20’ Open side container kiln
Started by Geeg, October 20, 2015, 03:19:36 AM
Geeg
Anyone using a 20' Open side container as a kiln?. The reason that I like this type is that you don't need a track system to load and unload. You might be able to get 1800-1900bf per load which is a good size for me and if I need more, just build another unit?
Was thinking of spray foam the underside and 2" amvic foil foam sealed interior and sealed floor and add on Nyle 200M
Any thoughts out there?
Here is a pic of one, it opens the full width.
Retired Airbus 380 Captain. Timberking 2200,  Kioti RX6010PC,  Nyle Kiln KD250, Polaris WV850
Ljohnsaw
Wow, didn't know there was such a beast!  And it opens on the end as well.  Must be pretty pricey, though.  If I were to make a kiln, I think I'd go for that design of a container for the reasons you mentioned.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Glenn1
Since it's maximum width is 20', what is the opening of the doors.  Looks like you can only put one load of 8'-10' boards thru the doors.  Please correct me if I am wrong.  Otherwise, It looks very practical.
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
YellowHammer
Just remember that the shipping container is made of Corten or "weathering" steel, and is intentionally designed to passivate or rust in a saltwater or otherwise corrosive environment.  Many containers are only designed for a 5 year service life, which is a long time for a shipping container, but a short time for a kiln.  Not saying they won't last longer, but in the extremely corrosive environment of a kiln, it should be a consideration.  So, according to the guys at Nyle, as well as several othe posts on this forum, unless the surface is extremely well protected, it will rust out in a few years.  It was a major consideration for me, so I went with a reefer, made of stainless steel and aluminum.
Here is a reply to a topic by Don Lewis, Production/Operations Manager of Nyle
https://forestryforum.com/board/index.php/topic,6677.msg93201.html#msg93201
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Ljohnsaw
Quote from: Glenn1 on October 20, 2015, 08:55:31 PM
Look at it again.  The little panels are actually doors that the big doors are attached to.  It opens up full width.
Quote from: YellowHammer on October 20, 2015, 10:44:10 PM
Would it work to spray the interior with a good epoxy paint (like pool paint) before adding insulation and finishing the interior?
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Geeg
Hi Glenn, here is the door opening dimensions width 18'8" and height is  7'1" and another pic of a unit.
Good info YellowHammer and I may need to alter my plan a little. Where there is a will, there is a way! (old sayin)
Geeg
YellowHammer,
It was your build that really got me to thinking about building a kiln from one of these units. I had plans on building a unit from scratch but after seeing yours I decided to go this route. I just need to ironing the kinks out  ;D
Oh and BTW, I was really impressed with your build, well done!
Geeg
Geeg
Not sure if anyone has heard of this but did some research and found that RUST GRIP may be the answer, can even spray it on the wood floor to protect.  http://www.spicoatings.com/products_solutions/rust_grip
longtime lurker
Marine spec paint system... much red oxide followed by marine 2 pack epoxy... stops ships rusting.
I've been eyeing off the same style of container for the same job. :D
GeneWengert-WoodDoc
Such a paint system works only if there is a corrosive environment on only one side.  So, if you coat the interior, do not coat the exterior.  So, you will have to put the container inside a building.  The reason is that if you get a small hole in the coating when both sides are covered (like when a piece of lumber scrapes it), then moisture will get in but will be unable to get out.  It is called the envelop effect.  Once moisture gets between the two coatings, it will corrode.
longtime lurker
Quote from: GeneWengert-WoodDoc on October 21, 2015, 07:22:33 AM
Respectfully Gene, I think we're on different pages. I'm talking about a paint system similar to that used on work boats - barges, tugs, fishing boats etc. all steel boats eventually die of rust, and they all rust from the inside out because of the difficulty of accessing the interior paint system for repair once in commission. But that takes ( provided a good initial paint job is applied ) 20 years or more.
The kind of system I'm referring too would have an initial epoxy primer onto shot blasted steel, followed by 3 to 4 coats of high build epoxy to a depth of around 16 mil DFT... About 0.016"...followed by a top coat. It's not flaky stuff... It's designed to take being rubbed against wharfs etc.
I'd follow that up with Mascoat DTM or similar mastic type insulation. While I know closed cell foams are the norm with kilns, I'm also aware that closed cell foam is poorly regarded in the commercial marine sector because even though it's "closed cell" it still takes up moisture and leads to rust quicker.
Also to factor in is that being a side loaded kiln I can forklift in using slippers straight onto wood bearers so shouldn't ever really break the paint anyway. My stickers are allways on the same spacing so the bearers can be permanently fixed.
I don't mean to be argumentative, but I think that while the broad operating parameters between a kiln and a commercial vessel are different that the research into corrosion prevention in the marine sector far outweighs that put into kiln corrosion control. Maybe it won't work ( and I've never had a problem with sharing my failures) but I feel that if I can trust my life to steel sitting in salt water then I can gamble the cost of a kiln chamber. Worst comes to the worst and it fails I'll just blast it all off and try a more conventional approach.
It's those door seals (on the container sides) that I don't like.
GeneWengert-WoodDoc
The coating itself is just fine.  I do not discount that.
My concern is the accidental hole.  I believe there is likelihood that it will get a small hole.  Ships have bilge pumps.  You will have hinges, screw holes, etc. that could be an entry way.  You will have a joint between the walls and between the roof and wall.  You have a lintel for the door.  The temperature of the wall will range from below freezing to over 150F and with that range of temperature will come expansion and contraction.  Such movement is likely to open a small hole.
The hole itself is not much of an issue if the coating is only on one side.  The problem occurs when both inside and outside are coated, so when the moisture gets into the wall, it cannot get out.  Both the interior and exterior will be very humid at times.
Bob Little of the Univ of TN did an big study on various coatings for kilns.  I do not know how many coatings he used but there were a lot and his work showed this effect indeed.
So, in a kiln we typically include weep holes to drain moisture that accidentally gets in the walls.  This helps some, but deterioration is an issue even with excellent coatings.
crazy
Quote from: Geeg on October 20, 2015, 11:27:33 PM
What kind of price did you get on one of those with that side doors.  Best price I got was about $6,000.  I was wondering about a kiln made from a steel container using solar to heat it.
Geeg
Quote from: crazy on July 25, 2016, 12:17:09 AM
Hi Crazy,
I got basically the same price, quite expensive
crazy
Yes but 6k in your dollars is $4.5 in USD.
Geeg
Container finally arrived.
Picked up the nyle kiln last week. lots of work to be done.
4x4American
I didn't know they made those.  Thats pretty awesome.  How do they unload it off the truck?  And is that a company that sells them to individuals?
Boy, back in my day..
bucknwfl
Keep us posted as things progress
Buck
If it was easy everybody would be doing it
Geeg
Quote from: 4x4American on June 02, 2017, 07:28:27 PM
They used a tilt and slide bed on the truck. You can get these containers from any container company.
Got to work on the fans, sealed the screw heads with silicone. Will hang the unit with 1/2" galvanized bolts.
DDW_OR
Like the open side, and still has double doors on one end?
I have thought of using an outdoor wood boiler for the heat source.
Tree Dan
Nice looking container.
What if you straped the walls with galv. screws
Then hire a guy to spray foam the insulation in.
Then screw 3/8 plywood on the strapping for your interior walls.
I have that blue spay foam in my shop, Its spayed on the steel siding from the inside, and it works great.
Your going to have a great kiln...looking good!
Have fun.
Dan
Wood Mizer LT40HD, Kubota KX71, New Holland LS150, Case TR270
6400 John Deere/with loader,General 20" planer, Stihl 880, Stihl 361, Dolmar 460, Husqvarna 50  and a few shovels,
60" and 30" Log Rite cant hooks, 2 home built Tree Spades, Homemade log splitter
Geeg
Hi Dan My plan is to paint the interior with this rust paint http://eaglecoatings.net/content/rustgrip.htm and then line the container with amvic 2" foam insulation. The base was sprayed with 4" foam.
Got the vents installed.
Geeg
Did some more work on the kiln today. Mounted the box and got some electrical component installed, holes drilled (what a pain). Had to rewire the control box as the wires all came out the rear and it would not fit into the black box so I spent a couple of hours rerouteing them through the sides of the enclosure. Dug trench to lay the wire, didn't get a shot of that. did the masking and now ready to paint.
Geeg
Paint went on well, used a HVLP Fuji and applied two heavy coats. I also managed to get the foam on the ceiling and walls and used some strong adhesive.
Geeg
Was able to finish off the kiln over the last couple of days. I just need to have the electrical hooked up by a professional. Used the tractor to mount the fans, was a tight fit, had 1/8" clearance on each side of the fan wall. Once it was all lined up, I lifted the forks till the bolts made contact with the foam to show me were to drill the holes to mount.
Pre drill the holes with a small bit, then climbed up top to finish the job. Was quite easy and fast.
Fan wall lifted to final position and held in order to secure. Used silicone doughnuts like YellowHammer used to cut down on any vibration. Finished
sealing the bolt and nuts with silicone.
The fan wall installed.
Placed the Kiln unit into the container and hooked up the electrical connections.
There is 5 tie-down rings on the floor, I am hoping that I could use these instead of putting something heavy on top of the stack, should save some space for extra wood?
Any comments or feedback, much appreciated.
Cheers
