Wallee's Milling Thread
Started by Wallee, August 25, 2015, 12:47:00 PM
Wallee
Figured I would just make a thread to share the day to day stuff I am doing around the mill. I am a huge fan of pictures and posting stuff I do so I figured someone may be interested and I am sure I will learn from what others will have to say about what I am doing!
To start off, Here is what I milled yesterday evening after finishing up the horses for the day.
And Here is some stickers I sawed, 1" by 1".
Lt28 Woodmizer, International 3514 wheel loader, husqvarna 450,455 rancher, and 372xp saws, 1990 international 4700 log truck, Prentice 180b knuckleboom!
plowboyswr
Just an ole farm boy takin one day at a time.
Steve
Wallee
Quote from: plowboyswr on August 25, 2015, 12:54:36 PM
:P with interest  ;D
I knew some would find it interesting!  :D Hang in for the ride lol  8)
Wallee,
   Interesting so far. Can you update your profile to show what kind of mill and support equipment you are using? Will help us understand the challenges and accomplishments better.
petefrom bearswamp
Nice!
Glad to see another miller who is not claiming to average 2,000 ft per day on hardwoods
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
bkaimwood
Amen!!! One man band, happy to saw 600bf
bk
slider
Good job Wallee.Take this for what it's worth but i started making all my stickers and dunnage the same length .Every thing is around 48 in.You get better air flow and when loading a trailer it fits .Your packs will look neater as well. It's good to see your progress and your interest in making a good product.
al glenn
Wallee
Quote from: WV Sawmiller on August 25, 2015, 05:27:48 PM
Wallee,
Sure I will update some of that tonight!
Quote from: petefrom bearswamp on August 25, 2015, 05:32:44 PM
Nice!
Ha ha oh yeah no where near that!
Quote from: slider on August 25, 2015, 09:03:49 PM
Thanks! Yeah this is the first stuff I have really tried to keep neat and stacked and stickered like what I want. I am thinking of taking the chainsaw and sawing off all the excess stickers that are hanging out. Would that be a bad idea lol?
Good idea.  A battery powered circle or reciprocating saw also works.   ;D
Wallee
Quote from: Magicman on August 25, 2015, 11:01:15 PM
Im liking the reciprocating saw idea! I have one of those I love running it for some reason lol
Also here is a video from around the mill I made. Cutting some logs to length and a little rambling at the end!
https://youtu.be/OSGpK92YhJI
Wallee
Here is a question I bet tons of you can help a rookie with. I am wondering how much water to run on my blade. A slow drip? or more? Reason I am asking is because I notice I have to scrub wet sawdust off every board... That is annoying lol. If I run the water more it seems to not be as bad. SO what is the effects of too much water vs. too little?
5quarter
Wallee...nice thread. I saw dry most of the time. When sawing white oak and pine, I will occasionally have to clean the blade. when I do, I use a diesel wipe. A clean blade is a happy blade. 8) ;)
Blue Harbor Refinishing
Warped
     I was using water in the beginning because I thought it was the thing to do, I've found it's not needed for what I do and run it occasionally if I make more passes than usual. Maybe that will change when I start on some white pine. Besides sawdust sticking, it freezes it to the board in the winter.
Good with the rough stuff and rough with the good stuff
sandsawmill14
i just run a slow drip unless i start to see buildup on blade the i will run alot (1/8" steady stream) until i finish that log. had an ash log cause major buildup yesterday bad as pine  never had that happen in ash before :)
East ky logging
Wallee how do you like the the log clamp on your mill I seen you had one break but do they do a pretty good job.
They who can give up essential liberty to obtain a little temporary safety deserve neither liberty or safety- Benjamin Franklin
Wallee
Quote from: East ky logging on August 26, 2015, 08:15:16 AM
They do a good job! I was over clamping in the beginning. I guess I was thinking of using it as a dog on a carriage when it indeed was as it was called and just a clamp. So I have been using it lately just slightly snugging up my cant and it has got a lot better.
Wallee
Quote from: sandsawmill14 on August 26, 2015, 07:39:49 AM
Do you have a lot of sawdust sticking to your lumber?
mesquite buckeye
redbeard
Wallee,  try a drying stick on the ends of your stacks 2"-4" in from the ends, it helps prevent checking if your staking bunks on top of each other. Your shins will appreciate cutting the excess lengths back. I have settled in on 42"-44" drying sticks. I try to grade them clear of knots so they don't fall apart.
sandsawmill14
Quote from: Wallee on August 26, 2015, 10:08:36 AM
there is quite a bit of dust on the lumber but its not wet and you can drop the board on its edge and it will almost all fall off. my feed rate may be enough faster than yours to keep dust from getting wet and sticky. today i sawed 54 7x9s and a total of a little over 3800 bd ft today  ;D i love sawing big gum. my numbers are about half that in white oak and even less in hickory  when my wife gets her new camera i will try to get a video posted of it sawing
Yes, the first sticks need to be at the ends of your boards.
Delawhere Jack
Very nice stack of wood for an evenings work, especially from a manual mill. As far as lube water -- just enough, but not too much. If your mill has a tension gauge, keep an eye on it. Dropping tension means the band is getting hot -- run more water. Watch for sap on the band, add more water. If in doubt......add more water. You'll get a feel for it over time. Cool clean bands are what you want.
Wallee
Quote from: sandsawmill14 on August 26, 2015, 05:41:30 PM
Heck yes to the video idea! Man o man you was getting it at 54 7x9's! Ha ha I would love to be able to saw that many! In time, In time I will!! I cut my first few gums about a week ago and it went alot faster than these pin/red oaks I have been in!
Wallee
Quote from: WDH on August 26, 2015, 09:43:23 PM
Note taken! I will add some in there!
Wallee
Quote from: mesquite buckeye on August 26, 2015, 10:33:21 AM
This is a good idea. ;D
Thanks! I will post tons of pics! I will even post a few of my logging adventures from time to time!
