Author Topic: 10hp electric or 20hp gas?  (Read 21788 times)
Offline hackberry jake
« on: December 16, 2014, 05:42:53 PM »
I came across a 10hp single phase electric motor. Should I switch it out with my 20hp honda? What would you do?
Offline Ga Mtn Man
  • Y'all can call me GMM
Re: 10hp electric or 20hp gas?
« Reply #1 on: December 16, 2014, 05:48:13 PM »
In your situation, I'd switch.
Offline tmarch
  • I'm older, maybe not wiser tho
« Reply #2 on: December 16, 2014, 07:31:20 PM »
Without knowing your electrical costs that would be hard to answer.  My electric costs .18 per KWH, no way can I convert my saw to electric, diesel maybe tho.
Retired to the ranch, saw, and sell solar pumps.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #3 on: December 16, 2014, 07:50:02 PM »
As I recall You will need about 7 amps/HP to run 220v single phase electric motor.
So your gonna need some juice,
You can estimate power consumption $$$ here.
http://www.cornhusker-power.com/operatingcosts.asp
I would say three Phase yes,  single??  you have to crunch the numbers.
Best
DGDrls
Offline ozarkgem
  • age 65 yrs old
« Reply #4 on: December 16, 2014, 07:52:18 PM »
electric will be cheaper I bet. I have 20 HP electric on mine.
Offline lineguy82
  • Not so new anymore
« Reply #5 on: December 16, 2014, 09:16:30 PM »
You've gotta factor your time and maintinence costs in too. Electric motors usually give far less problems than gas or diesel. Your parts cost and whatever you figure your time wrenching on something is worth is nearly non-existent on a electric motor. If you have the load capacity, I say go for it...unless you have a insanely high kWh rate.
P. S. If you're in a demand meter situation, that plays a big part also
95 chevy 4x4
Husky 562xp
Hardy H5
22T Countyline Splitter
...and hopefully a sawmill when the wife finishes college
« Reply #6 on: December 16, 2014, 09:41:34 PM »
I live in a fairly cheap area for kwh. Think I will see much of a reduction in power?
Offline Larry
    • Copas Sawmill
« Reply #7 on: December 16, 2014, 09:46:49 PM »
I think they will be close to the same.  It would take me about two seconds to go electric.  No gas, oil, noise, fumes, get rid of the battery maybe, no noise, and no noise.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #8 on: December 16, 2014, 10:07:01 PM »
I was thinking that as long as you're stationary and it's a toss-up between gasoline engine and electric motor, you would have to consider gas, oil, filters, and upkeep on the engine vs electric.
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline WIwoodworker
    • Milwaukee Woodworks
« Reply #9 on: December 16, 2014, 10:13:08 PM »
I'd keep the gas motor until it needed to be replaced. Then replace with electric.
Peterson 9" WPF
Offline Swatson
  • Arkansas born and raised
« Reply #10 on: December 16, 2014, 10:14:10 PM »
Electric motors are real easy to start in cold weather... :D
I cant figure out which one I like better: working with wood or making the tools to work with wood.
« Reply #11 on: December 16, 2014, 10:24:05 PM »
Unless they are hooked onto a hydraulic pump...  smiley_hourglass
Offline Swatson
« Reply #12 on: December 16, 2014, 10:39:03 PM »
Ah you got me there...come to think of it my air compressor is a bit finicky in cold weather as well.  I still have the 5 hp single phase I took off my old mill, I need to find a project to use it on.  I was quite impressed with what it could do (but the diesel is awesome).  I did have to upgrade to a 60 amp double breaker to run it.  I did not use a clutch on it when I had it.  It might have been better for the motor to have one but it had enough power to start the whole works from a dead stop.
Does the 20 hp motor a have a centrifugal start or capacitor only?
« Reply #13 on: December 16, 2014, 11:23:16 PM »
 say_what
The mill is set up with an over-cam type lever to engauge the gasoline 20 hp. The electric 10hp I imagine will use the same engauge method. It is capacitor start.
Offline Swatson
« Reply #14 on: December 16, 2014, 11:27:19 PM »
That's good.  Capacitor start motors generally start with a lot more torque than a switch type.
Offline ozarkgem
  • age 65 yrs old
« Reply #15 on: December 17, 2014, 06:16:15 AM »
Mine is hooked to a hydraulic pump. It has to be pretty cold for hyd oil to be a problem. My BIL has an LT 40 and put a 10 HP single phase motor on it about 6 yrs ago and couldn't be happier. Saws just a fast as the Onan gas did. GO ELECTRIC. The thing is if you don't like you can always put the Honda back on and sell me your electric motor. ;)
Offline bandmiller2
« Reply #16 on: December 17, 2014, 07:22:58 AM »
Jake, if you have the KW's to run that sucker have at it, electric motors are by far the best mill power. You should have the base rock like your gas engine so you can start no load and let it run between cuts as starting draws a lot of current. that motor is the equal of a 25 to 30 hp gas engine at least in practice. Electric motors have a lot of torque and will hold band speed in a cut. Frank C.
Offline customsawyer
    • The Custom Sawyer
« Reply #17 on: December 19, 2014, 04:20:27 AM »
Switch them. You won't regret it.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline FarmingSawyer
  • Gettin Older By the Day!
    • Claddagh Farm
« Reply #18 on: December 19, 2014, 05:02:47 AM »
popcorn_smiley  Keep up posted on how you go! I'd consider going electric if my mill were fixed.....
Thomas 8020, Stihl 039, Stihl 036, Homelite Super EZ, Case 385, Team of Drafts
Offline Glenn1
  • Drying lumber one board at a time
    • GPS Hardwoods
« Reply #19 on: December 19, 2014, 09:31:27 AM »
I don't mean to hijack this post my question is using a larger electric motor than the manufacturer offers.  Baker, Norwood offer 10HP electric and I think that WM and Cooks do too.  There 10HP are single phase and I have access to 15-20HP electrics in three phase configuration.  I would be using a rotary converter.  Would there be any benefits such as a quicker cut or more torque.  Are there any other  benefits?  On the downside, I know that I would be using more kilowatts.  Are there downsides like voiding the warranty?
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
opinions on 10hp electric
Started by brdmkr on Sawmills and Milling
Last post June 09, 2011, 11:13:48 PM
by jim blodgett
20hp honda Q
Started by BigJim2185 on Sawmills and Milling
Last post August 11, 2014, 09:54:12 PM
by hackberry jake
10hp deisel vs 15hp gas
Started by Bruno of NH on Sawmills and Milling
Last post April 16, 2019, 07:15:50 PM
by richhiway
One 10HP motor, or 2-5hp motors
Started by nathandcasey on Sawmills and Milling
Last post September 26, 2019, 10:20:43 PM
by Randy88
