oliver tractor
Started by timberlinetree, November 27, 2014, 06:11:47 AM
timberlinetree
Was going to buy this for pushing/loading wood chips and growing pumpkins for a nonprofit helping kids. Are they any good? It is gas and a 1750 with 1700 hrs on it and not running. Thanks for your help.
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
HiTech
Oliver was one of the best tractors ever built. It would be worth some TLC. When White took them over it was all down hill after that.
1700 hours???  :o  That is not much. Are new parts still available?
Depends on the money, as a 50 yr old tractor not running and likely parts not readily available would not be much more than a headache. But in the 60's they were good strong farm tractors.
As said, White ran them into the ground, but they were already on the ropes and struggling.
For the money (whatever it is) there are better investments. But it is your call.
Corley5
It would have to be really cheap.  A non running tractor can hide LOTS of issues that only come to light after it's running.
chevytaHOE5674
Oliver parts are still available both aftermarket and from AGCO, but you probably won't like the price.
1750 was a decent tractor of the era with decent hydraulics and a "hydra-power" 2 speed powershift, although the forward to reverse shifting isn't the best for a loader tractor. The 283 Waukesha is a pretty good motor, but parts are getting hard to find.
Not running I would buy it for scrap weight and go from there.
gspren
  Farmers around here still use them, there is a place called Zimermans that carry parts. Not sure if I spelled that right.
treeslayer2003
Quote from: chevytaHOE5674 on November 27, 2014, 10:15:09 AM
you can get some waukesha parts at napa......they came in all kinds of stuff not just olivers
those old tractors are tough as heck, i bet not much wrong with it.
chevytaHOE5674
You may be able to get some Waukesha parts at napa but if you ever need hard parts (crank, rods, head, etc) for the motor you may have to hunt. Neighbor farmer has a 283 Waukesha on a Genset and he ended up buying an Oliver 1750 and robbing the motor out of it because it was cheaper than buy/hunting down a few engine parts that his needed.
Firewoodjoe
If you don't mind a project buy it. Around here fixed up it would bring 6-7000 I would think. I know the loader alone would go for 2000. I have a wakasha in my loader. Never have problems finding parts
Maine logger88
Some guys around here are actually just replacing the wakasha with a 4bt or 6bt cause of parts avail. But with the cummins an Oliver would be pretty sweet
timberlinetree
Sounds like I should buy it if reasonable. Sat Marcia and I will go look and see if we can buy it. Any thing I should really look at on this thing? Thanks.
Yes, learn exactly why it is not running. Low battery? blown engine ?  A couple things on opposite ends of the scale of 1 to 10 reasons to buy or not.
If just "looking", then the pic shown doesn't "look" too bad. ;)
lopet
Sorry to sound negative.  But from my own experience I wouldn't pay more than scrap price. It could be a minor problem, but if it's sitting for years  you could run in to a real " money pit "
luvmexfood
Timberline
This is what I found for you on fastline:
Category: Tractors
Manufacturer: Oliver
Model: 1750
Number of Pieces: 4
Current Items w/Prices: 2
High Price Found: $7,600.00
Low Price Found: $2,500.00
Average Price Found: $5,937.
50
Equipment values are based off of the last 6 months worth of data in our system
www.fastline.com
Here is one listed on that site. No loader: Oliver 1750, (1) New Radial Tire, Making Oil, Small Fire, Tin Work All Good, Will Run $2,500 (W)
You now owe me. I missed Jerry Springer finding this. HA HA :D
Give me a new saw chain and I can find you a rock in a heartbeat.
Oliver05262
  Parts available at Sid Chavins on Schoolhouse Road in Nassau, NY.
Old Sid passed away, but his son or grandson is running the place now. Lots of new old stock, used and aftermarket parts available.
I don't have the phone number here, but I can get it if you post back.
Oliver Durand
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
"I woke up still not dead again today" Willy
Don't use force-get a bigger hammer.
timberlinetree
Thanks so much for all the help! It hasn't run in 2 years but was running when parked? It was bought brand new by his dad. He was using it to mow grass around his property but bought a small compact tractor to replace it. I'm a little nervous about a money pit, but some of the work this will be doing is priceless. What should I look for on a no running tractor so it doesn't turn into a MAJOR project! I feel better knowing parts are around and how much they are worth. Thanks so much and sorry you missed jerry, I do owe you one (maybe a pumpkin or a beer or a pumpkin beer) smiley_beertoast
54Dutchman
I had one for a few years; tractor had one weak point - the front end broke down with farm use of the loader. Problems with the front rims and casting that the power steering cylinder moved.  I was told that those problems where common with these.  Replaced with skidsteer - made for loader type work. :) :)
timberlinetree
It's a little more work than thought and Marcia thinks we should weight for something in a little better shape. I like rusty things that have the potential to be shiny and working. It needs rear tires, loader cyls are rusty, and doesn't run and is gas. He wants 3000 for it. What should I offer him? Thanks
Corley5
New rear tires will be expensive.  What else is wrong that will only show after it's running?  A loader on a tractor is hard on a clutch.  If the hours are correct and it's always had that loader on it.  It may very well be time for a clutch.  That's not a cheap fix and it's time consuming.  You could get a field ready machine for the dollars you could wrap up in this one.  Maybe even for less dollars.
QuoteHe wants 3000 for it. What should I offer him? Thanks
Nothing, until he gets it running. Then consider your offer after you can test drive it.
No reason that I see, for you to take the risk with your money. The onus is on him.
luvmexfood
Not running, it's a pig in a poke. You don't know what your getting. Could be a minor something or could be engine problems plus tranmission plus hydraulics. The list could go on and on.
Tell him to get it running and then you will talk.
Just my opinion.
lopet
Around here it would be a number between  8 Cents per pound and what a wrecker would pay for salvage , witch I guess around $ 2000 or 2500 at most. ( $ 2000 for the tractor + $ 500 for the loader   maaaaybeee )
About a year ago my neighbor sold a old Ford 4000 and a old round baler to the wreckers and got $ 1900 for it. The tractor was running and he drove it in the yard with the baler, pulled the battery , took the money and ran. :)
It all depends how much potential you see in that old girl.  Sorry for maybe not being much of a help.
chester_tree _farmah
Or ask him if u can try getting it to run? Does it even turn over still? Does it come with that flail mower? Good flail mowers aren't cheap.
254xp
C4B Can-Car Tree Farmer
Ford 1720 4wd loader hoe
Corley5
It's a pretty big tractor for a pumpkin patch.  Unless it's going to be a big pumpkin patch  ;D :)
