuts like white pine ;D,, I have my grinder set some where between 5 and 10 degrees.  it works,   the cooks super sharps and the kasco blades are pretty even in my book.  Not much blade breakage, with well over a 1000 bdft per blade, resharpened ones have bumped 2K,  not pushing, just sawing,  hard to pull a blade when it's working.
    • A&P Saw mill LLC
« Reply #7 on: October 22, 2014, 06:22:17 AM »
Yes, I tried 1 7x55 and don't like them. They swim more. 1x 7x 55 is all I use. And with the Wood Mizer CBN sharpener in oil there easy to keep razor sharp.
A&P saw Mill LLC.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #8 on: October 22, 2014, 09:46:42 AM »
Thats a 4 if I ever saw one.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #9 on: October 22, 2014, 11:36:55 AM »
Dave Shepard asked if seven degree blades were good as a 'standard' to run for most all types of wood . . . .
I switched over to sevens after reading Bibbymans thread on this a few years ago.
Turned out to be great advice as my mill only sees the sevens now.
However, I've only got an Onan with 24 horses, so in winter and with frozen hardwoods, I'll drop down to four degree blades.
Now it's easy to keep track of blades, Sevens in Spring, Summer and Fall. When it's DanG cold out, pull on the long johns and use the four degree bands.
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
why is it so hard?
Started by drobertson on General Board
Last post August 17, 2015, 08:00:57 AM
by r.man
Hard
Started by Peter Drouin on Sawmills and Milling
Last post April 08, 2015, 08:23:07 AM
by drobertson
Hard to Believe
Started by POSTON WIDEHEAD on General Board
Last post December 29, 2015, 10:15:39 AM
by millwright
A really hard day, NOT!!!!
Started by etat on General Board
Last post February 25, 2004, 08:00:03 AM
by Tom
