Author Topic: 1978 clark 664  (Read 15345 times)
Offline treeslayer2003
Re: 1978 clark 664
« Reply #80 on: August 16, 2015, 11:22:34 PM »
lets see here..........
i had this stuff made at a machine shop for the front cradle on my 666. the center will be the same parts plus brass washers and some shims.
see that bright yellow canister on the right side peeking from behind the air breather? thats the trans filter. my 666 has a spin on but its in the same location.
i may have specs some where on the pins and bushings. those are repair weldments in the pic, the bushing is a spherical bearing.
Offline vatkins
Re: 1978 clark 664
« Reply #81 on: August 17, 2015, 09:15:12 PM »
Thanks! I'll look again this Friday. The filter must be in a return line of some sort right. Wondering if it can be restricting flow to or from the cooler? The pins n bushing look easy enough for me to make. The spherical eye I'll hAve to order.  The pump I see on the left rear of the torque converter is the hydraulic pump right? I noticed on mine the suction hose is not as it should be. Thanks again. Wish you were closer I could help you with the machining
Re: 1978 clark 664
« Reply #82 on: August 18, 2015, 08:24:00 AM »
thats the tranmission charge pump, the lower right is the hydro pump for steering and blade. it is always bigger than the charge pump.
yes the filter could be restricting flow. i have numbers some where for the major brand bearings, ebay or a bearing house is cheapest route, but i like name brand ones.
i wish you was closer to, i got charged pretty good for what you see there. pins, 1-3/4" drill rod, weldments are just iron like the frame, nothing moves in those.
Offline vatkins
Re: 1978 clark 664
« Reply #83 on: August 18, 2015, 10:11:43 PM »
Pretty sure my Skidder has had the filter removed Treeslayer. Is the filter in the line coming off the right side of the oil cooler? I can see a bracket where something once was near the right end of the air cleaner but on the motor. Thinking I can put one back on if it simple is in line on the right oil cooler line? What's the hex chrome looking thing in the bottom left of the tranny just behind the left step? Theres a small opening there.
Offline vatkins
Re: 1978 clark 664
« Reply #84 on: August 18, 2015, 10:23:18 PM »
Try n this pic thing
Offline vatkins
Re: 1978 clark 664
« Reply #85 on: August 18, 2015, 10:39:15 PM »
This is where I think you say the tranny filter would be.
Offline vatkins
Re: 1978 clark 664
« Reply #86 on: August 18, 2015, 10:55:57 PM »
I also see to pumps. The one with the funny looking suction hose ( right one) is the hydraulic pump right? What does the left pump run?
Offline vatkins
Re: 1978 clark 664
« Reply #87 on: August 18, 2015, 10:57:26 PM »
The hose is under the drive shaft in the pic.
Offline kiko
Re: 1978 clark 664
« Reply #88 on: August 19, 2015, 03:45:15 AM »
There it is,  the transmission suction hose.  Looks like a radiator hose( at least from here) should have suction hose and suction hose clamps.  Edit. Just looked back at the picture,  to tell for sure which is which just see where the suction hose comes from.  I think the smaller pump on the right will be your transmission pump.
Re: 1978 clark 664
« Reply #89 on: August 19, 2015, 08:13:58 AM »
if i'm right, that rad looking hose goes to the hydro tank to the left and if so is the steering pump. this being the case, it looks like the charge pump on the left has been replaced.
vatkins, your filter is missing. yes it goes in line with the cooler line, i think to the converter. i would have to look to be sure. if you get a filter housing, you need to verify specs for flow and bypass. charge pump pressurizes the trans and fills the converter.
Re: 1978 clark 664
« Reply #90 on: August 19, 2015, 08:16:55 AM »
Try n this pic thing (Image hidden from quote, click to view.)
drain plug. and there is a screen behind it if memory serves........
Offline slakwire
Re: 1978 clark 664
« Reply #91 on: August 14, 2019, 06:52:54 AM »
Morning,  new to the site.  Do you know what the plugs are on the side of the diffs?  Manual says screw with a nut at the end. Thanks.
Will a 664c Clark Tranny fit a 664b clark ranger skidder?
Started by delimberboy on Forestry and Logging
Last post December 22, 2015, 01:23:05 PM
by oldseabee
1978 Cat 518
Started by Ohio_Bill on Forestry and Logging
Last post September 27, 2011, 01:11:38 AM
by acco1840
1978 Timberjack 450
Started by Jws_78 on Forestry and Logging
Last post August 27, 2015, 09:02:21 PM
by ehp
Bilzzard Of 1978
Started by Autocar on Forestry and Logging
Last post July 25, 2010, 05:55:48 PM
by woodmills1
