rebuilding Clark torque converter
Started by rockwall, March 27, 2015, 11:27:03 AM
rockwall
treeslayer2003
maybe you can blow it up.........i have all the numbers as well but they are the old numbers. still, some times it helps to see it all.
rockwall
I got looking at my radiator and it could use some work so I think I will pull that out and then pull the motor with converter attached so I can rebuild the converter and put in new fiber gear. Does the canopy need to come off to get the radiator out? Or what is the best way to get radiator out?
rick f
Rockwall, I know the radiator will come out without taking the front off but I think to pull the motor you will have to take the nose piece off. the canopy can stay on , at least it did for my buddy's.
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
5040 kubota farm tractor
treeslayer2003
take the nose section off, its only four bolts and makes it much easier.
rockwall
rockwall
Thanks to all who replied with help. I successfully pulled the 353 and torque converter out of my clark ranger. I couldn't have done it without your help.
rick f
Rockwall how about some pictures of the torque converter rebuild as you go throught it?
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
rockwall
Well I finally got the motor and torque converter back in the skidder. While it was out I got to do all kinds of maintenance to the old girl, new hoses, gauges and hoed out four boxes of crud from under the motor. Unfortunately, while putting it back in we broke a piece of the port on the oil cooler. I'd really like to put the machine all back together without taking the oil cooler out. Do you have any suggestions for making that broken port work. There is a half inch left on the port with the broken side. Hopefully the photo shows it clearly.
North River Energy
Maybe bond a sleeve into the bore, then 'glue' in the broken chunk(s) using the sleeve as a backer?
rockwall
What would you recommend for a sleeve?
North River Energy
How close is that ID to the OD of a piece of common copper pipe?
treeslayer2003
dang it! that sucs rockwall.........that oil cooler is a common leak on these, it may not be a bad idea to pull it and regasket. if you do, pressure test the cooler while its out with air and a bucket of water.
rockwall
North River Energy
If you were closer, I'd chuck a chunk of 1-1/4 black water pipe in the lathe and turn one for you. (OD measures just proud of 1-5/8).
Maybe head over to your nearest hardware outlet with a measuring device and see if you can find something close? Doesn't have to be metal, just needs to fit, stick to JB Weld or similar, and deal with the heat/ coolant.
Or, you can pull the assembly, and braze it back together.
rockwall
Holmes
  An 1 1/4 " copper coupling is just a fraction over 11/2 inch.  That would fit in with JB weld
Think like a farmer.
rockwall
Thanks Holmes! I slipped a 1 1/4 copper union in the port and it seems a little loose. I might want a tighter fit.
Holmes
   11/2" tubular brass pipe [ kitchen sink drain pipe under the basket strainer ] is about 1/32" bigger.  Thats as close as I can get unless you lathe down to size a piece of 11/4" steel pipe.
rockwall
Thanks again for your thoughts and time.
rockwall
Thanks to all the help from you guys I fired up the 664 yesterday. I needed all the help I could get and by searching and reading old posts I was able to get her going again. While I had it apart I had a great mechanic put a seal kit in the torque converter, a new fiber gear, rebuilt the TC pressure relief valve and a new rear main seal. I also got to clean and fix up the radiator which needed it badly. It didn't want to turn over at first but I found a loose nut from the starter case to solenoid, tightened that up and she fired up after getting all the air out of the lines. It was really helpful to have this forum to come to. I will try and post some photos.
rockwall
Some photos
krusty
I know this is an old thread but I have a C272 in an old Michigan loader I was going to take out to the woods. I believe the torque converter needs love. How hard it is to put new seals and the fiber disk in? Anyone have contact info for oldseabee as I have heard he is the guru. My machine will drive fine pushing no load but as soon as it encounters a load to scoop up, the output of the torque converter stops spinning.
