Tally-I/O
Author Topic: New owner.  (Read 20494 times)
Offline Satamax
Re: New owner.
« Reply #40 on: August 21, 2015, 06:44:25 AM »
Well, Ianab, that's because it's the end of the winter where you live. :D
Here's what it looks like in october where i live.
In the winter, i work for the chairlift company.  So i see plenty of snow.
The closest pass near me is open all winter and  is at 6751ft above sea level. ;D
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline Satamax
Re: New owner.
« Reply #41 on: August 27, 2015, 05:52:10 PM »
Glad I dont have to buy blades for that thing....
  Spoke with the guy from "Forezienne mfls" a company which provide for the needs of a lot of sawyers in France. He said 12cm wide blade, stellite tipped ready to saw is 250 ex VAT. Not tooo tooo bad! ;D
Offline 5quarter
    • Blue Harbor Refinishing
Re: New owner.
« Reply #42 on: August 28, 2015, 01:53:34 AM »
...12cm wide blade, stellite tipped ready to saw is 250 ex VAT...
American translation: ...Blahblah wide blade, stellite tipped blade ready to saw is blahblahblah.
Offline Satamax
Re: New owner.
« Reply #43 on: August 28, 2015, 04:04:58 AM »
5quarter, ye'r a cunning linguist, fantastic one even. I would never had thought you understood French!  ;D
Offline Satamax
Re: New owner.
« Reply #44 on: March 06, 2016, 04:28:03 PM »
Well, just bought some MEM log dogs, from a vertical headrig. Without motors :( But since they will be modified. I'll see how it goes.
Offline ozarkgem
  • age 65 yrs old
Re: New owner.
« Reply #45 on: March 10, 2016, 08:05:18 PM »
So is that 250 euros plus VAT? Pretty expensive.
Offline Satamax
Re: New owner.
« Reply #46 on: March 11, 2016, 01:38:45 AM »
Yep, it is. But they last a fair bit. You're counting may be 12 sharpenings between re stelliting. And 10 times that before the band is dead.
Offline Satamax
Re: New owner.
« Reply #47 on: May 25, 2016, 03:18:25 PM »
Ten months later.
Offline Satamax
Re: New owner.
« Reply #48 on: June 06, 2016, 06:05:30 PM »
Progress as of today!
All the piers are poured, i mean i've filled 8 more barrels, that we need to bury with a friend.
But i am gutted. I've noticed there's one part missing. The pulley for raising the head. It's nothing. I have a lathe and i know how to use it. But if i had known better, i would have checked that. Pulley should be on the arbor bellow, on the last pic.  :(
Offline ozarkgem
  • age 65 yrs old
Re: New owner.
« Reply #49 on: June 06, 2016, 08:26:18 PM »
Your piers should be stout enough. Won't be any give for sure. Now where is your log pile?
Offline Satamax
Re: New owner.
« Reply #50 on: June 07, 2016, 06:52:07 AM »
I don't have  a log pile.  :(
Online sprucebunny
  • Gender: Female
Re: New owner.
« Reply #51 on: June 07, 2016, 08:21:59 AM »
Glad to see your progress !
Offline Ox
  • Trying to learn/remember something new every day.
Re: New owner.
« Reply #52 on: June 07, 2016, 09:52:56 AM »
You keep plugging along and you'll be milling before you know it.  Then you're in trouble because everything will look like saw logs.
Offline Satamax
Re: New owner.
« Reply #53 on: June 07, 2016, 03:03:43 PM »
Well, question, what is the smallest size log which could be intresting to cut in larch? Got some tonight. We went on a mission with a friend, who had to cut two trees on a mountain path, to do some earthwork.  The feeling of the two trees was not planned, and the wood needed to be cleared quickly.  ;D
So now it's cleared, he's got a few saw logs, may be 2/3 of a cord. And we have those two 13'ish  logs. The middle of that 27'ish straight section was about 13" 14" Off center pith. Fastish growth (well for here. )
And i don't have a wood yard. But a friend of mine has 106 spruce logs planned to build a log home. Sitting about 100 yards from me. And he's complaining that they're roting away. They've been there since his his divorce.  Since he doesn't trust this wood anymore. He's ordered a big load of douglas. So i might have a fair bit of practice wood!  ;D
Offline Ox
Re: New owner.
« Reply #54 on: June 07, 2016, 06:02:35 PM »
Common thoughts are a minimum of 10" diameter logs.  But if you're milling for yourself, go as small as what you want to mess with!  I think you'll find the 10" is a good rule of thumb.
Offline Satamax
Re: New owner.
« Reply #55 on: June 08, 2016, 01:04:45 AM »
Thanks a lot Ox.
Offline Chuck White
  • Sawing Mobile since 2005
Re: New owner.
« Reply #56 on: June 08, 2016, 07:23:24 AM »
I tell my customers that 8" on the small end is my limit.
Any less than 8" and my clamp can't be used, it would work for the opening cut, but when you turn it, the top of the small end will be lower than the top of my clamp.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline DMcCoy
Re: New owner.
« Reply #57 on: June 08, 2016, 09:17:17 AM »
Wow!  Doesn't look like they were stingy with the steel in the mill our your trucks.  1/2 the price of an LT10.  Not surprising actually, seems like bigger equipment often goes cheap(er).
When you get tired of sawing you can take in the scenery -  beautiful!!
Offline Satamax
Re: New owner.
« Reply #58 on: June 23, 2016, 07:13:42 PM »
All the piers are in.
Offline tnaz
  • Retired; with a Full Time Task! Of my Choosen
Re: New owner.
« Reply #59 on: June 23, 2016, 08:10:28 PM »
Sweet; when will saw dust fly?
I am know a new owner
Started by sjh on Sawmills and Milling
Last post October 05, 2003, 10:05:31 AM
by oldsaw
New Oscar owner
Started by badpenny on Sawmills and Milling
Last post April 28, 2005, 01:50:42 AM
by WoodSmith
New E classic owner
Started by overclocking on Firewood and Wood Heating
Last post September 20, 2015, 02:14:39 PM
by overclocking
New E-Classic owner
Started by ken999 on Firewood and Wood Heating
Last post March 04, 2012, 01:29:11 PM
by Dean186
