Author Topic: If 3/8 takes more power  (Read 7394 times)
Offline kellysguy
« on: May 28, 2015, 11:49:49 PM »
then why do manufactures use it on small saws? I noticed Echo uses 3/8 on everything. If it takes more power to run a 3/8 chain then why use it on a 30cc saw? Is it a production cost thing?
Offline so il logger
Re: If 3/8 takes more power
« Reply #1 on: May 29, 2015, 01:08:32 AM »
I wasn't aware echo uses 3/8 on everything. Pretty sure they don't, as I have had one that was .325 Put a .404 on a 70cc saw and you will understand  :) More pull via chain weight and more tooth contact will rob power out of a already smallish saw.
Offline starmac
« Reply #2 on: May 29, 2015, 03:21:46 AM »
From what I understand, what is used is a 3/8 low profile, whole different animal from regular 3/8. I could be all wrong though.
Online LeeB
« Reply #3 on: May 29, 2015, 04:18:55 AM »
Echo's website offers 3/8 and .325 chains. I don't see any other sizes listed.
Offline ladylake
« Reply #4 on: May 29, 2015, 05:28:00 AM »
Echo uses 3/8 low pro on their saws up to 40 cc and they really cut , the big difference is they use a 6 tooth driver.  I tried a 7 tooth which cut quite a bit slower than the 6 tooth.. The 45 to 50 cc saws will have a .325 7 tooth and the 60 and above will have regular  3/8 with a 7 tooth driver.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline kellysguy
« Reply #5 on: May 29, 2015, 08:34:22 AM »
There was a major suppliers site that showed the "recommended" chain for all echo models from 310-590 as 3/8 which is where the statement comes from. I want to say it may have been a box store but I could be wrong.
So then I take it that 3/8 LP has less drag than .325, is that correct?
Offline SawTroll
« Reply #6 on: May 29, 2015, 10:50:56 AM »
Drive sprocket size is a major factor here, but the end result also depends on exactly which chain models are involved
Information collector.
Offline kellysguy
« Reply #7 on: May 29, 2015, 12:20:09 PM »
I understand that completely, with all things being equal are the 3/8LP the easiest to pull? (excluding 1/4 of course).
Offline Philbert
« Reply #8 on: May 29, 2015, 01:16:09 PM »
'3/8' is the pitch - the average distance between the rivets in the links.  It does not determine the height, width, shape, or size of 'bite' of the tooth.  As noted, 3/8 low profile is really a different animal than full sized 3/8 chain, as they don't even use the same sprockets.
In terms of power required to pull a chain, I think of this sequence (low power required to high power required):
1/4", 3/8 low profile AND narrow kerf (e.g. Oregon type 90), 3/8 low profile (e.g. Oregon type 91), .325 narrow kerf (e.g. Oregon type 95), .325", 3/8", .404".
Of course, there can also be some differences between manufacturers of the same size chain; if the chain is full-chisel vs. semi-chisel, how it is sharpened, etc.  Saw manufacturers will also use skip tooth, and semi-skip tooth spacing to sometimes put larger pitch chain, or longer bars, on lower powered saws.  This is somewhat deceptive in my opinion, but legal.
Philbert
Offline HolmenTree
« Reply #9 on: May 29, 2015, 05:35:43 PM »
3/8 LoProfile chain or Picco as Stihls trademark is actually  an extended pitch 1/4" chain made into 3/8" pitch. Oregon introduced  it as a manufacturing cost saving consumer  chain  in 1975. Stihl Picco in 1979.
Less pieces per foot was the savings.
Before 1976 the 1/4" chain was outfitted on all small cube saws as the preferred  chain . But many more pieces per foot make it an expensive  chain to manufacture as todays prices of 1/4" chain proves.
This chain cuts a narrower kerf over the larger chains and has a smaller bite with it taking a 5/32" file.
As said a 6 tooth spur drive  sprocket  as a " lower gear" helps the little saw powerwise too .
Offline kellysguy
« Reply #10 on: May 29, 2015, 08:36:13 PM »
Thanks guys, I really appreciate it. I finally got them both together and can see the difference now. Man that LP is small. I'm surprised how well it cuts but it makes sense on such a small saw.
Offline HolmenTree
« Reply #11 on: May 29, 2015, 09:05:59 PM »
Now I'll  make things really confusing  :D
Here's  another low profile 3/8" chain......the Oregon 76LG. Introduced in 1976 and discontined about 20 years later.
An actual true 3/8 pitch chassis to match a full size 3/8 sprocket.
Cutter bits are equivalent  in size to a .325 and chisel to boot.
Top picture....76LG
Middle picture ...old timbersport race chain trick. Full size cutter on lightweight  76LG chassis.
Bottom picture.....Stihl 33Topic Super 3/8" low profile chain compared to full size Stihl 33Rapid Super 3/8"chain.
Offline kellysguy
« Reply #12 on: May 29, 2015, 09:21:54 PM »
 smiley_dizzy
Offline pabst79
  • Oh Boy! Wabbit twacks!
« Reply #13 on: May 30, 2015, 11:18:25 PM »
Not sure which came first, but I have chickens and eggs.
Offline SawTroll
« Reply #14 on: May 31, 2015, 08:56:34 AM »
I believe at least most 3/8" lo-pro chain "pulls" easier than 1/4" chain, as there are way fewer cutters?
However, I am not an expert on 3/8" lo'pro, as I haven't used it for 15 years or so, and I never used 1/4".....
Offline Cut4fun
« Reply #15 on: May 31, 2015, 09:16:00 AM »
Top picture....76LG
I understood 100% of all of that.  ;) ;D
Offline Philbert
« Reply #16 on: May 31, 2015, 10:32:26 AM »
Yeah. Some companies used to make full sized 3/8 pitch chain with smaller cutters.
Philbert
Offline HolmenTree
« Reply #17 on: May 31, 2015, 02:08:48 PM »
Thanks to  Kevin (Cut4fun) a few years ago I was able to buy about 9 loops of the 76LG and 33TS chain from him that he found.
I haven't  been able to find this chain for about 20 years  prior. :)
Offline SawTroll
« Reply #18 on: May 31, 2015, 03:16:05 PM »
Top picture....76LG
Basically true, but there are no such thing as true 3/8" chain, as the pitch basically are .366 on both regular and lo-pro, and not .375.  ;)
Offline HolmenTree
« Reply #19 on: May 31, 2015, 09:40:12 PM »
You know what I mean Niko :D
I was just saying the 3/8 low profile 76LG and 33TS are true 3/8 chassis to fit a standard sprocket where the 91 series or Picco 3/8 LoPro chain are not a correct fit.
The guide bar companies who have spent millions of dollars in research and development for the last 60 years or so still call the 3/8" pitch .375 as the numbers on my bar tip shows..............
Takes lots of energy to get some power!
Started by ET on General Board
Last post August 28, 2014, 07:21:12 AM
by Al_Smith
WM will make it right whatever it takes!
Started by stavebuyer on Sawmills and Milling
Last post August 13, 2013, 09:29:39 AM
by LeeB
and the saw takes a bite
Started by LeeB on Health and Safety
Last post October 14, 2010, 01:20:51 AM
by Raphael
NY DEC takes a beating
Started by Shagy on Firewood and Wood Heating
Last post August 13, 2010, 08:23:39 PM
by petefrom bearswamp
