Author Topic: Total noob, with noob questions.......  (Read 2141 times)
Offline fermentor
  • rookie
« on: September 24, 2015, 05:03:07 PM »
Hello everyone. I just picked up a mill and am beginning my learning curve - with the mill and this forum.
I think it is custom fabbed twin (dual?) blade (21"H, 18"V) with 25 HP Kohler twin, power raise/lower, 24' power feed/auto return on 12K tilt trailer with 12K winch. Looking to get some idea about how I did.
Photos below (i hope).
http://www.forestryforum.com/gallery/displayimage.php?pid=190344#top_display_media
http://www.forestryforum.com/gallery/displayimage.php?pid=190343#top_display_media
Also have couple of questions.
It has fittings (no tank) for coolant feed on the vertical blade only. Wondering if circulars need it just like bandsaws? Any popular coolant recipes? Mainly looking at pine and cedar.
We did a maiden voyage on small (14"-16") log and after several passes (past halfway down) horizontal blade blade was chewing into prior pass. We are thinking we didn't have clamps tight enough and maybe the cutting action dried the core enough for it to curl up 1/8" on cut side. Anyone experience something similar? Trailer, tracks and carriage seem solid and no troubles on earlier passes.
Link to video (running out of gas) below:
https://www.dropbox.com/s/io1t105rh9toug0/video-2015-09-19-15-13-18.mp4?dl=0
Thanks for any suggestions/ideas.
Dale
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Total noob, with noob questions.......
« Reply #1 on: September 24, 2015, 05:17:30 PM »
Welcome to the forum, sorry I can't assist you with your circle mill!  Good luck.  Others will be along that can help.
Boy, back in my day..
Offline drobertson
« Reply #2 on: September 24, 2015, 05:26:55 PM »
I can't help either, but it looks like it should work, there is always a learning curve, and dont' tell anyone else, but I ran out of fuel one time too ;D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: September 24, 2015, 07:57:30 PM »
Welcome to the Forestry Forum, fermentor.   :)
Is this where you live?  State of Jefferson ?
Offline Ron Wenrich
« Reply #4 on: September 24, 2015, 08:39:56 PM »
As Rush would say - for those in Rio Linda.  Northern California.
I've only seen a few double cuts run, and I don't recall seeing them use a coolant on the blade.  Did you sharpen your blade before you started cutting?  Dull blades can do all sorts of things, especially ruin lumber and cuts.  Feed rate is also important.  Too fast, and you'll have problems as there is too much dust for the gullets to handle.
Offline mad murdock
« Reply #5 on: September 24, 2015, 09:41:07 PM »
Welcome aboard!! Nice looking mill. Uou got the pics to uour gallery, now just scroll down the screen a bit more and hit the add pic to post button, or copy and paste the url in your post like this
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #6 on: September 25, 2015, 06:42:46 AM »
Welcome to the Forestry Forum, fermentor!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline 4x4American
    • Website Link
« Reply #7 on: September 25, 2015, 06:56:51 AM »
I'm willing to bet a swing blade guy might have some good fft (food for thought) for ya.
Offline fermentor
  • rookie
« Reply #8 on: September 25, 2015, 11:01:15 AM »
Thanks everyone. Appreciate the welcomes and tips. I should probably start hanging with the circle/swing folks.
Only in spirit, although my grandmother was born in that area. There is a current effort by rural counties to split off from SoCal and Bay Area over differences concerning gun control, bullet trains, twin 40' tunnels to steal our water and stuff like taxpayers funding sex change operations for guys doing life in prison.
Hahaha... back when he had nicotine-stained fingers. Most of the time my ISP would show as a geosynchronous orbit.
Offline Larch
« Reply #9 on: September 25, 2015, 11:02:40 AM »
That's interesting that only the vertical blade has the coolant feed as the kerf on that blade should leave plenty of room for the blade to pass through without generating heat on vertical cuts.  It's on the horizontal cuts where the log can bite the blade that coolant is most necessary.  I use water, windshield washer fluid, dish soap and a touch of Pin-Sol in various combinations.
My first guess on your problem with the horizontal blade not matching its prior cut is exactly what you suggested -- log movement.  It happens all the time.  I only have a single blade swing mill but I like to flatten the top of a log and then turn it so it has a nice, wide surface contacting the mill.  Then I can see what it is doing.
Nice mill you found there.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #10 on: September 25, 2015, 08:44:33 PM »
Welcome aboard Fermentor,
I suspect the log was moving as well,
for lube I use a little Pinesol and warm water.
Make darn certain the teeth are sharp and filed square to the blade body,
looks like a Lucus blade, not many teeth so they have to all work well together.
Best
Dan
Another Noob with questions
Started by rmawhinney on Timber Framing/Log construction
Last post March 01, 2013, 07:37:30 PM
by rmawhinney
General questions from a noob
Started by Gideon_70 on Sawmills and Milling
Last post May 09, 2014, 08:12:52 PM
by manoverboard
couple of noob homebrew bandwheel questions
Started by fallenoak on Sawmills and Milling
Last post December 19, 2014, 06:49:26 PM
by Swatson
Commercial Firewood Guys - noob questions
Started by FarmerDickie on Firewood and Wood Heating
Last post March 02, 2015, 06:38:46 AM
by xalexjx
