Dynamic Green Products Inc.
Author Topic: Finally pulled the trigger  (Read 7458 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Finally pulled the trigger
« Reply #60 on: October 11, 2015, 04:57:37 PM »
You can silver solder them back together...
I do it all the time. I get the most out of my blades.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline jimdad07
  • Seeking Information
« Reply #61 on: October 11, 2015, 05:20:22 PM »
I keep a stock of 45% brazing wire and flux handy.  Maybe I'll try it out, worth a shot.  I'll start taking the blade off at night, I have kids that are 7 and 8 and one more coming, hate to have them get cut around the mill.  They're not allowed near it when I'm cutting.
Hudson HFE 30 Homesteader bandmill w/28' of track
Couple tractors, a bunch of chainsaws and not enough time to use them.
Offline 21incher
« Reply #62 on: October 11, 2015, 06:04:39 PM »
I always release the blade tension and clean the guides at the end of the day on my HFE-21 as it says in the manual. Another thing I found out is to recheck the tension on a new blade after about 15 minutes of sawing. My back gets sore thinking about the size of logs you are set up to saw. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline jimdad07
« Reply #63 on: October 11, 2015, 06:24:46 PM »
By the time I get to those bigguns I'll have a few things to make it easier in place.  Going to be putting a 28" poplar log on it tonight, it's about 12' long but I'll most likely knock some of it off due to the shape of the log.  Probably have closer to 8' of good log on it.
Offline jimdad07
« Reply #64 on: October 12, 2015, 12:06:29 AM »
Offline jimdad07
« Reply #65 on: October 12, 2015, 12:16:36 AM »
Here's the results of my goofing off this weekend.  Not a huge pile but it's a start.  These boards are out of a poplar I cut four years ago.  I was about to cut it all up into firewood, what a waste that would've been.  I got 105 board feet of usable lumber out of that last log.  Learned a lot about the mill just puttering with it.  I still have six poplar logs left, they are larger than what I milled so far but I'm not worried about it.  I've been eyeballing the logs for the barn, those are going to be an adventure for sure.  No way my old Allis Chalmers 180 is going to pick them so I'm going to have to get inventive on that one.  I think I'm going to build some long ramps up to the mill for those and push them with the tractor.  It'll work out, I see I'll also have to build some cheaters to hold this logs for the first few cuts.
Offline jimdad07
« Reply #66 on: October 12, 2015, 12:58:52 AM »
This is the last log of the night, I screwed up on the post Of the picture.  You'll also find out of me by my pics I do most of my hobby stuff late at night, too darn busy during daylight hours to get my own stuff done.  Good thing I took a vacation day tomorrow.
Finally Pulled the Trigger!
Started by FayettesFinest on Chainsaws
Last post January 13, 2015, 08:34:13 PM
by FayettesFinest
Finally, Pulled the Trigger
Started by TessiersFarm on Chainsaws
Last post November 09, 2010, 07:32:06 PM
by TessiersFarm
thumbup
Started by island boy on Sawmills and Milling
Last post December 09, 2011, 07:54:14 PM
by Tim L
Started by EmannVB on Sawmills and Milling
Last post September 08, 2009, 11:29:17 AM
by EmannVB
