We have contest winners!
I'd have to admit how little I know about chainsaws, so please be kind to this chainsaw neophyte.
If you don't think the length of a chain changes over its life, measure one brand new, then one that has been well used and is nearing the end of its life. In fact, compare one that is new to one that has only been used enough to require a couple of sharpenings. Even if it's the same brand an model of chain, you'll see a noticeable difference - and it's not just on "abused" chains or ones that were run dull. The change is more likely due to parts wearing and rivets "seating" than metal actually "stretching", but the difference is there. From what I've heard, it's less noticeable on Stihl chains, but not having checked one out myself, I can't say for sure.
Chains stretch very little, things wear. Don't overlook the sprocket that drives the chain, it wears, and if it's about gone makes for slack in the chain. If you install a chain that doesn't quite match the worn teeth on the sprocket, the two will quickly wear to a fit, leaving the chain loose...
Started by Philbert on Chainsaws
Started by KPSTIHLSAW on Chainsaws
Started by Magicman on Technical Support Topics
Started by bandmiller2 on General Woodworking
