Author Topic: john deere 648 e  (Read 1948 times)
Offline barniescamp
john deere 648 e
« on: March 13, 2015, 10:46:33 PM »
Just a question maybe someone knows on here, on the axles of my john deere 648e grapple skidder there are grease zerks (nipples) at the axle ends, how much grease is supposed to go into these zerks ???? would just like to know if theres a specific amount that should be put in or just a couple pumps of the grease gun each grease period. My 540e had them also so i presume all the john deere skidders have em.
Offline BargeMonkey
Re: john deere 648 e
« Reply #1 on: March 13, 2015, 11:49:21 PM »
   :D  3 or 4 whole tubes every 8hr shift.  :D   5-6 pumps max is what i put in my 440D every 10-12hrs, do not over grease those bearing or you will blow the seal out and be pulling an axle down.
Offline teakwood
  • Switzerland
« Reply #2 on: March 14, 2015, 07:54:34 AM »
Thats way to much! I put 3 pumps every week (shafts and pivot 1-2 pump every week) That grease wont go anyway on this bearing as it turns very slowly. you just fill up the axle housing with grease or blow out the seal if you put too much in it. On my excavator i grease daily because the pins and bushings work very hard, but just 2pumps per nipple. people tend to overgrease stuff. put 5 to 6 pumps in the universal joints on a fast spinning winch shaft and that grease will fly all over you skidder. nasty
Offline snowstorm
« Reply #3 on: March 14, 2015, 08:18:01 AM »
my valmet has a jd axle on front i grease it every 50hr or so. on the old 440 a and b the tek manual said grease it until grease appears
Offline BargeMonkey
« Reply #4 on: March 14, 2015, 09:31:15 AM »
 Ive always went with 4-5 pumps every other time i grease the centers and with almost 12k hours i havent lost a seal yet.
Offline Oliver05262
« Reply #5 on: March 14, 2015, 10:34:13 AM »
   Probably all the answers are correct in some way. The inner bearings on the axles are in oil, and there is a seal just outboard of them that keeps the oil inside. The outer axle bearings are grease lubed. They are usually packed when installed, and then regular greasing replaces the small amount that gets squeezed out, and also helps form a dam that keeps water from entering. That's the grease that you'll see on the outside. Some more of the extra just puddles in the tube.
  Farm tractors came with a plug in that location that was to be replaced by a fitting and greased at some long forgotten interval. I've worked on 40 year old 3020 and 4020's that have never had that plug taken out!! Others have got a peck of grease put in them over the years with no apparent damage.
  The big problem on JD farm tractors is bale twine, especially long pieces from round bales, getting wound around the axle and destroying the outer seal. To an extent, tall grasses can do this too. It's not usually a problem in the woods, and skidders have a little more outboard protection for the seal. Once water can enter, dirt and rust can wreck the outer bearing.
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
Offline kiko
« Reply #6 on: March 14, 2015, 11:33:35 AM »
My  service literature calls for 4 pumps every 8 hours of operation in mud and water and 4 pumps every 50 hours absent heavy mud and water.
Offline teakwood
  • Switzerland
« Reply #7 on: March 15, 2015, 08:56:51 AM »
X2 on that! smiley_thumbsup
john deere 350
Started by 4430jd on Forestry and Logging
Last post June 01, 2015, 06:12:46 PM
by beenthere
John deere 350
Started by 4430jd on General Board
Last post June 01, 2015, 09:57:34 PM
by sharp edge
John Deere 540 BC
Started by Nemologger on Forestry and Logging
Last post June 22, 2013, 03:25:53 PM
by beenthere
exclamation
John Deere 50v
Started by AtLast on Chainsaws
Last post November 10, 2003, 10:11:00 AM
by Gus
