Author Topic: A good beginning  (Read 1201 times)
Offline woodman58
A good beginning
« on: May 04, 2015, 09:45:19 PM »
Hello All,
  I would just like to share my results of how my beginning is going with my new TK 1400. I have been posting adds on CL and putting fliers in local feed and farm stores. I have had a few people bring me a few logs at a time and had many calls for mobile sawing. I have got a portable job set for next weekend. About 1500 BF. The following two weekends, I have a job set that has 3500BF. This past weekend I looked at a job where a guy is clearing his 150 acres of land. He said that I can set up and start cutting when I get done with my other two jobs. He then said that I can just leave my mill on site or bring it every weekend because he will be cutting all summer. It looks like I will be busy all summer. I will be cutting some cedar at $65 per hour and the rest is oak and some hickory @ .30 per BF. Thanks to every on here who has posted in the past. It has helped me with pricing and knowing how to talk to potential customers. Hope all this works out.
i LOVE THE SMELL OF SAW DUST IN THE MORNING.
Timberking 2200
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: A good beginning
« Reply #1 on: May 04, 2015, 09:46:39 PM »
Glad to hear it good luck!   8)
Boy, back in my day..
Offline shakebone
« Reply #2 on: May 04, 2015, 09:52:10 PM »
Good luck but watch cutting that hickory so cheap it'll make you and your saw cry !! It will destroy your blades  :'(
Lt40 super desiel , LT 35 hyd , New Holland ls 180 , Case 75xt ,
So many logs so little time.
Offline 4x4American
    • Website Link
« Reply #3 on: May 04, 2015, 09:54:24 PM »
4 blades for the hickory?
Offline thecfarm
« Reply #4 on: May 05, 2015, 06:16:43 AM »
Sounds good!
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #5 on: May 05, 2015, 06:29:09 AM »
Good luck  8)
A&P saw Mill LLC.
License NH softwood grader.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: May 05, 2015, 06:34:28 AM »
Very often one satisfied customer leads to another.  Your reputation will become your greatest asset.   8)
Offline woodman58
« Reply #7 on: May 05, 2015, 08:18:45 PM »
Thanks everybody. I am looking forward to all the sawing. I have been sawing walnut and cherry for a couple of weeks. I plan on retiring to saw full time in two years.
Timberking 2200
Offline sandsawmill14
  • love my job (most days)
« Reply #8 on: May 06, 2015, 07:32:56 PM »
sounds like your off to a good start smiley_thumbsup  good luck with the hickory I send almost all hickory to cirlce mill  I have sawn it with my timberking b 20 but it takes a lot of blades :)
Offline GAB
« Reply #9 on: May 06, 2015, 08:50:00 PM »
Hickory is one of those trees that the bark seems to act like a magnet to any dirt in the air.  Using a new or ReSharp blade on a hickory log once I was able to get three cuts before having to change blade.
I learned that to saw hickory you need to open the log and take a board or two, then rotate 180 degrees and do the same, then rotate 90 degrees then saw boards without having to saw through any more bark.
Hickory bark is a real blade killer for me.
Gerald
« Reply #10 on: May 06, 2015, 10:00:42 PM »
Gerald
yep its almost like sawing backstops or dogs :D :D  >:(
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #11 on: May 07, 2015, 09:18:57 AM »
The iron might be softer than the Hickory.   ;D  :D
« Reply #12 on: May 07, 2015, 10:03:12 AM »
x2 :D :D :D
It may be the end, it may be a new beginning.
Started by Engineer on Sawmills and Milling
Last post February 26, 2010, 01:03:26 PM
by vahighlander
Just the beginning
Started by bigred1951 on Health and Safety
Last post April 18, 2018, 06:58:35 PM
by Idiocrates
Its beginning to look a lot like a sawmill
Started by gms1911 on Sawmills and Milling
Last post April 15, 2016, 10:35:26 AM
by outpost22
Rough at the beginning of a cut-why?
Started by caveman on Sawmills and Milling
Last post November 30, 2014, 08:50:05 AM
by caveman
