Author Topic: Woodmizer Battery Light and Alternator Belt  (Read 1607 times)
Offline ncsawyer
« on: May 15, 2015, 09:31:28 PM »
My mill is practically brand new and only has 15 hours on it.  I noticed this evening that the battery light flashes every time I disengage any of the hydraulic levers.  It also flashes sometimes when I release the back and forth control for the head after traveling back to the front of the mill after a cut.
My old Woodmizer didn't have an alternator, it charged by a stator (like a lawn mower), so I don't know if it is normal for the battery light to flash when doing certain functions with the mill.  Have any of the other Woodmizer owners noticed this with their mill?
I also noticed this evening that my alternator belt will be lucky if it makes it  until I get the rest of the order I am working on finished up tomorrow morning.  This is the second alternator belt I have been through in 15 hours.  We worked for half a day at the dealership when I bought the mill the correctly align the drive pulley.  It shredded the first belt in about 10 minutes.  We slid the drive pulley as close to the engine as possible to get it to line up with the alternator, I guess it's still not lined up right, but I don't think there is any more adjustment in the drive pulley. It's as far as it will go in that direction and it looks like it needs to go a little bit more to get the alternator and drive pulley lined up.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
Offline Chuck White
  • Sawing Mobile since 2005
Re: Woodmizer Battery Light and Alternator Belt
« Reply #1 on: May 15, 2015, 09:49:32 PM »
Is the tension correct on the alternator belt?
The biggest issue is alignment.
There has to be something you can do to get "near" perfect alignment of the pulleys!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline flatrock58
« Reply #2 on: May 16, 2015, 09:03:21 AM »
ncsawyer
I have a 2001 WM LT40 super I bought last summer.  My battery light blinks when I run the motors all the time.  It has not caused me any problems that I can see but I am not sure if it is normal.  I guess it could be a ground problem.  My alternator belt is fine and the battery stays charged.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #3 on: May 16, 2015, 12:13:36 PM »
Could it be the light sensing the momentary hesitation of the voltage regulator in the alternator as it switches between different charge rates?
Offline drobertson
« Reply #4 on: May 16, 2015, 01:43:52 PM »
Seen it before, battery connections and a good ground on the under rail.  Now the alternator is a different issue, if not charging then that makes a little bit of sense too.    Simple fix,
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #5 on: May 17, 2015, 07:46:59 AM »
Hello,
That alternator belt needs to be aligned correctly. You should be able to tell. One side of the belt will pull off if not aligned.  We had the same issue here with that same diesel. I have been checking them ever since and have not had any more issues. Yanmar D35
I will try to post a picture of the pulley and post it.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Woodmizer alternator belt tension question
Started by Jim_Rogers on Sawmills and Milling
Last post October 26, 2009, 02:20:59 AM
by Brucer
Need some alternator belt help
Started by Nomad on Sawmills and Milling
Last post December 05, 2012, 08:56:23 PM
by Beavertooth
alternator belt PN
Started by LeeB on Sawmills and Milling
Last post January 07, 2017, 01:56:56 PM
by LeeB
Alternator belt for 2006 WM LT40
Started by WoodenHead on Sawmills and Milling
Last post May 06, 2015, 12:32:51 PM
by WoodenHead
