Author Topic: Where would you cut the nose on an old cant hook?  (Read 3689 times)
Offline shinnlinger
« on: November 18, 2014, 09:05:27 PM »
Hello,
I recently made a new handle for my old cant hook on the lathe.  I even did my first offset turning on the butt of the handle of which I am very proud, but that is not the reason for this post.  Being an old style without a nose, I was going to just call it good but then it occurred to me I could put some copper fittings (or some kind of cleat) on the business end of the tool if I turned it down some more.  I also suspect it is longer than it needs to be and perhaps I should shorten the nose a bit while I am at it to roughly where the copper fittings are.
Any pointers?
Shinnlinger
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Where would you cut the nose on an old cant hook?
« Reply #1 on: November 18, 2014, 09:08:11 PM »
You turn a nice cant hook handle shinnlinger.
Offline thecfarm
« Reply #2 on: November 18, 2014, 09:11:56 PM »
Check out the Logrite site.
Offline Gideon_70
  • Just joined and looking forward to talking!
    • Daytona Gun Owners
« Reply #3 on: November 18, 2014, 09:16:26 PM »
Hello,
Any pointers?
I have two of them.  One I use to unload trailers with, and it's great because it's long at the nose and lets me lift the log a bit - but it doesn't work well at the mill because the nose gets in the way.  So I guess it'll depend on what you are doing with it.
You cannot reduce crime by disarming the victims!
Offline shinnlinger
« Reply #4 on: November 18, 2014, 09:25:12 PM »
Thanks WDH,
 Had some fun with these projects.  A student wanted to turn a peavy handle and then another wanted to make an ax handle so of course I had to show them how to do it an now we are making handles left and right.  Made a double bit throwing ax handle today for the dartmouth woodsman team.
cfarm,
The log right site shows the cant hook on a log, but not folded up so it is hard to gauge where their snout ends, but it is shorter than mine
Gideon,
Do you have a Peavy for the trailer and a cant hook for the mill or a long nosed cant hook for the trailer and a short one for the mill?
Shinnlinger
Offline Onthesauk
  • Still learning!
« Reply #5 on: November 18, 2014, 09:29:47 PM »
Go to Google, Imagines, Cant Hook.  Should get a whole bunch of ideas!
John Deere 3038E
Sukuki LT-F500
Dont attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Offline shinnlinger
« Reply #6 on: November 18, 2014, 09:50:51 PM »
I have done that but it is inconclusive.  half the shots are actually peaveys and many are open so you can't tell.  Of the ones that are somewhat closed it does seem to end where the hook comes up or shortly thereafter.  I am wondering if I should add a cleat of some kind as opposed to simply a copper fitting.  I have longer peaveys and a really neat little cant dog thingy that was manufactured locally about 50 years ago.  Has Canaan NH  stamped right on it.  Might have to haul that into the shop and make a new handle for it.
I envision this unit being used on the mill when the little do dad thing isn't big enough.
Shinnlinger
Offline cousin jw
« Reply #7 on: November 18, 2014, 11:33:29 PM »
 I think I found a photo that might be of use to you for this project. Majicman posted a photo of several Logrite cant hooks in the closed position in response #43 in the thread 'What length can't hook to buy' that was started on 10-4-14. This post was the second post that came up when I typed in Logrite can't hook in the Forum search engine.
Offline BCsaw
  • Love to build, fabricate and make saw dust!
« Reply #8 on: November 18, 2014, 11:42:10 PM »
Shinnlinger, I just went and measured my old cant hook. The hook is approximately 12" from the end of the hook to the pivot point. The nose is 8" from the end to the pivot point.
The overall length is 50".
I hope this helps some.
Happy hooking! :D :D
Inspiration is the ability to "feel" what thousands of others can't!
Homebuilt Band Sawmill, Kioti 2510 Loader Backhoe
Offline 5quarter
    • Blue Harbor Refinishing
« Reply #9 on: November 19, 2014, 01:16:04 AM »
Shinnlinger...Great job on the handles! If it were mine, I'd take it back to where the point meets the handle. Did you make the axe handle too? again, nice work.
Offline shinnlinger
« Reply #10 on: November 19, 2014, 07:11:56 AM »
Thanks guys, will look
Into those measurements.
I made both handles out of some ash I milled a few years ago to show some students how to do it.    The axe head I found on the family homestead in Linconville me.  My 6Th. great grandad got the land for fighting in the Revolution, so it could be pretty old, but who knows?The cant hook bit I found in an old barn here in Canaan but had been using around the mill with a busted shovel handle wrapped with a ball of duct tape to keep it tight.    I like my new handle better...
Shinnlinger
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #11 on: November 19, 2014, 07:20:45 AM »
Old cant hooks and peaveys.
Logrite cant hooks.
Offline bandmiller2
« Reply #12 on: November 19, 2014, 07:39:53 AM »
Shinn, the geometry of a cant or peavey is critical for the best operation. I would copy the dimentions of one you like. I make peavey handles from louieville slugger bats I find. Yes I do own a Logrite canthook. I must try aluminum bats. Frank C.
Offline loggah
  • Just hangin' around :)
    • Johnson Hollow Sawing and Shingle Making
« Reply #13 on: November 19, 2014, 05:01:35 PM »
Shinnlinger,I have a couple of those mill cant turners made by Jamieson in Canaan,a medium and a small one there nice little hooks. On your end you should have a steel thimble,closed end with a small lip on the inside edge! ;D If you need any more parts i probably got parts to 50 or or more hanging around.
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Offline shinnlinger
« Reply #14 on: November 19, 2014, 09:00:11 PM »
Thanks again all!
Looks like I need to start turning some more handles to catch up with Magicman.
My Canaan hook is also a Jameson but I think One of the Larrys first made them and then sold the biz to Jameson and then another Larry bought it back.  I would love to see yours as I might be able to remanufacture them with the vo-tech school.  We are already working on a pickaroon together.  They do the steel and we do the wood.
Loggah, you probably knew Ed Larry.  I used to enjoy talking with him.  Still see Charlie Neilly around and he is another fellah I always make time to talk with.  He has forgotten more common sense than I will ever know.
Shinnlinger
Offline shinnlinger
« Reply #15 on: November 19, 2014, 09:02:20 PM »
Magic,
I see that your bottommost wooden cant hook and your top Logrite cant hook have shorter snouts than the others.  Do you have a preference?
Dave
Shinnlinger
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #16 on: November 19, 2014, 09:43:28 PM »
They actually have longer hooks for handling larger logs.
Offline loggah
« Reply #17 on: November 20, 2014, 06:46:23 AM »
Your welcome to come over and check them out anytime. they are both in this picture.
Offline shinnlinger
« Reply #18 on: November 20, 2014, 10:07:24 PM »
this has been an interesting process because for the first time I actually looked at the geometry of a cant hook.  I will turn down my new one to where the hook extends at half mast.   I am sure that makes no sense but it seems to be the spot consistent with the others.
Shinnlinger
Offline StorminN
« Reply #19 on: November 22, 2014, 01:37:30 PM »
Looking very good, Shinnlinger!
-N.
Happiness... is a sharp saw.
Nose to nose
Started by Onthesauk on The Outdoor Board
Last post January 18, 2008, 07:35:27 PM
by Onthesauk
My Nose knows
Started by SW_IOWA_SAWYER on Sawmills and Milling
Last post May 28, 2006, 07:51:22 AM
by Don P
My nose says elm...
Started by Pepe_Silvia on Tree, Plant and Wood I.D.
Last post January 24, 2020, 09:45:56 PM
by DPatton
My Bar Nose Came Apart!
Started by lxskllr on Chainsaws
Last post February 19, 2019, 07:47:36 PM
by lxskllr
