Author Topic: Great tool to clean Heat Exchangers on Central Boiler  (Read 760 times)
Offline Bob Lentz
    • Back40Ranch
« on: March 13, 2015, 05:44:11 PM »
Guys, i modified a Scuffle Hoe. Just cut the two clamps that hold the stirrup at an agle so you can separate the stirrup from the clamps. Next, remove the clamps from the pole. Now drill a hole in the middle of the stirrup and re-attach it to the end of the wood pole using  a large lag bolt.   Now the tool will fit in between the HEXs and you can scrape them clean.
eClassic-2400
Triangle Tube Backup (Propane)
Heating 6500 sqft house and small pool
like to add heat to my new sunroom using my central boiler. looking for ideas.
Started by adamant on Firewood and Wood Heating
Last post April 06, 2014, 12:53:23 AM
by Local4Fitter
Central Boiler Hot Water Heat Exchanger - NEW
Started by DR_Buck on For Sale
Last post August 09, 2019, 07:26:19 PM
by DR_Buck
Hot water Plate heat exchangers
Started by Viperman on Firewood and Wood Heating
Last post January 18, 2019, 02:14:18 PM
by hedgerow
Central Boiler issues - heat exchanger not heating up?
Started by Kemper on Firewood and Wood Heating
Last post November 12, 2019, 12:04:43 AM
by Kemper
