CIRCLE SAW GUIDES
Started by Gearbox, May 04, 2015, 09:47:13 PM
Meadows Miller
G'day
I use Grey Box for my guides from 1.5 to 2" square and get a great run out of them .
Regards Chris
4TH Generation Timbergetter
Ron Wenrich
I had square ones in one mill I ran.  I used a block of hickory or locust as a guide.  Just cut a block of wood and get it to the wide width.  I cut grooves in the wood with a grinder.  Soak in oil for a longer lasting fit.  I used a hammer to install.  To get out, you take a chisel or a screwdriver and split the guide into pieces.  I always went with the grain, as it's harder to get an end cut into it.
You might be able to find a composite block that would work.  You might have to adapt them to fit.  We even had to adapt the round ones to fit the newer mills.  It isn't one size fits all.
barbender
Gearbox, I may just do that ;)
5quarter
Meadows miller...great to see you back! Whatcha been up to? Isn't Grey Box one of those Aussie woods that saws about as easy as cured concrete?  ;) :D :D :D
Blue Harbor Refinishing
chopperdr47
I had some trouble with my pins for a while until I got all the stars and planets aligned. Since then I have the same dogwood pins with not much wear at all. When I "mop" my log beds, head blocks and other things with used motor oil cut with diesel, I make sure they get a little taste as well.
If ya ain't got what ya need, use what ya got
Meadows Miller
G'day
5quater  I'm Back Mate I have missed ya all  ! ;) ;D 8) yeah box does saw like bloody concrete at times  :o :)  :D but great wood if you want to build things to last mate ;)
Regards Chris
