Author Topic: Kasco Blades  (Read 5293 times)
Offline justallan1
  • living and learning
Re: Kasco Blades
« Reply #20 on: June 26, 2015, 12:14:35 AM »
Jake, do the 8s pull your carriage into your hardwood logs much? The 10s were pulling my carriage into an apple log quite a bit.
Offline hackberry jake
Re: Kasco Blades
« Reply #21 on: June 26, 2015, 12:52:53 AM »
Not as bad, I used to notice it the most when I was edging boards. It seems like the wider the cut, the less it tries to pull. I added some weight to my carriage (3' I-beam, 20 hp v-twin, 8 gallon fuel tank, and a battery). Now that my carriage is heavier I don't really notice it pulling at all.
Offline justallan1
Re: Kasco Blades
« Reply #22 on: June 26, 2015, 08:43:09 AM »
Cool thanks.
Now if a guy could regulate how much "grab" it has and raise the tail end a couple inches he'd have auto feed and auto return. :D
Offline gmmills
Re: Kasco Blades
« Reply #23 on: June 28, 2015, 10:49:56 PM »
     homesteader
         The Kasco blade profiles in 10  deg and 7 deg are almost an exact clone to WM 10/30 and 7/34 profiles in 7/8 tooth spacing. There should be very little issues in sharpening the Kasco blades. The 4 deg Kasco blades are a completely different tooth profile from the WM 4/32 profile. As far as I know, no cam or full profile CBN wheel to match the Kasco 4 deg profile.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Offline Cutting Edge
    • Cutting Edge Saw Service, LLC
Re: Kasco Blades
« Reply #24 on: June 29, 2015, 06:12:03 AM »
x2
A cam for a 10/30 blade profile ( or similiar ) works great.  The Kasco 4 deg. shares the 10 deg. profile, just a different hook angle.  Just adjust the head angle to 4 degrees and dress the stone accordingly.
No full profile CBN wheel avaiable... yet.
EDIT:  As of Oct. 2015  Rixsaws has a CBN wheel for the Kasco 4 degree blades
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
Offline Bruno of NH
Re: Kasco Blades
« Reply #25 on: June 29, 2015, 05:15:43 PM »
Any one have a sharping service for the Kasco bands ?
A place you can send them to get re sharpend .
Jim/Bruno
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Ga Mtn Man
  • Y'all can call me GMM
Re: Kasco Blades
« Reply #26 on: June 29, 2015, 08:00:08 PM »
FF member Cutting Edge can help you with that.  PM him.
Offline gmmills
Re: Kasco Blades
« Reply #27 on: June 29, 2015, 10:00:26 PM »
     Yes, Cutting Edge can definitely sharpen the Kasco profiles.
Sawing since 1995
Offline homesteader1972
Re: Kasco Blades
« Reply #28 on: June 29, 2015, 10:34:02 PM »
     homesteader
Thanks, that was what I was wondering!
Woodmizer LT40HD20G
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
Re: Kasco Blades
« Reply #29 on: June 30, 2015, 07:49:11 AM »
Got 2 blades last year.
I like them, but I have about 50 blades in rotation now so dont need any more, but when I do I'll certainly contact kasco.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
241 acres of woodland
Kasco blades
Started by goose63 on Sawmills and Milling
Last post December 10, 2017, 01:24:27 AM
by Crossroads
VERY plesed with my KASCO blades
Started by kelLOGg on WoodMaxx Blades from KASCO SharpTech
Last post June 20, 2020, 06:56:36 AM
by kelLOGg
Ordering Kasco Blades
Started by LeeB on WoodMaxx Blades from KASCO SharpTech
Last post March 05, 2020, 07:49:49 PM
by kelLOGg
Kasco Blades for a new HM130
Started by nybhh on Sawmills and Milling
Last post January 23, 2018, 09:22:44 PM
by JB Griffin
