BLUECREEPER Poster Award #4!
Hi all,I've been reading these threads for a few years, since we first got our owb in 2011. We had an issue last winter that warranted CB replacing the entire firebox because of corrosion. Has been running fine since Feb. of this year until yesterday...of course the first below freezing day of the year. So the issue is that I can't get the fire to stay lit once I shut the door. I know it sound simple but it has me baffled. Cleaned all the air holes, checked the fuse, can't figure it out. Water temp stays up at 185-180 but reaction chamber won't go up unless I have the door open and I'm giving it air. What do y'all thinkThanks!VTwoodburning - I don't have the E-Classic 2400, I have the E-Classic 1400. But, it sounds like something is plugged somewhere. Have you checked for creosote build up in the elbow of primary air solenoid? You may have to consult your owners manual. On the 1400 it is found in the rear of the OWB in the vicinity of the blower. Simply loosen the clamp that holds the rubber coupler to the elbow and remove the elbow. It may a bit of friendly persuasion to get it loose. On mine it was nearly plugged with creosote after a full season of operating it. Are you sure the primary air holes in the firebox are clear of creosote buildup? Every couple of weeks I poke a piece of stiff wire through mine just to be sure they are open. Roger
Started by Cass007 on Firewood and Wood Heating
Started by AsaG on Firewood and Wood Heating
Started by New Guy on Firewood and Wood Heating
