My next question in my quest to buy a mill - need input from Wood Mizer owners
Started by Southside, February 18, 2015, 01:58:00 PM
Southside
Well, the mill search continues.  Strange how small of a world it is sometimes.  The vet we go to is married to a cabinet maker, he and I have talked in the past about logging and mills as he has a band mill of his own.  I could not remember what he had so when I saw him I asked him if he still had his mill, to which he sarcastically asked if I wanted to buy it.  When I told him I was looking to buy one he stopped dead in his tracks and had the funniest look on his face.  Turns out he has had his eye on a newer / faster mill and was going to sell his.  I am going to look at it Thursday but from what he described he is the second owner, still works with the original owner who upgraded, and it has not been abused at all, said it cuts straight and true.  1994 or 1995 vintage Wood Mizer LT 40 hydraulic.  It does not have roller toe boards, a de-barker, or setworks.
I called Wood Mizer and they said the new style de-barker would work on this mill, just have to drill holes in the tubing for the mounting bolts.  A roller toe board could be adapted to work on one but a setworks was not an option at all.  The tech explained that the mounting plate for the control unit was different and the gear box for the encoder was different.   Having never looked in detail at either a post or pre '97 mill I really don't have a reference to what he is talking about.
So, I guess what I am asking is are there any members who have figured out how to overcome the setworks issue?  I am guessing an adapter plate similar to what one would do when mounting a non OEM engine would solve the mounting issue, but I don't understand how the encoder is being attached and what rotations it is counting.  Are there alternative locations on where to mount the encoder?
Are there traditional areas on this mill to look at for wear or failure?  Any input or advice is very much welcomed.
On a different note when I called Wood Mizer they could not find the owners name in their database, but at lest so far the local SWAT team has not pulled into my driveway!  :D
White Oak Meadows
Ocklawahaboy
Woodmizer will only have a 2nd owners name if he registered when he bought the mill.
There are many LT40's sawing every day that do not have any setworks.  The good thing is that if you decide to buy and then "upsize" later, the LT40 will hold it's value quite nicely.
I do not know the $$ figures that you are dealing with, but have you checked the "For Sale" board here on the FF?
Chuck White
Good to hear you're thinking of getting a mill!
My mill is a 1995 LT40HDG2425.  In other words I removed the 24hp Onan (the original engine) and replaced it with a 25hp Kohler.
The engine replacement wasn't due to engine failure, in fact the engine was running and sawing right up to the last hour before the engine swap took place, it only had 2206 hours on it.
I did the engine swap simply because I was money ahead and just decided to go ahead with it.
The only worn parts I've replaced were the engine mounting bushings and some belts.
I have a debarker (added by the 2nd owner) on my mill and I feel that the debarker is a fine investment!
As Magicman stated the LT40 will hold it's value very well.
I've had my mill since 2008 and I would not sell it for the same price I paid for it, it's worth more than that with the upkeep and improvements I've made on it.
Southside
Thanks Chuck,
Just trying to understand all the parameters here.  What would you say a "typical" or average day production is with your mill - mind you I completely understand there is no average log, I see it every day.  Just trying to evaluate how far any purchase I make will take me for the $$ I spend in the event I am able to actually make this into more of a profit generating business.
Magicman thank you, yes I have been keeping an eye on that section.  If this close one is not the mill for me I will be making a trip or two based on what is there.
Jim
White Oak Meadows
Southside
Chuck,
Also wanted to ask what you think of the lap sider.  This mill comes with one and I have an old farm house that is desperately in need of a face lift, new siding would be easier than dealing with what is on it now believe it or not.
White Oak Meadows
pineywoods
If you can get it at a good price, I'd say go for it. It will have either an onan or a briggs and stratton powerplant. Both are out of production, but are good engines, should be good for 5000 hours or so. Engine swaps are a breeze. I swapped out the briggs on my 95 for a kawasaki, was back sawing the next day. Toe rollers would be pretty much a bolt-on option. Setworks can be a little confusing. The original was called accuset I, no longer supported. Current is accuset II, which would be difficult to retrofit to a 95. There is a third option called simpleset, not quite as sophisticated, but still nice. I would ask, do you really need setworks? The saw scale on that mill has an inch scale with fractions plus 6 more adjustable scales. As long as I use one of those 6 preset thicknesses, I can saw just as fast as with setworks, no math involved. And yes it's easy to set up to let's say, cut 5/4 boards down to a 7 inch cross tie. There's one thing I didn't like about mine, that's the SLOOOOW head up down speed. I came up with a simple fix for that. Some will bad mouth the pre-97 frame, yes the later models are beefed up a bit, but the older frames were pretty rugged to start with. I saw hardwood as big as 36 inch by 20 long and I ain't bent or broke anything yet...
Chuck White
SSL; On an average job, I will usually turn out 1,500-1,800 bf in a day, with a decent off-bearer.
My day of actual sawing usually starts at 8:30 and ends at 4:00-4:30.
I like the idea of having the Shingle & Lap Sider, even though I haven't used it yet!
They are running around $1,200.00 new, now!
uler3161
That should be a good mill if you can get it for the right price.
I'm tempted to agree with pineywoods about not needing the setworks, but I should mention one thing... I'm pretty sure in this year of mill, you're height control is only a drum switch. Older mills had the gearbox pulley exposed so you could fine adjust, but this one probably has that all enclosed. We have a friend whose first mill was like this and he was constantly battling with going up/down to "hit his mark". Whereas on our mills, the standard operating procedure was to lower the head close to the cut, then roll the pulley with your hand to get it right on. I suppose WM changed this due to safety concerns. With practice you might could get to where you can run the height controls on this mill pretty well, but to be honest if I had to choose between an older mill with the exposed pulley versus this one, I'd choose the exposed pulley.
Frame wise, without some serious fab work you're going to miss out on being able to upgrade to a 2-plane clamp. That's the only real complaint I have about my mill.
1989 LT40HD, WoodMaster 718
Dan
4x4American
I have crossed paths with a few folks who have lt 40's without setworks.  Computerized setworks are fairly recent.  It would not be a deal breaker for me.  The fact that you can add a mudsaw is great.  Go onto the youtube, there's a video called what to look for in a used woodmizer (or something along them lines) by videos by al (I believe).  Pretty sure he is a forum member here. He is the sawyer in most of the Lindas Sawmill Cinema videos from what I gather.  Anyways, worth the time.  You are around equipment, so you can generally see what condition it is in.  You know the owner too, which is an advantage.  Try to get some blades with it too, and any spare parts he might have.  Good luck, and let us know!
Boy, back in my day..
4x4American
This mill is still light years ahead of some of the other mills you were looking at, no?
Much depends upon the sawmill's planned usage.  I would hate to think about sawing production without my Setworks and Debarker.  Those plus a few more options.
Bells & whistles do much more than just make noise.   ;D
pineywoods
The simpleset could be adapted to the older mills, but you would most likely have to change out the up-down gearbox. The gear ratio is most likely different. The transducer is an optical unit that fits on the end of the gearbox input shaft, counts revolutions. There's a cheat to stop the head on the mark. Don't try to stop on the mark. Deliberately drop a little below and then jog up, much easier. I added a couple (well actually 4) garage door springs to take some of the head weight off the up-down motor. Makes a big difference. Uler, you are right on about the 2 plane clamp. that is one very nice option. I sorta cheated. My mill WAS all manual, now has full set of pinewoods hydraulics. The turner/clamp is ALMOST as good as the wm 2 plane and doesn't require butchering the frame...
Darrel
I have a 1992 LT40HDG24 and I find that running the mill without set works is no big deal.  There is an excellent scale on the mill that is calibrated to 4, 6, & 8 quarter. As well as a regular rule with 1/16th inch lines on it. It didn't take long for me to master the skill to hit the down leaver and then release it so it stopped exactly where I wanted it to. This was a concern I had before I bought my mill last summer, but my worries were unfounded.
1992 LT40HD
WH_Conley
I keep a roll of masking tape around the mill. If someone wants an order of special thickness, say 1/2 inch I will put the tape on the scale and mark every 9/16 inch. Don't do any math that way.
Bill
Chuck White
You'll find that you can get by with what you have!
Personally, I wouldn't be without the debarker!
Southside
@pineywoods do you have any photos of the spring and clamp assembly you built? What is different about the single plane system?
I am quite certain the machine will not be the weak link in the chain here, I have a whole lot to learn when it comes to milling.
White Oak Meadows
Dave Shepard
Quote from: WH_Conley on February 19, 2015, 12:48:43 AM
Neat trick!
I learned on a '93 LT40 Manual. You can hit the mark no problem with this mill. I would drop below the mark and bump up to it. After some time on the mill, I could just about hit the mark without looking. I wouldn't be too worried about no setworks on this vintage mill.
barbender
If the setworks and other options are important to you, I would wait and find a mill that has them already installed. On my LT40 super, the head up/down is so fast that it is hard to land on the mark, and that costs you time. The setworks incorporate some kind of electronic braking to land on the mark, and that is the real time saver for me. If the head didn't move so fast, it wouldn't be as big of an issue.
     Piney, the encoder on my original setworks is not optical, it is a sprocket driven encoder that could likely be incorporated into older mills if it was still supported. Maybe the simple set is similar?
MAI
I've never operated a mill but the info on this thread just keeps rolling.
pineywoods
Barbender, the encoder on your accuset I is a magnetic pickup driven off a sproken that rides the up-down chain. Simpleset is completely different. It's encoder is a slotted disk that fastens to the v belt pulley on the input shaft for the up-down gearbox. The pickup is optical, enclosed to keep sawdust out.
If my mill had the old flap type clamp, I would retire the clamp mechanism to the spare parts box, then replace the big springs on the turner with a hydraulic cylinder. Then you can jam the claw into the side of the log/clamp and use that for a clamp. I designed the pineywoods turner/clamp to work that way. Not quite as nice as the wm 2 plane clamp, but close. Pics, videos and drawings here
https://forestryforum.com/board/index.php/topic,39860.0.html
barbender
Thanks for the info, Piney- I haven't gotten a chance to look at the simple set on the newer mills.
pineywoods
Quote from: Southside logger on February 19, 2015, 07:28:57 AM
Here's a link to the post about the spring assist for head up....
https://forestryforum.com/board/index.php/topic,27272.msg391022.html#msg391022
hunz
Not sure if you are married, but I am, so I thought I would share the one thing my wife has been right about....well that's up for debate. I am on my 3rd mill in 5 years, now with a lt-40 super. "I don't wan't you buying something that isn't what you need, or something you need to fix to make work the way you want it, just buy the right thing the first time" My wife has never been more right with that statement, at least that's what I have found! My problem is that I love to tinker, and make things work so to speak. I always love a challenge to fabricate, and see my idea work; this is the way I am. But..... just because it's how I am, doesn't make it the best decision. A 98+ mill would make your life a lot easier, for not much more $. Just my thoughts
Dream as if you'll saw forever; saw as if you'll die today.
2006 Woodmizer LT40D51RA, Husqvarna 372xp, Takeuchi TL140
Chuck White
Here are a couple of pics of the Pineywoods lift assist I put together.
