Dynamic Green Products Inc.
Author Topic: Reducing drag on Woodmizer LT25 Manual Head Lift  (Read 2234 times)
Offline AnthonyW
  • Wannabe hobby sawyer
« on: September 26, 2015, 09:27:28 PM »
In another thread I floated the idea of adding a motorized lift to my LT25. Along the way a post was made about determining the torque required to turn the handle. I found the torque required for my lift was really high. So I started checking through the sprockets and bearings to see if any were rough.  All check out fine. The only thing left I can see is the amount of friction in the mast. Does anyone know what it takes to remove the delrin pads and how to clean the mast on a manual lift Woodmizer?
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Re: Woodmizer LT25 Manual Head Lift
« Reply #1 on: September 26, 2015, 10:55:12 PM »
Hello,
I have a barrel brush on 4" grinder. Polish the area where the mast pad rides. I have only replaced one delrin pad assembly and that mill was in a fire, one was completely missing. I used a clamp to hold the mast in place then removed the assembly toward the rear of the mill. I did not remove everything I just loosen the bolts and pried the old pad out and replaced with new pads.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline AnthonyW
« Reply #2 on: September 27, 2015, 07:46:54 AM »
I had polished the mast with a wire wheel on an angle grinder and coated with a thin layer of red grease, but it still rusted quickly. Granted I have not tried to remove the pads, but I can't see how they will come out since the bolts seem too long to fit between the head and mast. Or is there something I'm missing?
Offline 47sawdust
Re: Reducing drag on Woodmizer LT25 Manual Head Lift
« Reply #3 on: September 27, 2015, 05:15:33 PM »
I'm not sure if the mast on the Lt25 is different than the Lt30/40 but my manual says to coat the mast with ATF and frequently.
Mick
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: September 27, 2015, 05:39:32 PM »
No grease because it attracts sawdust.  ATF is the recommended lube.
Offline bandmiller2
« Reply #5 on: September 27, 2015, 07:25:53 PM »
Tony, mayby the pads are adjusted too tight. Frank C.
Offline AnthonyW
« Reply #6 on: September 27, 2015, 08:04:50 PM »
There seems to be a pretty good gap (maybe too big) between the pads and the mast. Maybe I just need to remove and clean all of the above. Maybe it is just coated with sawdust and grime. Question is can I get the pads out without completely disassembling the saw head and mast.
« Reply #7 on: September 27, 2015, 08:21:04 PM »
Hello,
I would not remove the pads. Clean the grease off. Raise the saw head to the top and adjust so the loose pad is about the thickness of a credit card or two business cards away. Lower the head adjust the lower. I check the adjustment then raise the head to make it easier to work on. Lube with a light coat of ATF. Dextron III
Hope this helps.
Marty
LT25 effort to raise the head
Started by AnthonyW on Sawmills and Milling
Last post January 17, 2020, 04:21:28 PM
by AnthonyW
Sticky spot on head feed of LT25.
Last post May 28, 2020, 06:01:29 PM
by AnthonyW
Alternative for powered raising saw head on LT25
Last post September 16, 2015, 09:25:54 PM
by ljohnsaw
Older Woodmizer LT25 or new import mill
Started by ofarrell on Sawmills and Milling
Last post December 15, 2020, 03:25:48 PM
by Nebraska
