Author Topic: Better setter  (Read 962 times)
Offline uler3161
Better setter
« on: December 05, 2014, 12:46:01 PM »
We've never used ReSharp before, but know people who do. I've also read a few things here on the FF about the service. The recent thread about finding an alternative to ReSharp reminded me of one of the complaints I've heard/read about why blades are rejected. Apparently if they have "too much set", they are deemed useless. We simply bend the teeth back the other way. Doesn't take a lot of time, but it's also not an automated process for us.
What I'm wondering is if there are any setters out there that automatically handle a tooth with too much set? Seems like a good idea, but I've never seen one. I'd like to find an automatic setter that does this. Right now we use an old WM single tooth hand setter with dial indicator. It's slow, but you catch (and usually can fix) every issue with every tooth.
1989 LT40HD, 12ft extension, WoodMaster 718, Fordson Major Diesel, Champ CB40 Forklift
Dan
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Better setter
« Reply #1 on: December 05, 2014, 01:02:52 PM »
I've recently been very successful using my dual tooth setter to push teeth back.
Used to be if I accidentally set too much like 035 or greater I'd delegate that for spruce.  Well I started to have too many "spruce" blades.
Now I just take out one of the anvils, back off the setting on the other about 2 turns, position the over-set blade and adjust it  so this will push a tooth BACK about 10 thousandths, and crank it around.  Have to do one side, then the other, because the spacing doesn't come out right to do them both at the same time.
The uniformity of the resulting set is very good, probably have better set teeth doing this than the normal way, and all of them are the same now, no worry about some being too far out.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Better setter
« Reply #2 on: December 05, 2014, 01:38:59 PM »
Correct.  Most setters can neither detect nor correct too much set.
Offline uler3161
Re: Better setter
« Reply #3 on: December 05, 2014, 02:05:19 PM »
I figured as much. I'd think with todays electronics this would be easy. I've thought about trying to build one myself. Maybe after I get my setworks working correctly.
Dan
Offline Brian_Rhoad
Re: Better setter
« Reply #4 on: December 05, 2014, 02:50:42 PM »
The Timberwolf setter is supposed to increase and/or decrease the set.
Offline uler3161
Re: Better setter
« Reply #5 on: December 05, 2014, 03:07:42 PM »
Thanks. That looks like what I'm talking about
Dan
Offline Larry
    • Copas Sawmill
Re: Better setter
« Reply #6 on: December 05, 2014, 03:22:01 PM »
Going back in time to around 1990 WM had a roller thingy that you were supposed to use before sharpening/setting.  The rollers took the set out of the band.  Seemed like it was a pretty simple device that attached to the sharpener.
If the above statement needs correction do it...I suffer from CRS.
Offline uler3161
Re: Better setter
« Reply #7 on: December 05, 2014, 04:30:25 PM »
Could be. Our setter is WM 1988 vintage but I don't think we have something like that.
Dan
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
Re: Better setter
« Reply #8 on: December 05, 2014, 04:30:58 PM »
My Suffolk dual tooth setter came with anvils and instructions for down-setting.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Re: Better setter
« Reply #9 on: December 05, 2014, 05:20:52 PM »
Hello,
We have Re Sharp Sharpening service here at our location in Pennsylvania. We sharpen lots of blades per week. The process is sharpen, clean and set.
The cleaning process is done with a wash station and we use hot water, wires brushes and a spring loaded roller that makes all the teeth the same before we take the blades to the next station.
If a blade is rejected the tooth may be really bent out or a tooth damaged or if more than three teeth missing then it is rejected. If only one tooth is damaged we straighten the tooth and put the blade back  into service.
 We always put a note on the blade if we do this for quality purposes.
If one side is bent out beyond reasonable amount it is rejected. One because labor to straighten the complete side is not cost effective. The other reason is once the blade is bent beyond a amount the blade set has memory and will never work as good as new. Most times the blade tooth bends the profile also and again it just will not cut.
There are times we will sharpen blades we would normally reject because customers are willing to have a blade to cut trash logs etc. and do not expect the blade to have a high quality cut.
I hope this helps answer your question.
Thanks!
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline uler3161
Re: Better setter
« Reply #10 on: December 05, 2014, 06:18:06 PM »
Thanks for the explanation Marty. While we probably will stick with doing our own sharpening/setting, at least I have a better understanding when some of our local sawmilling friends have complaints.
Dan
Bmt 250 setter
Started by Chaser357 on Sawmills and Milling
Last post February 25, 2019, 10:19:27 AM
by Southside
NEED A SETTER
Started by SAW MILLER on Wanted
Last post March 24, 2006, 08:21:11 PM
by SAW MILLER
Setter
Started by ladylake on Sawmills and Milling
Last post January 10, 2018, 08:33:34 AM
by ladylake
My New Setter
Started by Fla._Deadheader on Sawmills and Milling
Last post February 20, 2003, 04:07:32 PM
by Fla._Deadheader
