new homemade sawmill
Started by 1967Stroker, April 26, 2015, 08:30:39 PM
dustyhat
Not to get in anybodys way here, but you will need to make an adjuster for your roller guides , up and down tilt,to get the blade alined with the bed.    just trying to save you some head aces.
1967Stroker
the piece of 2x2 angle iron(with c-clamp on it) will have slots in it to go up and down and tilt. thanks
1967Stroker
Got the saw frame hooked to the carriage. yeah.
fishpharmer
Keep plugging along and making progress like this and you will be milling in no time.  Goes for all you other homebuilt fellers too! 8)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
1967Stroker
plan on to be sawing in three weeks. i hope
1967Stroker
gww
Stroker
One thing about it.  The pullys seem to keep the blade smoother in its running in all areas then my tires do. It looked pretty good to my eyes.
gww
ps thanks for the math on my build.
1967Stroker
i had tires on my first one GWW. i like this better.
Stroker
Where do you think the vibration is coming from? Looked to be a lot of bouncing. Any thoughts?
1967Stroker
motor plate. i haven't braced it up yet. i will soon.
1967Stroker
plus its a cellphone video
Stroker, its apparent you know what your doing and have the skill set to do it. Couple of comments, your belt idler, you want the band to come to a quicker stop when released and not just slowly turn. What you need is a way to brake the belt when fully released, it will aid band flex life and increase your safety margin. Single belt is probably OK for 8 hp but if you go more HP twin "B" would be better. All in all one of the better builds I've seen. Frank C.
1967Stroker
Yes need to fix a break for that. I will make one soon , need a piece of teflon plastic.
Herb Brooks
Quote from: fishpharmer on April 29, 2015, 09:58:31 PM
Ok update coming.  Well maybe.  got some done but not near enough.
fishpharmer
Herb we are looking forward to your update.
1967Stroker
well worked on my track added back stops and log dogs.
gww
It looks solid and I think you will like that you added enough log bunks for the logg to sit on.  I need one more in mine for the 9/10 foot loggs to be supported better.  Looks great and your work looks very neat.
gww
1967Stroker
There is one every three feet. I got some v groove pulleys order and some angle iron coming. Hope to get to saw some by the end of the month. Thanks.
1967Stroker
gww
Mine is 20 feet long but realisticaly I can only cut a 12 foot log. I lose a little on each end and am loading the log manualy and am lucky to get a 12 foot on spaced well enough to cut it.  You are going to love the 3 feet spaced bunks.
Looks good
gww
Fpenkaty3
Looks great, I am building a very similar mill also now. 20 ft tubular frame with a linn style head like yours. Keep the pictures coming
1967Stroker
when i started this it wasn't like this but its turning and twisting into something totally different.  it is 50" in between the axles and the track is 31" wide. the wheels for the blade are 16" and drive pulley is 10.25" and engine pulley is 3.15", the engine is 8HP. when finished it sould cut a 24" tree fine.
1967Stroker
well got it on its wheels now.
gww
Looks like all you need is a log.
gww
1967Stroker
just a little more stuff and going to try it out
