Good safety reminder
Started by MattJ, June 23, 2015, 09:27:32 PM
MattJ
 Thought I'd show the value of good push blocks. I was routing dados for drawer sides when after routing about 12 pieces the spiral bit came loose. The collet must have loosened and it took off going right through the drawer and into my push block. Made a mess out of my drawer piece but luckily my hand was fine. Good lesson to always use ppe.
yukon cornelius
that's a good visual reminder. i think we all need those once and a while to remind us that it is necessary to protect ourselves
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
clww
Excellent post! Glad that wasn't your hand, too. ;)
Many Stihl Saws-16"-60"
18-Wheeler Driver
MattJ
Thanks guys.  I was working on fathers day and my first thought when it happened was all the work needed to recreate the piece and dovetails.  Then I looked at my fully intact hand and thanked the lord for my happy ending.
hackberry jake
That is scary! I had a bit come out of a router once. Never did find it. How did you do those fancy dovetails?
Gdaddy
Routers scare me more than anything !!! Push blocks and feather boards are a must. A board can be replaced but not so easy to replace a finger. Glad your ok!!
TK 1220 mill
Massy Ferguson 40 tractor
MattJ
The dovetails were cut with a porter-cable 4212 dovetail jig.  It clamps onto my workbench and then holds the two pieces to be joined at the same time.  You then use the attached bit and a router.
It was a love hate relationship that got better over time.  At first I couldn't avoid getting tearout.  I then saw a video showing you need to start with a light climb cut to score the surface and then route out the dovetails and pins.  It works pretty well that way.
The other downside is you need to have some scrap pieces the same width and thickness to set the jib up with.  It takes me 2-3 attempts to get it set up right.  Then you can really knock the pieces out.  I love handcut dovetails, but with a day job and family I don't have the time.  With the jig I cut five drawers in ~1.5 hrs including setup time.
 :o  Oh that is scary stuff !!!  Thanks, we need constant reminders.
Dan_Shade
I had the same thing happen with a spiral bit.  scared me too!
lots of dull bands and chains
