Whatcha Sawin' ???
Started by Magicman, December 23, 2014, 12:00:38 PM
0 Members and 7 Guests are viewing this topic.
kbeitz,I've seen that trick with the dime too.
I got a serious inquiry yesterday about sawing ~150 Cypress cants that is only 80 miles away.  I used last week's job as a reference and bingo!
Have Gun Sawmill will Travel.   move_it
Kbeitz
Quote from: thecfarm on February 15, 2018, 10:06:12 AM
I call it tiddlywinks.
Love machine shop work
and Wood work shop work
And now a saw mill work
Crossroads
I ain't sawin nothin. I'm on day 7 of 14 days straight twisting wrenches in a pulp and paper mill. So far they're all 12 hr days, but it sounds like I might get a 16 or 2 over the next couple days. On the bright side, this should give me a little extra money for my trip to Liberia this spring.
 smiley_thumbsup  I wish Liberia was more within my reach.
caveman
MM, sawing cypress cants should be a treat.
WDH, the pecan slabs look very good.  On the wide cedar with the metal, I think I would put on one of the blades we have previously hit metal with but that still cut straight - we have several to choose from - and saw the rest of that log.  One dry, wide live edged cedar slab, without rot, should more than cover the cost of several blades.  I desisted last spring while sawing a large diameter oak solo after ruining two bands and also hitting nails with the saw chain.   After this cut the rest of the log made a contribution to global warming via the burn pile.  DanG, Mr. Widehead could probably get $300 for a thick cedar slab it he called it a mantle.
Jackpot ;D
Caveman
Crossroads
Ouch! That's so painful, even a caveman would feel it ;)
Jim_Rogers
Cutting some red oak trailer planks today and color coded them:
Jim Rogers
Yup Crossroads, I kinda hope that job comes through.  I love sawing Cypress.
The job that I just finished was set up on red clay sand.  Yup, the logs were practically covered with sand so I had the tailgunners busy knocking off as much as possible especially on the exit side.
The brushes got a good workout, actually a wearing out.
I had a full box of new brushes but I couldn't let the helpers know because then they would not have worn the old one completely out.   ;D
cbay
Finished off a blade on a poplar log today, put a new blade on and started cutting a real nice white oak.   Got two thirds through it and poof, big ole nail.
Starting to think the metal detector idea a good one.  >:(
Peter Drouin
Jim, I get $5.00 each for the cookies, 1" to 2" thick 8"to 14" outside ID.
If bigger the $$ goes up.
A&P saw Mill LLC.
License NH softwood grader.
Brad_bb
caveman, nice Pecan log.  The nails look like my Ash logs!  I'm sure I'll never saw Pecan.  Too far north.
Jim, how does your color coding work?
4x4American
Quote from: Peter Drouin on February 15, 2018, 05:36:37 AM
Some with 2" of slack would be hard to do for sure.
alls what you have to do is calibrate the "kerf" into your noggin-programming and youre all set lol
Boy, back in my day..
caveman
Brad, the pecan belonged to WDH.  Mine was just a fat, metal filled water oak.
Caveman
Dude complained about $2 each for 30 cookies?  What does he think you are, a charity?  You have to wonder how gracious this dude is, probably a Philanthropist who gives away millions to solve World Hunger?
Probably NOT.  These kind of people pith me off.
If you had given them to him and one cracked he probably would have wanted a refund.   ::)
Jim_Rogers
Quote from: Peter Drouin on February 15, 2018, 07:51:13 PM
Thanks for your advice.
Jim Rogers
paul case
I sell logs to a guy who cuts a lot of 12'' cookies and he gets $8 each for 1.5'' x 12'' cookies. He sells thousands of them.
PC
pc
E-Tex
Quote from: Jim_Rogers on February 15, 2018, 05:36:26 PM
Jim Rogers
Jim, how do you use the Color Coding System?
Curious how others us a color system....and/or track "Logs to finish Lumber", if you'd like to keep lumber from the same tree together.?
LT-50 Wide, Nyle 200Pro Kiln, Mahindra 6065, Kubota 97-2 / Forestry Mulcher
L2 Sawmill LLC
Jim_Rogers
Quote from: Brad_bb on February 15, 2018, 09:34:25 PM
When a company asks me to do their trailer decking, I go to the trailer and measure it. I then draw up a plan putting planks in between the steel rails and end them over a rib. I print out the plan and give it to the mechanic who is going to install the decking and he just need to follow the instructions of cutting them to lengths so that they just drop in.
Here is a screen shot of the current job with color coded planks in place:
This company is a major highway paving company in my area. The put down black top (hot top as we call it around here) for highways and streets all over our area.
I have been doing their trailer decking for many years.
Jim Rogers
Jim_Rogers
Here is a shot of the trailer before the new decking:
Jim Rogers
E-Tex
L2 Sawmill LLC
SawyerTed
I was able to take delivery on my my mill this morning!
I have so looked forward to posting something in this thread....
I decided to spend the day practicing on a short red oak log that was destined to be firewood.
SawyerTed
I think I figured out photos as well.  Now to turn them the right way
This may still look like firewood to some of the veterans here but I think it is beautiful!
Roxie
SawyerTed, I sure am happy for you.   8)
Say when
