Author Topic: couple pics... post what your currently cutting  (Read 525130 times)
Offline 1270d
Re: couple pics... post what your currently cutting
« Reply #4600 on: March 27, 2020, 07:41:26 AM »
Lyme Timber out of NH bought out the Weyerhauser and Hancock lands here in the UP over the winter.
The Weyerhauser part has had many names over the last 20 or 25 years.  Mead, MeadWestvaco, Plum Creek, Weyerhauser and  now Lyme.
Same with all the commercial timber holders.  They are kind of a revolving door up here with a name change every 5 to 10 years.
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #4601 on: March 27, 2020, 01:43:04 PM »
Real Estate Investment Trust I believe..
Offline barbender
« Reply #4602 on: March 27, 2020, 01:49:27 PM »
Hey 1270n good to see you here! How have things been in the U.P.?
Offline 1270d
« Reply #4603 on: March 28, 2020, 08:35:07 AM »
Kind of a warm, wet winter but it turned out pretty decent.  We are shut down now with mud, full mills and road postings.
Offline Skeans1
« Reply #4604 on: March 28, 2020, 10:19:39 AM »
A little bit of export thinning of the understory of this 60 year old stand of Doug fir, al is setup for a grapple cat because of the weight of the logs.
1270g h415 Long log thin
Online BargeMonkey
« Reply #4605 on: March 29, 2020, 09:42:31 PM »
Few hours tomorrow and done on this one.
 The problem with a stroker is she LIES to you... 😂 only looks like 5-6 load... keep railing wood up. Had someone stop today and want to buy her, I'm kind of torn, that 320C in Quebec seems nice but boy she is still a good machine.
 Not a bad pile for a weekend. 1,000 full cord in my yard here soon, about 400 right now, wont take long.
Offline barbender
« Reply #4606 on: March 29, 2020, 09:54:45 PM »
Watch out that high voltage line doesn't give you a little spark on the lips😁
Online BargeMonkey
« Reply #4607 on: March 29, 2020, 10:23:51 PM »
 If I got within 30ft of that I wouldn't live to know it. Pictures are hard to tell, that's 200ft up, I couldn't hit it holding a tree with the loader all the way up if I wanted to. 😂
 Had DEC here last week, the problem bear was over in the woods here. Then some local turned me into DEP for smoking the hemlock, guess they aren't happy about seeing the section 8 hood get put in 😂
Offline barbender
« Reply #4608 on: March 29, 2020, 10:51:47 PM »
You get a lot of visitors, it seems😂
Online BargeMonkey
« Reply #4609 on: March 29, 2020, 11:00:49 PM »
The last one was a little tense till we figured out who exactly each other was. See this guy on the hill taking pictures, right now due to the #rona "strapped" is a good way to put it. People cant mind there own business, guy down the road threw a fit when he heard I was cutting the job. Hammered 😂🤘
Offline treemuncher
  • Committed vegetation terrorist since 1997
    • TreeMuncher.com
« Reply #4610 on: March 30, 2020, 12:15:40 AM »
I cut a bunch of these larger trees before I mulched them up. I guess that counts as to "what I'm currently cutting?"
I had a short little clearing job for a sewer right of way this past week. Lots of heavy growth in this one section with some big maples, gums and poplars. Numerous trees 20"+ that were in the corridor. It was wet and nasty at the start but getting the air flowing through it helped dry it out much faster. It's a shame I can't find someone to carry off the decent logs rather than me doing the magic show and making them disappear into thin air. But then the mulch does stop any erosion until the digging begins.
Smaller trees and easy drops already taken out by this first pic. I got a little more air flowing to start drying out the 12"-24" of mud I was dealing with in this section.
I used the saw to get the precision drops made. This poplar was the biggest in the bunch. 28" bar for reference.
After my magic show is completed, everything has disappeared. The prime contractor can now start digging when ever time and conditions suit them to do so. Meanwhile, the airflow and sunlight will aid them to a faster drying time after rainfalls.
TreeMuncher.com  Where only the chosen remain standing
Offline ljohnsaw
« Reply #4611 on: March 30, 2020, 02:08:04 AM »
Do you just grind the stumps down as well?  So they have a little surprise waiting for them when they start to trench? ;)
John Sawicky
Offline nativewolf
« Reply #4612 on: March 30, 2020, 05:32:18 AM »
@treemuncher - nice to see a real mulcher on here.  What sort of machine/heads are you running?  We're owned a FAE mulcher/subsoiler but sold it, my carrier was just too small (220HP case magnum tractor).  We're interested in a purpose built machine but it may be a while yet.
Liking Walnut
Offline treemuncher
    • TreeMuncher.com
« Reply #4613 on: March 30, 2020, 08:53:38 AM »
Stumps have been chipped down to grade and usually 1" or so below if the surrounding material is soft, like this mud was. The remains of the stump is still there. However, when they do start cutting the trench, they will find that the stumps will break apart much easier as stump cores are rarely more that 8"-12" deep into the soil below area grade. If it is hit at an angle with a dozer blade or pulled from the edges with a Tiger Tooth on a bucket, the stumps will break into pieces fast and easy. Once in pieces, the remaining dirt can be knocked off easier, too.
I expect them to excavate all of this with track hoes. Stumps won't be an issue for them.
Nativewolf: It's a Lamtrac with an FAE head. Factory, it was just under 300 hp. I'll bet money that the engine was tuned prior to my purchase. It pulls better than my Barko 937 most of the time. I just wish it had the float that the Barko has for hidden stumps. I did a major retrofit on the carrier arm to head connection so that the head will contour up to 20 degrees offset from the carrier. It contours the grade exceptionally well and puts much less stress on the carrier with this modification. That allows me to cut lower and leave a better finish quality on my cuts.
This is what the job looked like before I started my cut. You might be able to see some of the flagging marking my boundaries.
Offline dustintheblood
  • Home in the woods
« Reply #4614 on: April 03, 2020, 08:42:30 PM »
We are just coming off of syrup season and into mud season, so not much cutting going on here for a bit.
Isolation for us is pretty much status quo compared to any other year.
Evenings I have been watching more of the youtubes than usual, and admit I've seen things I shouldn't.  For example, this fine bozo example of exactly everything one shouldn't do as a "cutter":
Case 75C, Case 1494, RangeRoad RR10T36, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln
  • Home in the woods
« Reply #4615 on: April 03, 2020, 08:44:22 PM »
Perhaps we make this a game to see who can get the highest count of mistakes, dumb moves, safety infractions, environmental messes etc. that we can tally.   lol lol lol
Offline thecfarm
« Reply #4616 on: April 04, 2020, 06:13:23 AM »
At least he used the chain break.  :D
I have been around a few that was never around someone that knew how to cut trees.  :o  I showed them a few things.
  • Home in the woods
« Reply #4617 on: April 04, 2020, 08:30:09 AM »
You mean the brake for the chain that was so loose it's about to spin off?   :D :D :D
Online BargeMonkey
« Reply #4618 on: April 08, 2020, 10:58:41 PM »
 Just keep slamming up piles of firewood and pulpwood, forget about cutting good logs 😂
 Finish one job, onto the next.
 Theres a set of 30' steel bridges local, trying to get the guy to sell them, at the point they would be handy.
 I knew when I backed in this wasnt going to be good, slid off making the turn in and started to sink, tried getting out and I was done for. Broke a spring but lucky I didnt do worse, without my legs down she really LEANED over.
 Cant win them all, why I try and avoid selling loglength wood to most people and only feed processors.
Offline Skeans1
« Reply #4619 on: April 08, 2020, 11:21:37 PM »
A few on the larger end of the small export size on the butt we can send depending on the sort.
Started by Brian w on General Board
Last post January 01, 2019, 05:27:50 PM
by dustyjay
First post and a couple of questions
Started by peter nap on Ask The Forester
Last post December 05, 2007, 06:24:18 PM
by Jeff
first post and a couple of questions
Started by billy_wizz on Timber Framing/Log construction
Last post November 15, 2014, 10:18:25 AM
by Heartwood
couple o' more pics
Started by kra on Sawmills and Milling
Last post March 21, 2004, 10:37:40 AM
by Fla._Deadheader
