Author Topic: Processor rate versus Forwarder rate  (Read 1090 times)
Offline deastman
« on: April 20, 2015, 04:42:29 PM »
Let's say on a $20/ton rate to process and forward 16' to 24' pulp, what do some of you C-T-L guys figure for a percentage of that rate for the processor  versus the forwarder?  50/50, 60/40 etc
Samsung 130 LCM-3 with Fabtek 4-roller and Cat 554 forwarder, Cat EL 180 excavator, Cat D3C dozer, Cat D7E dozer, '92 Ford LTL 9000 dump, Easy-2-Load 25 Ton tag-a-long, current project under construction: '91 Peterbilt 379 with a Hood 8000 w/extenda-boom loader
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: Processor rate versus Forwarder rate
« Reply #1 on: April 20, 2015, 05:41:04 PM »
Never thought about it but the harvester seems to be the all around more expensive of the two machines to run.  I'd think 70-30 with 70% for the processor  :-\  Maybe  ??? :)
Offline wannaergo
  • Work while I'm young, sleep when I'm dead!
« Reply #2 on: April 20, 2015, 06:18:02 PM »
There is a couple guys around my area that work together but separate. They each own one machine. I think they found the numbers to be at 63/37.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
Offline deastman
« Reply #3 on: April 20, 2015, 06:40:38 PM »
That's the same as I was thinking.  The processor has to do a lot more work per cord than the forwarder does and my forwarder can usually yard a little more than I can process in a day in average conditions. Thinking about adding a subcontractor with a processor to help increase production this year but then that might be too much for my forwarder to keep up with and then I would need to find a bigger forwarder. Always seems to be a vicious circle trying to balance out production with what equipment you have versus how much more you could produce if you added more or bigger equipment
Offline 1270d
« Reply #4 on: April 20, 2015, 08:09:50 PM »
I've heard forwarder work time should be around 2/3 harvester time.
Offline Jamie_C
« Reply #5 on: April 20, 2015, 08:29:06 PM »
Around here the processor rate per tonne is generally double the forwarder rate per tonne.
Cutting rate for forwarder and sawyer
Started by MattR on Forestry and Logging
Last post February 08, 2020, 08:20:23 AM
by Cub
Different rate for ERC?
Started by NCDiesel on Sawmills and Milling
Last post February 28, 2014, 01:22:50 PM
by Cedarman
Going Rate?
Started by dail_h on Drying and Processing
Last post November 09, 2005, 06:25:28 AM
by FeltzE
Going Rate?
Started by Kirk_Allen on General Board
Last post January 07, 2004, 05:26:01 PM
by Kirk_Allen
