Author Topic: From Woods to Woodshop  (Read 2478 times)
Offline Bibbyman
    • Warden Sawmill
« on: February 26, 2002, 06:18:57 PM »
Has everyone read Gene Wengert’s great little book titled “From Woods to Woodshop – a guide to producing the best lumber”?  :P If you haven’t I recommend it highly.  It’s only 19 pages but is the most concise collection of instructions on how to saw lumber I’ve seen.
I’m not sure where else it is available but it is available from Wood-Mizer for $5.00.  Or,  for $5,000 - $60,000 more, they’ll throw in a new mill! ;)
www.woodmizer.com
Sawing since '94
Offline Frank_Pender
Re: From Woods to Woodshop
« Reply #1 on: February 26, 2002, 08:15:34 PM »
Does he cover any of the species and the operations of the Western part of the United States, in the booklet?  :P Or, is it more generic in nature and "guidance"?  Is it retro-fitted for cirlce saws or merely designed for those with band mills?  :-[
Offline Bibbyman
    • Warden Sawmill
« Reply #2 on: February 27, 2002, 05:01:12 AM »
Well,  with just 19 pages you can't expect it to be a complete encyclopedia of knowledge of the forest industry.  But..  It's about the minimum you should know when you step up to saw a log into usable lumber.  When I was starting out,  I read a small library of books on the subject and this one contains about 95% of what was important in all of them.
It's written generic as to circle or band mill and it covers hardwood and softwood.  It covers the anatomy of a log as seen by a sawyer - 4 faces, face cuts, defects, sweep, and such.   It covers sawing methods such as grade sawing, boxing the heart, live or through and through sawing, etc. It talks about moisture and drying and shrinkage and lumber storage.  It talks a little about lumber grading and sawing to extract the most return value from the log.  Etc, and so on.  Then it's got a page of other places a person can go for formal training such as lumber grading classes or to get more in-depth materiel on a specific subject.
Under the "Resources" bullet on the Wood-Mizer home page you can connect to the following blurb they put out on the guide:
A nice sized tree has just been felled in the woods. Your plans are to saw as much of the tree as possible into high quality lumber. You want to do this with a minimal amount of waste and, at the same time, you want to maximize the value and usefulness of the lumber you produce. How do you proceed?
Produced in collaboration with renowned forestry expert Dr. Gene Wengert, this three part instructional book covers sawing techniques, drying methods, and includes a resource guide. Written with both the hobbyist and the professional in mind, it contains basic, practical information on how to saw and dry lumber efficiently with minimal loss and downfall. You'll find all the information you need to convert our valuable, renewable resource into useful and durable wood products that will last for centuries.
Sawing since '94
Woodmizer Links forum member Gene Wengert book "Woods to Woodshop"
Started by VictorH on Sawmills and Milling
Last post November 30, 2012, 10:48:27 PM
by Jasperfield
Old barn into woodshop
Started by getoverit on General Board
Last post January 09, 2006, 11:30:20 AM
by getoverit
New Little Woodshop Inside
Started by tcsmpsi on General Woodworking
Last post July 23, 2011, 08:53:12 AM
by Magicman
Sawing for the woodshop
Started by jdunmyer on Sawmills and Milling
Last post May 15, 2004, 09:57:58 AM
by jdunmyer
