Author Topic: Small 7 acre homeowner needs advice on felling Long Leaf Pine...  (Read 2429 times)
Offline Claybraker
  • Mostly New!
Re: Small 7 acre homeowner needs advice on felling Long Leaf Pine...
« Reply #20 on: February 08, 2015, 11:37:19 AM »
I am looking for some ideas on how to use the bases of other big pine trees in the area to cable pull the fallen logs to the portable sawmill. I might rent a 4-wheel drive fork lift for a week if needed but we will have to see.
I plan on using every inch of the trees that I cut down.
Just a brain flatulence, but Pinova in Brunswick buys Longleaf stumps. It might be worthwhile to bring in a dozer and push the trees down. They take the stumps, you keep the trunks. The economics may not work out, but it's something to consider. Worst case scenario, you push the trees over, in a few years you have an unlimited supply of fat lighter.
http://www.pinovasolutions.com/pinova
Offline crosscut
  • foley belsaw and lt40 super with 25 foot extension
« Reply #21 on: February 12, 2015, 07:23:01 PM »
Also dont take down more trees than you can process quickly. Here in central fl bugs pretty much much keep on chewing wood all year. round do them all at once you going to need to peel them and get them off the ground either that or aquire a taste for the rustic bug kill look . The ones i drag in in the summer will start getting borers in them within a couple of weeks if left in piles on the ground.
The Long Leaf Pine
Started by Tom on Tree, Plant and Wood I.D.
Last post March 22, 2007, 10:03:14 AM
by TexasTimbers
Jeff's pet Long Leaf Pine
Started by Tom on The Outdoor Board
Last post April 10, 2007, 09:30:34 AM
by Jeff
need advice on purchasing/processing of log length firewood for homeowner
Started by peterc38 on Urban and Community Forestry
Last post February 04, 2010, 12:14:35 AM
by steveforest
homeowner seeking advice about large black walnut tree on property
Started by johnk on Ask The Forester
Last post January 16, 2020, 10:33:25 PM
by Old Greenhorn
