Author Topic: Timberjack 230d  (Read 646 times)
Offline Cov1adam
Timberjack 230d
« on: March 30, 2015, 04:28:23 PM »
Need some help I have a timberjack 230d and it has started to make a grinding noise when under a load. Seems like it is coming from the box that controls your foward and reverse any suggestions???
Offline Maine logger88
  • Don't force it get a bigger hammer
Re: Timberjack 230d
« Reply #1 on: March 30, 2015, 05:12:00 PM »
Have you checked the oil in it? If it was low or got thin from to much water it could do that. It also could be a bearing starting to go
Offline Cov1adam
Re: Timberjack 230d
« Reply #2 on: March 30, 2015, 06:56:55 PM »
Yes I changed all the fluids a few months ago when I bought it but I will check it again tomorrow for water. Thanks do you know if there is a problem can it be fixed through the top plate or does the whole box have to be removed from the machine?
Re: Timberjack 230d
« Reply #3 on: March 30, 2015, 07:08:30 PM »
If it's a bearing you will have to take it out but it might not hurt to drain the fluid and take the top cover off to see if you can see anything
Re: Timberjack 230d
« Reply #4 on: March 30, 2015, 07:09:17 PM »
Welcome to the forum BTW!
Offline Cov1adam
Re: Timberjack 230d
« Reply #5 on: March 30, 2015, 07:11:20 PM »
Ok thanks it seems to slip when it does make that grinding noise But it doesn't do it constantly so I'll check it tomorrow
Re: Timberjack 230d
« Reply #6 on: March 30, 2015, 07:55:06 PM »
If it's slipping that sounds like the clutch to me
Timberjack 230d
Started by Cov1adam on Forestry and Logging
Last post March 31, 2015, 09:42:12 PM
by Mooseknuckle
Timberjack 230D
Started by Upnorth on Forestry and Logging
Last post November 29, 2016, 10:47:33 PM
by Mountain_d
TimberJack 230D Help Required.
Started by Chris2484 on Forestry and Logging
Last post August 01, 2015, 10:48:10 PM
by Mooseknuckle
230D timberjack project
Started by ilog4u2 on Forestry and Logging
Last post August 27, 2016, 02:58:29 PM
by danbuendgen
