Whatcha Sawin' ???
Started by Magicman, December 23, 2014, 12:00:38 PM
0 Members and 4 Guests are viewing this topic.
EOTE, I have never seen anything like that but you should be able to find that tooth with the unaided eye.  :o
doc henderson
looks like it cut strait from what I can see.  should be able to hear a little noise as that passes over the band wheels.  check the weld area to make sure it is flat as well.  send us a pic when you find it!  good luck.
Southside
Agree that looks more like a single tooth that got whacked rather than a mis-set band. Could have happened anywhere along the process, even entering the log.
White Oak Meadows
Deese
Quote from: Ruffgear on March 05, 2019, 07:40:52 AM
Deese, what's the size of that mantle? You're a busy man!!
Not sure which one you're referring to.  The one that's sitting on the table all cleaned up with the tung oil on it maybe?  Heck I really cannot remember. Customer found it in a burn pile on Maxwell Air Force Base and it was bone dry.  I typically cut oversize mantles from my own logs and stack them. Customer picks one out and we throw it back on the mill and start trimming it down until customer likes what he/she sees. They absolutely love the experience and are usually gleaming with excitement when we're done.  It's easier to charge more that way too.  ;D
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
olcowhand
"anybody with initials CA need a branding iron head?  "
Doc,
For that cool brand, maybe I'll change my name; I'm thinking something cool, like "Cal Armstrong", or maybe "Conner Abernathy"? :D
Nah, I'll wait for one that says "SS".
God bless you for the work you're doing with the Scouts.
Olcowhand's Workshop, LLC
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
doc henderson
thanks ol cow hand.  just took some 1/2" CRS plate and a got set up on a plasma table and made a couple dozen.  their might be a couple loggers, sawyers or foresters in that group.  cheers!
tule peak timber
Inbound alder and pine today....
Rob,   :o
Those bolsters look more like I am accustomed to seeing.
tule peak timber
Tomorrow I will take a pic of how they fold- pretty neat.
WV Sawmiller
   What's the alder used for? I always think of it as a very small shrubby tree and used for smoker wood on all the Alaska shows. Never thought of it getting big enough for lumber.
With those logs coming in you had better be putting your building britches on.  8)
Quote from: WV Sawmiller on March 05, 2019, 06:36:19 PM
There's about 2 dozen different species of Alder. That would be Western Red Alder, which grows into a respectable tree. Wood is a light coloured softer hardwood, but can be used for furniture and musical instruments as well as more utility stuff.  Probably comparable to soft maple or Tulip Poplar?
Other species are smaller and in a cold climate probably not much more than shrubs.
tule peak timber
Alder wood....
 <b
 I like building with alder. I live in the desert and it grows around water so when I can ,,,I grab it .
tule peak timber
Quote from: Ianab on March 05, 2019, 07:04:46 PM
I build a lot with this too.Manzanita and redshank ! Only 3-4 inches in diameter.
randy d
I have used Tag Alder for smoking fish  mostly suckers and northern pike it works good nice mild smoke. Randy
AZ_builder
Alder is what I built my cabinet faces out of and my interior doors. Manzanita makes great table legs with mesquite or juniper slab tops. Small juniper makes very strong table legs too.
Farm29
      Picked up some pecan logs from a friend down the road I think it looks like walnut but I have not been around fresh cut pecan and he swears he's picked up pecans around it for the 35 years they have live there.  ???
What do you all think
Either way looking forward to cracking them open he also had a white elm I'll prolly go back and get
96 lt40 Hyd 24 hp onan
460 rancher
Yes, saw it and I think that you will find out why Pecan is a smiley_devil.    :D
Southside
I think @WDH  will come on here shortly and tell you that you have a trailer full of ash logs.... :D
White Oak Meadows
Farm29
That's what I hear so I guess I'll find out
460 rancher
Lawg Dawg
White Oak, how about this for a woodshop? Yey or Ney?
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Crossroads
Those alder doors are very nice! Good work.
Alder logs don't have ash bark :D.
Farm29, just looking at the bark & log ends, I would have said Walnut too, but pecans don't grow on Walnut trees without some serious grafting.  Yes, it will be interesting to crack them open.
Lawg Dawg:  Yes.  :)
doc henderson
LD, are you asking about white oak, or the building for a work shop.  Both look great.  How did you get that square cant out of that round log with out cutting it open?
