Sawmill gas
Started by Bruno of NH, July 09, 2015, 10:53:30 AM
elk42
1-2 TREE  thanks
    I also use pure gas in all small engines. And I use SEAFOAM at times to clean the carbs.
  Thanks . Bennie
Machinist Retired, Lt15 WM 25 HP, Stihl 044, Stihl 311, Kubota M2900w/FEL, KUBOTA L4800 w/FEL,
Lincoln Ranger 10,000, stihl 034,
4x4American
What do yawl think of that Star-Tron?  Before non-eth was available around here I used to always run that star-tron and I didn't have any issues.  Now that non-ethanol is available, it's all I use in my small engines.
and also, how about that K-100?
Boy, back in my day..
elk42
4x4American
  I have never used it so if it works for you use it. Pure gas is easy to get so I buy only what I need for a week or so, keeps it fresh.
twin_lakes
Quote from: 4x4American on July 11, 2015, 10:12:20 PM
I have used it with good success in my saws and UTV.  I also like and use sea foam as well.  Both are especially helpful in the colds of winter here in Michigan.
Woodland HM126, Stihl 270, Ford 641 Workmaster
Ljohnsaw
Well, the nearest ethanol free gas is 100+ miles from me in S.F. or Redding (California).  I thought I read somewhere that the high octane gas was ethanol free.  Any truth to that?
My only other option is aviation fuel and those are a bit of a drive as well.  Can anyone buy it at a air field or do you need some sort of clearance?
John Sawicky
DMcCoy
What we have locally is called 'Clear Premium' - non ethanol premium.
I have never run AV gas but many antique engine people swear by it.
Small engines do run better on clear premium.  About $4.25 a gallon locally.
I too, avoid plastic gas cans.  Latest engine manual mentions to avoid gas from metal cans, and to not run E-15, but E-10 is OK.   Maybe they just want to sell engines and gas cans.
4x4American
What about plastic diesel/kero cans?  I have a handful of metal cans, including a jerry can but getting gas out without a mess is largely impossible
waho
Quote from: DMcCoy on July 12, 2015, 08:53:56 AM
They recommend plastic cans?
Ljohnsaw
I haven't shopped lately, but thanks to CARB (California Air Resources Board), all cans offered for sale must be the spill-proof spouts.  All I see in the stores is plastic with the stupid spouts.  Takes forever to dispense fuel through them.  You can find metal cans at garage sales (Jerry cans) but they are generally in bad shape-rusted up.
John Sawicky
Andre
I got 2 of these from a guy who was giving up racing.
http://www.jegs.com/i/JEGS-Performance-Products/555/80211/10002/-1
May not be legal but the local sheriff asked were he could get some so as to not have to mess with the ones he could get in the stores.
For the "Wallmart" cans I add a vent hole a plug it with a roofing nail.
For a better looking solution you can get some plastic vent caps.
http://www.jegs.com/i/JEGS+Performance+Products/555/80217/10002/-1
See ya
  Andre' B.
AnthonyW
Quote from: 4x4American on July 12, 2015, 08:56:33 AM
Most of the time, I use a jiggler siphon rather than pouring. Flows at a rate I can control and with no funnel I can see into the tank. So CARB be darned, I take the spout off any way.  :D
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
4x4American
Quote from: ljohnsaw on July 12, 2015, 01:33:45 PM
You can get the Eagle ones at your local Grainger's.  OR mail order them.  I have 3 of these and love them.
I do not consider these jerry cans
https://www.google.com/shopping/product/8838685142815832852?q=eagle+gas+cans&safe=off&espv=2&biw=1280&bih=679&bav=on.2,or.&bvm=bv.97653015,d.cWw&ion=1&tch=1&ech=1&psi=AySjVYHcL4Hu-QGr2rPwDA.1436754949356.5&prds=paur:ClkAsKraX1jRipMSha9ASjGUY3teATJLMt1YFK0hbnpZQ-IZeKHC9BpDpww6bYp1odgfyIoD8Hw-oo15O_9nsWKpEI8TAkKfB6oFgK1xnasPx7OH_HIG1wEyARIZAFPVH72rYdm4DoR1cIxASPNrSaRi2w7vmA&ved=0CAwQpis&ei=CSSjVdmoGsXn-AGAsKrIBg
Quote from: AnthonyW on July 12, 2015, 10:34:59 PM
:D  these CARB people just don't get it.  Now with their junk spill proof cans most people take the spout off and spill more than ever!!  At my regular job, every so often on small jobs we use 5 gal cans to fuel up equipment instead of bringing the fuel truck, and with the spill proof nozzles we always just take em off and aim for in and around the hole.  Not only are we spilling more, we are also wasting valuable fuel.  Oh well, this must be what they wanted!  They also, IMO, need to make gas can threads a standard size.
The best spill proof plastic cans I've used are these:
https://www.pricefalls.com/product/no-spill-1405-2-12-gallon-poly-gas-can-carb-compliant/20405766?source=GoogleShopping&medium=cpc&term=PLA-SC&content=61865531738product_type_l1&campaign=TexasValue&adpos=3o1&creative=59282505151&device=c&matchtype=&network=g&gclid=Cj0KEQjwoIitBRDTgeiZq93F2LQBEiQAMfXL0S7cFQVGYysaWcmTlzEKnFSah1rl-rE3T3-QxB7lFy8aAj9o8P8HAQ
They work great in a 2.5 gal and under size.  I have a 5 gal version of this for diesel, and it pours way too slow.  SO I drilled a hole in the back of the tank, and I put a self tapping screw with the washer in it to plug it for transport.
Ever since they took away that back vent on gas cans, many folks will drill a hole in the back.  Put without a good way to plug it, it just leaks.  So if they just never took em away in the first place there wouldn't be any problems!
I have a friend who fuels up his powersaw with that small hole in the back of the tank.  More precise I guess.
Vents are readily available:  Vents
4x4American
I had no idea you could buy them!
4x4
Would you set those long url's up as a link so they don't run our screens off to the other room?  Appreciate that...
4x4American
Hey just saw this.  I fiddle farted around with it for a few min.  Couldn't figure out how to get it to not be annoyingly long!  I clicked the insert hyperlink button, and pasted it in there, but it didn't seem to do anything.
acrosteve
I always run premium gas for my small engines.  My thinking is that ethanol has a rather low octane rating.  Which would not be something that they would want to mix in with a higher octane fuel.
My logic may be flawed, however.
Timberking B-20
If you live in a goody goody liberal state you will have problems finding alkie free gas. Its worth paying the freight for the expensive canned gas if your an occasional user in two cycle engines. For mills, lawn equipment, tractors and snow blowers use the crap fuel but with blue (marine) stable. Have a shutoff under each fuel tank and run the carb dry when your done using it. Seems the damage is done in the carb not sitting in the tank. My 50's vintage Deeres don't seem to care ether way on the gas. Frank C.
John S
MM,
Thanks for another great LINK!  Just orderd 10 vents!
2018 LT40HDG38 Wide
barbender
4x4, I decided to try one of those cans you linked to. I like it, so I went and got another ;) They work really well for fueling saws, it's easy to meter the fuel out. Most of the time, with other cans, I think only about 1/2 makes it in the saw tank ::)
deadfall
Is this the link to that can?  Or was it this one?
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
Personally, I really like the No-Spill cans..   first link.
Thanks deadfall, for using the "link" feature to those long url's
4x4American
barbender- glad to hear it!  I hear ya there before I had one of them I would get the sawgas in and around the tank, mainly around. :D
deadfall-how you do dat link thing ???
4x4
To see the "code" for the link, click on the "quote" of his post.
There you will see the use of the square brackets, where the url fits, and where the 'name' of the link fits.
The = sign and the / along with the [] have important places and position.
deadfall
It's weird that there is a button for FTP links but not for URLs.  I didn't know how to do it, so it was trial and error until I got the combo that worked.  This is not my first rodeo errrr... forum.  It seems there are no two alike.  Some forums want the URL in quotation marks, but this one didn't.
So, here's how:  (Note: Just for explanation here, when you see these: < >, think these: [ ].)
<URL=(paste the URL here)>linking text here</URL>
So:
I anyone knows an easier way, please show us.
It was nice that I learned how to do ° with a button instead of writing the word, degree.
