Author Topic: No hot start  (Read 2495 times)
Offline Beweller
No hot start
« on: September 06, 2004, 09:35:41 AM »
I have a Stihl 009 that will not start when hot.  It has been to the shop twice and returned "fixed".  I don't think the shop ever sees the problem.  It occurs only when the saw is hot and has been shut off for more than a few minutes.  Then may be over an hour before it will again start.  Any one encountered this problem?  Thanks
Beweller
Offline Dean Hylton
    • Washington Hot Saws
Re: No hot start
« Reply #1 on: September 06, 2004, 12:38:42 PM »
What you have is most likely a coil that needs to be replaced. You have a break in the internal wire of the coil. As the coil heats up the gap is widened and you loose spark.
Offline Beweller
Re: No hot start
« Reply #2 on: September 07, 2004, 10:43:43 AM »
Dosen't seem likely.  If the saw is shut down for only a minute it hot restarts OK.  But if for several minutes, then no restart intil it cools.
I have checked and there is a spark during the refractory period.  Maybe weak, I don't know what it is supposed to look like.
Thanks for the suggestion.
Beweller
Re: No hot start
« Reply #3 on: September 07, 2004, 12:32:57 PM »
I don't have an answer, but, my Husky 61 will do that every once in a while.  I have always attributed it to a vapor lock.  After about 20 minutes of sitting, it will crank right up.
The only other cranking problem I have had, I found, was a too long fuel line. I had the line replaced along with some other maintenance and found, after turning the air blue a few times, that the filter couldn't "freely move" in the tank.  I shortened it a smidgeon and everything was hunky-dory. ;D :)
Offline Kevin
Re: No hot start
« Reply #4 on: September 07, 2004, 06:12:15 PM »
Does your saw tend to stall out at idle but operate normal at high speed?
You should have a bright blue spark.
Offline Beweller
Re: No hot start
« Reply #5 on: September 08, 2004, 09:04:04 AM »
Runs fine at idle and full throttle.
I would not call the spark I saw hot and blue.  But of course I was looking at it in full daylight.
Beweller
Offline Beweller
Re: No hot start
« Reply #6 on: September 14, 2004, 03:46:16 PM »
I was pretty sure the trouble had to be some sort of vapor lock.  Only thing I could come up with that seemed to fit all the symptoms.
But because it was easy, I tried replacing the spark plug.  Amazing!  The saw starts fine, hot or cold, including hot after a short rest.
I can't find anything wrong with the old plug.  Huh.
Thanks all.
Beweller
Offline Minnesota_boy
  • Some like 'em short, but I prefer looong!
Re: No hot start
« Reply #7 on: September 18, 2004, 08:03:32 AM »
I worked in a saw shop for a while and that problem with not starting hot was a tough one for the shop man to diagnose.  I had no where to test the saw long enough to get it real hot.  I did find that replacing the plug was a good place to start though.  ;D
Offline sawguy21
Re: No hot start
« Reply #8 on: September 20, 2004, 09:49:04 PM »
Beweller, was the plug a Champion? I find them very inconsistent. Bosch and NGK are much more reliable
Offline Beweller
Re: No hot start
« Reply #9 on: September 21, 2004, 07:06:35 PM »
The troublesome plug was an Autolite.  I replaced it with a Champion, the only replacement I could find in three stops.
I was trying for the Bosch, but none of the three carried them.
Beweller
Online SwampDonkey
  • Forester
  • Large Tooth
Re: No hot start
« Reply #10 on: September 26, 2004, 01:01:04 PM »
The Stihl shop recommends Bosch plugs for their FS450 thinning saw I know.
cheers
Move'n on.
Offline james
  • truck drivin fool
Re: No hot start
« Reply #11 on: September 28, 2004, 06:51:22 PM »
one verry good way to test for spark is to gold the bare plug wire in your hand and crank the saw ;D ;D
Offline Ianab
Re: No hot start
« Reply #12 on: September 28, 2004, 08:50:58 PM »
Quote
I guess that depends on your defination of GOOD  :D
Mine would be to get someone ELSE to hold the plug and crank the saw :D
Offline james
  • truck drivin fool
Re: No hot start
« Reply #13 on: October 02, 2004, 11:14:28 AM »
aw, comon lanab -what no sense of adventure? ;D ;D :o :o
james
Offline Timber_Framer
Re: No hot start
« Reply #14 on: October 02, 2004, 03:06:37 PM »
I fouled my plugs on my Harley once in Podunk North Dakota and all I could find that would fit were champions. I didnt have to replace those plugs for nearly a year, which is unheard of on an old Hog.
If you find a good champion plug theyre as good as any on the market, the problem is as sawguy said finding a good one is sometimes a difficult task.
"If people concentrated on the really important things in life, there'd be a shortage of fishing poles."
Stihl MS-250 won't start fire or start after running great previous day
Started by fatdaddy on Chainsaws
Last post September 26, 2019, 06:07:47 PM
by fatdaddy
Start-up
Started by luvmexfood on Forestry and Logging
Last post April 17, 2014, 08:29:06 AM
by thenorthman
Saw won't start sometimes when hot
Started by jackganssle on Chainsaws
Last post March 26, 2013, 07:34:02 PM
by Al_Smith
Which end do i start from?
Started by rjwoelk on Timber Framing/Log construction
Last post December 12, 2017, 10:44:32 AM
by Roger Nair
