Dynamic Green Products Inc.
Author Topic: Chain saw accidents.  (Read 5703 times)
Offline Ed.
« on: May 28, 2015, 05:21:36 PM »
Hi guys, this is probably a dumb question but I am interested in finding out the mechanics of how chainsaw accidents occur, as a lot of you guys do this for a living and there is much more logging in your part of the world, so you would be much more aware of these things.
Now excluding all the obvious ones like kickbacks, trees falling down on a worker, over reaching, sawing without a good balance on the ground and falling on top of the saw. Just the bare mechanical basics, do they occur when a saw chain breaks and the broken end whips around the bar tip in a large arc or when a chain comes off a bar, that sort of thing and how often does this sort of thing happens? Hope this sort of makes sense!
Offline beenthere
Re: Chain saw accidents.
« Reply #1 on: May 28, 2015, 05:52:01 PM »
Can't say, as I've never been injured by a chainsaw. (knock on wood.. old saying).
Are you excluding the obvious ones, so just want the "un-obvious" ?
What is leading up to the question. Maybe that will help figure out what you are after.
Offline Ed.
« Reply #2 on: May 28, 2015, 08:39:32 PM »
Hi Beenthere, how this started was I was talking to a young bloke(23)  who is a chippie (carpenter) and his boss likes to take shortcuts where possible, on a building site this chippee was working at, there was a couple of trees that had to be removed, so instead of getting someone who knows what they are doing , the boss just went to a hire place and got a chainsaw and told this chippie to cut them down, apparently the chain was very blunt, no safety gear, no training in chainsaws ect.
Anyway I was telling him that I would have refused due to the safety aspect and tried to tell him about the dangers of  using blunt chain saws, no safety gear ect. ect. and I got to wandering about how frequently accidents occur due to actual equipment failure and not the obvious ones I listed earlier as a lot of those causes can be minimized or removed with a bit of care.
I do not do much chainsawing myself and have never seen an accident ( touch wood also) although I own 3 chainsaws. But I was wondering about mechanical failures such as what happens when a chain breaks or gets pinched and comes off the bar, I would assume that it wraps itself around you if you are felling and slashes you or does the chain grabber work well and are there other causes that can lead to major injuries? When cutting on the ground you can always remove your body from the line of damage , but this isn't possible when felling if it wraps around you. So just curious about the causes and how common they are.
Offline HolmenTree
« Reply #3 on: May 28, 2015, 09:45:39 PM »
Ed, in all the years I made a living  with a chainsaw and all the thousands  of times I have derailed a chain, I have never had a chain wrap around any part of my body.
Not even a cut.
 When a chain derails even at the highest  speed,  the drive links instantly  disengage from the drive sprocket  and the chain stops rotating when making contact with the saw. Whether it's  the chain catcher, sprocket  cover or rear handle guard.
Offline Ed.
« Reply #4 on: May 28, 2015, 09:51:42 PM »
Hi HolmenTree, that is good to know, I assume that the same result applies when the chain breaks or is that different? So I take it that most of the casualties are from kickbacks and that sort of thing?
Offline Spartan
« Reply #5 on: May 28, 2015, 09:59:41 PM »
Never had a mechanical related injury.  Would expect they are very uncommon.  Most i know happen by user error or outside uncontrollable events.
Although, some mechanical failures would probably have to fall under user error if it has to do with maintenance or inspection before use, that kind of stuff.
All my injuries were either stupid stuff or chance, none were mechanically saw related.
Offline JohnW
« Reply #6 on: May 28, 2015, 10:00:33 PM »
I think, by definition, your question is almost impossible to answer.  Generally, chainsaws are so distructive, and logs are so dangerously heavy, that those who deal with them quite natuarly have a little respect.  Accidents happen due to the unexpected and unforseen.  If we could forsee them, we could answer your question.
Everybody that's cut down and cut up a couple trees came close some place or another.
Offline HolmenTree
« Reply #7 on: May 28, 2015, 10:04:15 PM »
Ed to answer your question same scenario,  chain breaks the drive sprocket  instantly  disengages from the drive links. Chain stops. No whipping or flailing.
Kick backs by far are the greatest  danger of chainsaw operation next to struck byes from trees or parts of a tree.
Offline Ed.
« Reply #8 on: May 28, 2015, 10:09:33 PM »
Thanks guys for your responses, they answered my questions.
Cheers
Ed.
Offline so il logger
« Reply #9 on: May 29, 2015, 02:39:30 AM »
I may have to respectfully disagree about chain breakage not causing flailing. If it breaks when it is in the right spot it will flail or whip. I know from experience. But yes most injuries from operating a saw are from the tree or limbs or what have you. Logging or tree trimming is a dangerous job. If need be I guess I can have the wife take a pic of the scar's on my arm that caught a broken chain. It can happen
stihl ms 660's 661's husky 395's 450c tj Learning something new everyday
Offline Ianab
« Reply #10 on: May 29, 2015, 03:53:34 AM »
Yes, it can happen for sure. Not often, but often enough that modern saws have some sort of "chain catcher" down under the bar to reduce the chances of it happening.  If it never flicked off in a dangerous way, there wouldn't be any need to fit the catcher.
Offline HolmenTree
« Reply #11 on: May 29, 2015, 05:11:43 PM »
I'm wondering if this flailing broken chain was driven by a spur gear sprocket?
Another  few questions  what model of saw . How did the chain break and was a chain catcher and rear handle guard on the saw?
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
« Reply #12 on: May 29, 2015, 05:32:18 PM »
I've thrown(derail) a number of chains, but never had one break while operating. Sometimes you might get "stung" by it, but never anything serious. But it is why I prefer chaps that have legs sewn together in the crotch area. A little less mobility but a lot more protection.
Offline sandsawmill14
  • love my job (most days)
« Reply #13 on: May 29, 2015, 06:09:42 PM »
we used to break a lot of chains when we were running the old big saws(1050 homelites and a couple 100cc macs)  but they would normally just shoot out through leaves off end of bar.  i loved those old saws i still have a 1050 and a 1020( plus a few others) i might see what it would take to get them running :)
« Reply #14 on: May 29, 2015, 06:39:04 PM »
It was a rim/drum on a 660, 24in oregon bar and 75lgx chain. The chain catcher was long ago broke off, seems common. Yeah the rear handle was on the saw, I was limbing a water oak that was riding kind of high from limbs holding it up so the saw was above my head. The chain broke and it whipped back and down slapping my arm. I also agree that every other time I have had a chain break it has gotten thrown out away from the tip of the bar. Just saying never say it cant because believe me it can.  :)
Offline HolmenTree
« Reply #15 on: May 29, 2015, 07:02:41 PM »
Same here the few chains that ever broke on me just fly off the end of the bar and laid on the ground.
When you were limbing that tree above your head the limb may have deflected the chain down and back at you. Chain catcher probably wouldn't  have helped in that situation  anyways.
« Reply #16 on: May 30, 2015, 01:18:11 AM »
That's what I figure happened as well, the limb probably deflected it toward me. But figured I better throw it out there that it has happened. May have broken in the right spot like on the bottom side of the bar I honestly don't know but it wasn't a bad injury so that is what matter's  8)
Offline Ianab
« Reply #17 on: May 30, 2015, 01:50:02 AM »
A chain doesn't need to hit you "hard" to leave a mark, the sort that needs stitches at least. Same as a kicback where the chainbrake has activated can still cut you, just no where near as bad as a chain that's still running.
Now 99% of the time it wont get you because it flicks off the front of the saw. But that means 1% of the time, it's going to come your way. Then you hope the chaincatcher, your chaps, and good body position keep you safe.
« Reply #18 on: May 30, 2015, 02:51:18 AM »
X2... I wound up with 12 stitches out of my deal, the way my luck runs if it can possibly happen it will happen  :D I am laid up at the present time because of another felling accident  :D
Offline longtime lurker
« Reply #19 on: May 30, 2015, 07:00:29 PM »
So our carpenter is smart enough to know the saw is blunt but not smart enough to stop and sharpen it. Why didn't he sharpen it? Would he stop and sharpen/ change blades on his circular saw when it gets blunt or does he just keep going until the boss tells him to fix that too?
Why didn't he advise the boss he had no chainsaw experience? And y'know... PPE is a must at the idiot level, which is where I'd put 99.9% of the general populace when it comes to chainsaws, regardless of their experience or training level. All employees have the right to say "where's the PPE", all supervisors have the right to fire based on refusal to wear it.
Honestly, it should be mandatory for hire places to send at least chaps with a hire chainsaw... but it aint. In a workplace however no-one is going to get fired for refusing to do a job without PPE. Personally I believe that hire places should have an obligation to send appropriate PPE with any piece of equipment they hire out as part of the hire.
The major cause of death in professional forest workers is from falling objects, per the last WHS major study into what is Australia's most dangerous industry. Injury due to chainsaw is rare, and also in that you need to add that at after certain level in the professional industry we can actually get exemptions from wearing PPE (specifically chaps) because the risks associated with wearing it are higher then the risks of an injury from a saw. So at the pro level many dont wear chaps and we still dont get hurt by chainsaws.
Chaps save your legs from risks of kickback, flying chain etc. What they really are is insurance for those who through lack of knowledge encounter kickback... or dont know enough to maintain their gear. Kickback is the result of operator error each and every time it occurs. (Hard hats of course are there to make it easier for the paramedics to scrape your brains up.)
Chains come off for a number of reasons. Most common is incorrect chain tension: ie the operator keeps cutting when the chain is visibly loose. Thats caused by a fault know as laziness: ie the operator was too lazy to tighten it.
Significant causes of loose chains are operator keeps cutting with a blunt chain, and the excess heat generated by that makes the chain stretch. Thats caused by a fault know as laziness also, cause the operator was too dammed lazy to stop and sharpen it.
Chains dont just fall off the bar rails or fly apart without reason. When a chain does jump, it mostly wraps upwards and back into the clutch brake guard/front hand positions. Other then that it is most likely to strike you in the legs.
I don't mean to sound difficult here - but I get annoyed when people screw up then go looking for someone to blame rather then accepting responsibility for their own wrong choices. Chainsaws are not inherently dangerous things: like firearms its the idiot on the end of it that makes them dangerous. At least an idiot with a chainsaw is only mostly a danger to themselves.
ATV Accidents
Started by Phorester on Health and Safety
Last post August 27, 2007, 12:04:41 PM
by Phorester
Farming accidents
Started by Kevin on Health and Safety
Last post March 24, 2005, 05:58:06 PM
by Ernie
serious chainsaw accidents
Started by knuckledragger on Chainsaws
Last post April 03, 2018, 05:07:48 AM
by Skeans1
Even Animals Have Accidents
Started by Mark M on Health and Safety
Last post January 17, 2003, 11:03:40 AM
by Noble_Ma
