BLUECREEPER Poster Award #4!
CaseyK, Yes the motors are 24 volt wheelchair motors but I removed the brakes. I needed to mount encoders on the motors for feedback to the controller. The controller accepts commands from a PC or microcomputer and then tells the motor drive what position to go to and at what speed. It also keeps track of where the motor is by way of the encoder feedback. The controller is called a Kangaroo and the PWM motor drive is called a Sabertooth. The drive and controller takes care of two motors. They were engineered for robots (as in robot wars). They are sold by Dimension Engineering.I assembled a remote control using the two 12 channel remote transmitters so I now have a 24 channel RF remote. When I finish up the microcomputer program and get the motor controller tuned I will be able to run the bandsaw from the remote.I uploaded a few more pictures today so I'll post them. (Image hidden from quote, click to view.) This is my diesel drip band lube. It is applied via a felt wick. (Image hidden from quote, click to view.) I also have a water lube/coolant system using the same felt wick. (Image hidden from quote, click to view.) You can see the two tubes coming down from above. I just hook up which one I want to use. The felt wick wets both sides of the band. (Image hidden from quote, click to view.)This is a shot from under the band carriage. You can see the linear positioner for the engine v belts tensioner.(Image hidden from quote, click to view.)I was concerned that my carriage might tip over so I made some brackets that hook under the rails.vfauto, The next three pictures and a drawing will show how my log stops work. (Image hidden from quote, click to view.) (Image hidden from quote, click to view.)(Image hidden from quote, click to view.)
Started by JoeyLowe on Sawmills and Milling
Started by DR_Buck on Sawmills and Milling
Started by Dan_Shade on General Board
Started by customsawyer on Sawmills and Milling
