Author Topic: And another sawmill build thread...  (Read 17628 times)
Offline ljohnsaw
Re: And another sawmill build thread...
« Reply #100 on: December 13, 2017, 06:49:50 PM »
Back on reply #90, there is a picture (from March 2016) of my mill.  Here it was in February of 2017:
And again the end of March 2017 after about 18" melted.  Notice the head angle...
Offline ljohnsaw
« Reply #101 on: December 19, 2017, 11:43:12 PM »
Went up today to try and get some milling done before the snow dumps again tonight.  The last snow was from Thanksgiving weekend - just a couple inches.  The forecast was for rain.  Here is what was left today - ground pretty well frozen but was able to use the SkyTrak
I put this big guy on to test the log clamp
Plenty of travel (1") and tons of pressure!  The only issue I had is a 2x2 tube is not exactly 2x2.  My tubes are ever so slightly rectangular.  Of my 3 log bunks that will accept the clamps, only one would fit correctly.  The other two would only take the clamp 90 off to the side.  I have a little grinding to do on the posts.
Offline ljohnsaw
« Reply #102 on: February 01, 2018, 05:18:40 PM »
I've been pondering what to use to jack up logs to center the pith.  I have a few scissor jacks that could fit but it might be difficult to crank them as the jack has to rise between the bars on my log bunks.  The crank mechanism would be blocked by the bunk end posts.  I was out today hitting thrift stores and such and found this at a ReStore (Habitat for Humanity).  Maybe Kbeitz knows what it from.  I'm thinking an early 1900's car or truck?
BTW, the posting by clicking to insert link is working again (for me)!  :)
The "lug wrench" has a screw driver like end on it (to pop a hub cap?) and a hex nut hole in the other end lug nuts/bolts.  It doesn't fit in the jack correctly so I'm assuming there was a different handle for it.  I had to give it a shot of Blue Creeper to get the ratchet pawl to work properly and lubed the threads as well.  I like the flip top extension - might come in handy when I try it out on my mill (whenever the snow melts...) :-\  I'll probably make a slight U shaped bracket to fit on top to cradle a log so it won't want to roll off.
Not bad for $5.00! 8)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #103 on: February 01, 2018, 05:31:20 PM »
I have a jack collection with a few like that but I have no idea
what car it came from. E-bay is saying Model A A2
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline waynorthmountie
  • new guy that likes to tinker.
« Reply #104 on: February 10, 2018, 03:23:29 AM »
Can you provide more info and photos of your lift system. Seems pretty unique, how has it been working and how fast can you lift the head up and down.
Offline ljohnsaw
« Reply #105 on: February 10, 2018, 11:18:50 AM »
Here is a couple pictures when I first made it.  Things are a bit rusty now!  It is made from those big rolling file cabinets.  I added more stages of gear reduction to make it really easy to lift.  About 10 turns to lift an inch.  The center shaft turns the two outside shafts which haul the head up on four chains.  It used to free fall so going down was easy.  Now I have to give the handle a big spin and it will go down a couple inches.
Offline ljohnsaw
« Reply #106 on: March 21, 2018, 10:56:53 AM »
@Kbeitz ,
I'm going to make the jump to power!  I will add a motor to my head lift.  It is geared way down - about 10 rev/inch.  I bought a pair of Jazzy motors and with their low speed and my low gearing, I'm thinking just a on/off/jog/reverse setup like you did on your router attachment.  The other motor I was planning on adding drive power and I found this controller
Waterproof 12V 24V 48V 20A DC Motor Adjustable Speed Controller Regulator Switch
and was wondering what you think.  I like the waterproof!  Hard to say without seeing the guts.
I found where you recommended this one Q1 Speed Motor Pwm 60a Red+black Hho Rc Control 48v 24v 12v 15khz 10-50v 3000w
and it looks like it is pretty ruggedly built (lots of power transistors).
Then there are these out there
DC 10-55V 12V 24V 36V 60A PWM DC Motor Speed Controller CW CCW Reversible Switch
with a reverse switch already set up and a digital display of the speed (0-100%).
I am adept at doing electrical/electronics so no issue with putting in a reverse switch on the motor leads and limit switches.
Offline Kbeitz
    • My Hobbies
« Reply #107 on: March 21, 2018, 02:02:00 PM »
Great... and good luck... My choice would be the high amp one. It will last much longer...
Offline ljohnsaw
« Reply #108 on: September 04, 2018, 10:23:00 AM »
Made this change back in April or so.  Took the tri-handle off and installed a wheel chair motor (24v) that runs off the engine battery (12v).
Runs a little slow when you have to go far (20-30") but good for fine adjustments.  It was acting strange (would go real slow) so I installed some test points for my VOM.
Turns out the battery wasn't fully charged.  I used a battery charger and now it seems to be doing much better.  Might have to resort to an "external" alternator that has more output then the little magneto one on the engine.
The switches on the right are for drive motor(s) but until I get more charging output, that is on hold.
I built my mill using Toyota Tercel rear wheel hubs.  The pulley I had required me to pull the drive hub apart so I could bolt it up on the back side of the hub flange.  In doing so, I messed up the bearings.  They have been giving me problems the last month or so.  When I took off the blade to change it, I could see they were way gone now - about a half inch of wobble!  The inner bearing races were heavily pitted and the seal looked shot.  Probably a lot to have a machine shop repair.
Over Labor Day weekend, Pic-n-pull had half-off so I found a "new" hub for $10 and decided NOT to do the same thing.  Using the old hub, I located the pulley on the rim and drilled though to bolt directly to the rim of the tire.  Then I cut out the center of the pulley and mounted it like this:
I was going to take it up the hill today to test it out but a small forest fire has closed my area.  Hopefully they will get it under control/out today if it didn't spread too far last night.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #109 on: September 04, 2018, 03:32:43 PM »
You may consider adding one of these.
Since it draws virtually nothing mine is wired direct.  12.6v before I cranked up but I had used the hydraulics a bit.
14.6v with the engine running.  I always know what my battery and alternator are doing.  :)
Offline ljohnsaw
« Reply #110 on: September 04, 2018, 04:00:19 PM »
Nice.  I'll have to add that to my Amazon list for the next shipment.
Offline ljohnsaw
« Reply #111 on: September 17, 2019, 09:21:45 PM »
I guess I add a little once a year to this thread.  So, once again, the drive bearing went out.  I got TWO replacement spindles this time from Pic-n-Pull so I have one "on the shelf" ready to go.  That happened about back a couple weeks.
I was having trouble with my "sideways" clamp.  The point wasn't quite long enough so I welded on a little tab.  So here is my sideways clamp for when I get down to something less than 7" that needs a clamp:
 The cam is setup reversed.  This is the locked position, with the handle pointing to the left is released.
I also "improved" one of my scales:
I did two things.  I punched a little dot half way between each scale mark (dark blue).  Then I also punched which scale under every mark and full mark (the faint, uncolored numbers).  That way I can make sure I'm on the right scale.  At the bottom you can see a little carriage bolt head.  That is on a toggle clamp that holds the scale from sliding around.  Say I want to cut a 6x something, I center the blade on the pith, release the toggle and slide the scale up or down until a dot on the 6-scale is under the height marker (a red wire not shown).  I lock the toggle and then raise the head to the full 6-scale (numbered) mark and make my cut.  Drop down to the next lower 6-scale full mark and cut again.  Now I don't have to mess with the tape measure!
Offline ljohnsaw
« Reply #112 on: October 12, 2019, 08:49:15 PM »
Posted this elsewhere but wanted to keep my sawmill thread up to date.
To center the pith, I would lay my 4' level across the rails and measure up with an aluminum rule (like a yardstick).  So I came up with a single tool to do the job and not so fragile as my level.
I just made this up from a 8' piece of aluminum 1/8" x 1" stock I had laying around.  I cut it into two 4' sections.  I had the last 2 feet of a 12' stick on measure (for radial arm saw fence ).  I stuck it starting a few inches above my log bunks.  It doesn't matter what the numbers are, they are just a reference to the pith at each end of the log.  The wing nut allows for sliding the vertical to match where the log is on the bunks and it can be slid off to store as a single 4' long stick.
The Official VooDooChikin sawmill build thread!
Started by VooDooChikin04 on Sawmills and Milling
Last post May 16, 2020, 10:44:40 AM
by VooDooChikin04
Another build thread... JoshNZ
Started by JoshNZ on Sawmills and Milling
Last post May 10, 2020, 07:03:28 PM
by JoshNZ
bugpeople's Butt and pass build thread
Started by bugpeople on Timber Framing/Log construction
Last post March 28, 2018, 03:14:41 PM
by Jeff
(Another) Sawmill shed design thread, but I could use some help
Started by AnthonyW on Timber Framing/Log construction
Last post January 19, 2015, 08:39:42 AM
by AnthonyW
