Alright Formites.....The Goat pulled the trigger on a Pick-Up Truck
Started by POSTON WIDEHEAD, October 06, 2015, 07:28:14 PM
MikeZ
I think the Goat bought it because of the Cat plate on the front. :)
MikeZ  Homemade  Mill
POSTON WIDEHEAD
coxy
Quote from: coxy on October 07, 2015, 08:09:14 PM
nice :) ill give you 4k for I have a 96 with over 400thousand change the oil every 10000m don't use any and get about 18-20m a gal and mine don't look anything like yours ;D
ok ill give 4k and 3bags of sweet feed  :D ;D ;D
sandhills
loghorse
had the same truck in a 96 with 5 speed.stop at a binder dealer and ask for a ph strip for radiator.they have a chart  of how much additive ,they also sell it like 7.00? .fuel filter is easy to change,cimes with gasket.
POSTON WIDEHEAD
Quote from: loghorse on October 08, 2015, 06:23:06 PM
What kind of additive? Do you know the name? Do you add it to the antifreeze and water mix?
North River Energy
starmac
It usedto be called napacool (napa brand additive) I forget what international calls it, but get the strips and check it. Many antifreees these days have it and you don't want too much in it either.
snowstorm
Quote from: starmac on October 09, 2015, 01:58:41 AM
every diesel motor needs this if it has green coolant in it
Just Me
Quote from: North River Energy on October 08, 2015, 10:48:44 PM
Here's a little light reading. Probably not the last word on the topic, but it's a start.
http://www.thedieselstop.com/contents/getitems.php3?Cavitation%20Analysis
Thanks. I never really understood the why, just to take care of it. Good read.
Larry
ST Ranch
And every diesel motor needs fuel lubrication
With todays low sulfur diesel fuel, REMEMBER to use a diesel fuel additive - In our colder climate, I have used howes treatment for both lubrication and to stop fuel gelling in the cold and to act as a winter de-icer treatment.
Friend is a cummins mechanic and he says it is mandatory to use a good one.
LT40G28 with mods,  Komatsu D37E crawler,
873 Bobcat with CWS log grapple,
JB Griffin
Add a quart off atf to every tank of diesel, keeps um slick and CLEAN.
Don't do nuthin for water or gellin though.
Howes is good stuff don't do much for water but sure will keep fuel from gellin, and a diesel will run on it straight. I'm bad to fill the fuel filter up with Howes when I change filters, works real good.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
Gearbox
DO NOT USE ATF . Atf is RED added to diesel it is still red . Red fuel is off rd and you don't need to try to explain to the DOT why you are running red fuel . YES they do still look in your fuel tanks .
Gearbox
POSTON WIDEHEAD
Was at the Ford dealership at 7:45 this morning.
2-1/2 hours. Changed oil, changed air filter.....the K&N was really dirty.
I had them put in a new OEM paper filter.
I have 1 front wheel bearing that needs replaced. Ordered.
Checked breaks, greased, new fuel filter. Some one had installed some kind of chip in this truck. That explains the little knob I can turn 3 clicks and makes the truck sound like a jet or some say the Batmobile.
Just the wheel bearing was all they found wrong. Had a spare key made.....not a bad check up.
timberlinetree
Its amazing how clean and no rust. That's shure is a nice one! Congratulations!
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Next time that we ride over to a sycamore project, we are going in your truck.
plowboyswr
Just an ole farm boy takin one day at a time.
Steve
isawlogs
 I think I now know where I should be lookin' for my next truck....  The "no rust" has me, wife has a 2012 car that has started to show signs of it.... I ain't going to begin to talk about my '99 F250S\D Power stroke..... Power rust... and will leave it at that.  A probe has gone to mars but we can't, for the life of me , build cars rust free......  :-\ >:(
   Marcel
POSTON WIDEHEAD
Quote from: WDH on October 11, 2015, 07:42:28 AM
It'll haul that BIG AMP you got and not even grunt.  :D
As long as you can tote it to that truck we will be fine.
POSTON WIDEHEAD
barbender
Like other northeners, I am super envious of how clean that truck is. It should last you for years, it's a shame that nice clean interior is gonna get all goaty smellin' ;D
POSTON WIDEHEAD
PASS_AUF
Nice find! You definitely made the right call on getting rid of that K&N! As others have said an additive is necessary as well. Diesel had 500 PPM sulfur in it when your truck was made, today it has 15 PPM sulfur in it. Recently I've switched over to Archoil in my Duramax and I've got to say I've been extremely happy. The fuel additive quiets the motor down quite a bit, increases the miles between exhaust regens, shortens the regen, and gives the truck a bit more pep. They also make an oil additive which would help your 7.3's injectors which can suffer from stiction. Archoil is spendy but the quantities used are quite small so you get your monies worth out of it IMO.
Stihl MS362
Stihl FS550
Stihl FS450
Stihl FS250
Stihl FS80
Stihl 026
Husky 555FX
John Deere Gator 825i
John Deere 4066M
