Author Topic: Kasco WoodMaxx profile  (Read 996 times)
Offline postville
    • Postville Blacksmith Shop
« on: August 19, 2015, 05:06:01 PM »
What does a Kasco WoodMaxx blade profile match up to?
I have to get a 3/4 cam for a Cooks sharpener that is close.
Thanks, Bob
LT40 25hp Kohler, Gehl 6635, Valby grapple, Ford 4600, Farmi winch, Stihl saws
Offline Cutting Edge
    • Cutting Edge Saw Service, LLC
Re: Kasco WoodMaxx profile
« Reply #1 on: August 19, 2015, 10:38:06 PM »
postville,
Kasco 3/4" has a 10 deg hook and similar gullet shape to the "Industry Standard"  They do have a deeper gullet to help carry more sawdust out of the cut.
Kasco 10 deg. is near identical to a WM 10/30
Kasco 7 degree is very close to a WM 7/34
Kasco 4 deg has the same profile as their 10 deg blade but with a 4 deg. hook angle
Hope this helps.
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
clip
Kasco WoodMaxx profiles
Started by Sawman815 on WoodMaxx Blades from KASCO SharpTech
Last post December 29, 2020, 08:49:06 AM
by Tacotodd
Please Welcome KASCO SharpTech & WoodMaxx Blades!
Last post December 22, 2014, 07:15:25 PM
by Billbob
WM Turbo 7 profile vs Kasco 7 profile.
Started by LeeB on Sawmills and Milling
Last post July 05, 2019, 09:05:58 AM
by PA_Walnut
Woodmaxx sawmills
Started by AndyVT on Sawmills and Milling
Last post November 29, 2021, 08:35:31 AM
by VB-Milling
