Author Topic: Woodland HM 126 vs Harbor Freight sawmill  (Read 54888 times)
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
Re: Woodland HM 126 vs Harbor Freight sawmill
« Reply #60 on: November 24, 2015, 06:32:49 PM »
PTO shaft diameter, length, height, keyway on the two engines are both the exact same, however, the difference is the shaft end tapped which on the 420cc it's 3/8" 24UNF and on 301cc it's 7/16" 20UNF.
That makes no sense at all.  The bigger engine uses a smaller connection?
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Offline dukecrazy
« Reply #61 on: November 24, 2015, 08:42:31 PM »
that's what the specs say, lol.
G3033 LS tractor w/FEL, multiple chainsaws, and Central machinery sawmill.
Offline KirkD
« Reply #62 on: November 25, 2015, 12:07:44 PM »
With HF I would question it I bet you will find out it is metric.
Wood-mizer LT40HD-G24 Year 1989
Offline dukecrazy
« Reply #63 on: November 25, 2015, 08:29:22 PM »
I wonder how hard it would be to find a new clutch to fit if the one I have won't fit the new engine....hmmm
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #64 on: November 25, 2015, 09:16:13 PM »
You can buy bushings for smaller shafts.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline dukecrazy
« Reply #65 on: November 25, 2015, 09:47:50 PM »
Will definitely do that then!  For 300+bushings to double my power seems like a no brainer
Offline starmac
« Reply #66 on: November 26, 2015, 12:44:25 AM »
It would probably be easy enough to drill and tap the shaft if it was needed.
Offline dukecrazy
« Reply #67 on: November 26, 2015, 11:12:44 AM »
It seems there are a few good options on the table for it. Thanks guys
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #68 on: January 06, 2019, 05:56:19 PM »
Dragging this up from the depths, are any of the original posters out there and are you mills still up and running ?
Offline StimW
« Reply #69 on: January 07, 2019, 10:20:07 PM »
I still have my HF mill, it still works great.
I haven't had much time to use it because I closed my business, retired, bought 10 acres and moved 50 miles from where I was living and have been remodeling a 4 bedroom house.
I got some pine logs a year ago but they were poor quality, too many limbs but I cut them up just for fun.  :)
New HF Band Mill
Branson 35 hp 4 WD Diesel Tractor W/Attachments- Backhoe, FEL W/ Bucket or Forks, 4' Tiller
4000# Clark Forklift W/24" Tires
Promark 6" Brush chipper W/18 hp Kohler
Harbor Freight in Maine
Started by thecfarm on General Board
Last post October 21, 2013, 11:54:05 AM
by BobInMN
harbor freight bandmill
Started by slabmaster on Sawmills and Milling
Last post February 10, 2011, 09:13:35 AM
by ForestMan
Anybody got a harbor freight welder?
Started by brdmkr on General Board
Last post January 21, 2008, 05:24:35 PM
by buzzegray
Let's talk Harbor Freight...
Started by Paschale on General Board
Last post May 25, 2015, 07:22:22 PM
by hackberry jake
