what would you do with this one?
Started by chief613, January 14, 2015, 03:42:26 PM
chief613
first post, just been listenin for a while. New to sawing
come across this log about 52" on the butt 30' long. I think im gonna have to split it twice for each log. i thought that might be spalting shown in the end grain? only seen it in photos in boards. Is it worth sawing for the lumber, all they seem to want is a couple slabs for table top. what would be some common dimensions to saw, how would i market the lumber, few more pics in gallery
lt40hd
Dave Shepard
Welcome to the Forum! Is that hard maple? It does look like spalting to me.
POSTON WIDEHEAD
Quote from: Dave Shepard on January 14, 2015, 04:02:51 PM
It sure looks like it.
Texas Ranger
Tex beat me to the spring thing, but welcome Chief you will have to prune that  rascal to fit your mill. How far down east are you.?? Frank C.
slider
Welcome Chief.I did a 52 in red oak a while back on my 70 and it was a challenge.I split it once and then set it on the mill with my boom truck.I hope you have some support equipment.Good luck.al
al glenn
Busy Beaver Lumber
This is what I do with them.
Cut spalted wood into pen blanks and dye stabilize in vacuum chamber
These are dyed red
The third, fouth, and fifth pens down are made from dye stabilized wood
This Bracelet assistant is one of my favorites that Mrs. Beaver made from some orange ones i made
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
chief613,welcome to the forum. What part of Maine are you from? Good luck with the log!!
mikeb1079
love those turnings beaver.   :)
from the pics i was curious about how far into the log that spalt is?  seems like some i've sawn like that the fungus was localized to a small pocket right at the butt.  only one way to find out i guess.   8)
homebuilt 16hp mill
Welcome to the Forestry Forum, chief613.
Chuck White
Welcome to the Forestry Forum, Chief613!
I think I'd wait until things warmed up a little before tackling that log!
Privacyleech
dgdrls
Good morning and welcome Chief613,
That will be a dandy project,
What are you sawing with?
look forward to seeing where this project takes you,
Best
DGDrls
johnnyllama
Definitley spalted. I would wait until spring, then decide what length s to use and cut to those lengths. When you make those crosscuts you will be able to better see how far along the spalting has progressed. I'm guessing not that far in a log that size. If it were me, I would hold of sawing for another year to let the spalting move further. Some guys actually cover the maple logs with dead leaves to keep things moist and supposedly speed up the process. I haven't tried that yet but it sounds logical. I've found 2-3 years about right for letting a maple log ( 18-24") spalt to about the right level, lots of spalt but still hard solid wood. Too far and it will get soft and punky. A log that big might be tricky to go too long though. Any idea how long it's been cut as of now?
Turner Bandmill, NH35 tractor, Stihl & Husky misc. saws, Mini-excavator, 24" planer, 8" jointer, tilting shaper, lathe, sliding table saw, widebelt sander, Beautiful hardworking wife, 2 dogs, 2 cats, 23 llamas in training to pull logs!!!
thechknhwk
So that's what they call those nowadays, "bracelet assistant" :-\   :D :D
chief613
its pretty much a now or it goes to firewood log , the log itself is free. It was cut this fall. the spalt seems to run the whole length(end grain pic are from opposite ends), at least its evident on both ends. dont really want to hire some one to truck it, takes a big hunk of the free away. Didnt know if there was enough value in the log to invest cash.
lt40hd
Quote from: thechknhwk on January 15, 2015, 07:11:03 AM
Yeah, I thought it was one of a set of earrings for un-pierced ears.   ::)
Geoff Miller
Spalting will move through the log the same way water and nutrients do, along the length of the log. I cut some black maple logs in March 2014 and coated the ends with latex paint. The logs were milled in mid December. Spalting had initiated at both ends and moved about 12-15 inches through the log,with no evidence of wood degradation. Spalting will eventually move along the entire length but it will take time. If the log is too long, the log ends will be punky by the time the spalt gets to the mid point. One way to get spalting to occur is to cut a fresh log into planks or slabs and then re-stack into log form with a layer of wet leaves/dirt between each board. Wrapping the entire log in plastic will help keep everything moist and speed up the process. That being said, it is still a very hit and miss process. Check the stack every 3 months and add moisture if required. The fungus that causes spalting will die once moisture is removed.
JohnM
Hey Chief, welcome to the forum.  Where abouts in Maine is the log?  I could slab it but if time is an issue it may not work.  Send me a PM if you want to talk about it.  Seems a waste to turn it into firewood (would be wicked nice firewood though! ;D)
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
isawlogs
 It looks very promising in log form, that will be a heavy one to deal with what ever you do with it !   Good find as far as I can tell  8)
   ''bracelet assistant''   I must of had a mirror assistant, as I had its look alike hung from my mirror at one time.....   ;D :D
   Marcel
chief613
got the log moved to my place,in two pieces was all the loader wanted, maybe a bit more. was closer to 20' got an 8 and a 12. thats a 4 foot peavey for reference
lt40hd
samandothers
Welcome Chief!
That will be some kinda pretty!  Look forward to your pictures when you get it split.
woodjunky
Whats all this wait til spring stuff? Be waiting half my life if i waited for spring, up here.:)
Nice looking chunk. Nice and bumpy. Im curious how it will look cut up?  Might get some figured wood from that gnarly chunk. Good luck
Brad_S.
Yikes!
All those bark inclusions will make getting decent boards off the outside rather difficult.
IMHO, if I was still sawing for a living and someone gave me that log, the amount of usable lumber that will come out of that would not be worth the effort involved in extracting it. You will have a lot of knotty, brown lumber and most woodworkers want clear white maple. You will need to find the woodworkers who like "character" lumber. 4/4 and 5/4 lumber were my biggest sellers.
Since time and effort does not equal income for you, it is a moot point what the return will be...I realize you will be going for it!
Best of luck to you!
mesquite buckeye
That would be an  arg-smiley argh  arg-smiley log it were mesquite. Half a day to mill it and might just get pieces of flooring. Also that type of log frequently has rot pockets.
Might be less of a problem with your log. Some logs cost more to cut up than the lumber you get out of them is worth. I've done plenty of them. Those barky seams also will contain grit and will really dull your blades. Might take 4 blades to cut up one log like that. What does that cost?
I'm not saying don't cut it. Just pay attention to your time input, blade expenses and value of what you get out of it at the end and figure out whether you want more logs like that in the future. I think this will be an excellent learning opportunity. ;D
