Author Topic: Using Setworks to make a cut??  (Read 6203 times)
Offline Bibbyman
    • Warden Sawmill
Re: Using Setworks to make a cut??
« Reply #20 on: March 25, 2002, 05:04:51 AM »
A Wood-Mizer owner just south of me mounted what looked like a high water marker on the backend of his mill.  It was a 1x6 that sticking up some 24-30" above the bed that he had painted white and added marks and dimensions on it like a big ruler so it could be read from the operator end of the mill.  He could then sight down the blade to the appropriate height mark on his water depth gage and could then judge the opening cut or log level, etc.
I was thinking of something similar:  Maybe get a magnet like one used to pick up bolts lost in the dirt or grass and mount a section of plastic pipe or fiberglass rod to it.  The "staff" could be painted (or black electrical tape) alternately with black stripe say 2" wide.  You could stick the thing on the back end of the mill rail like a temporary antenna.  Probably marks every 2" would be close enough for government work and far enough apart you wouldn't get the wrong one. ::)
Sawing since '94
Offline L. Wakefield
  • Gender: Female
« Reply #21 on: March 25, 2002, 07:24:02 AM »
   How much vibration do you get on that puppy? You might be better off to make a mount that has a temporary 'thru bolt' that holds it from jiggling or slipping. you could still take it off easy. Be a shame to have your reference mark slip. I've been burned by that on a lot of different applications. (Mike hired one guy to make him a cement floor in the garage. The guy used the ceiling as his reference for setting the grade stakes. funny about that low spot in the back..)  lw
Offline Bibbyman
    • Warden Sawmill
« Reply #22 on: March 25, 2002, 08:03:21 AM »
While I haven't developed this idea to the working model stage (and probably won't),  I'd think setting the magnet base on top of the main rail should solve any problem with it slipping down.  The magnet would have to be strong enough to keep it from sliding sideways enough so it didn't fall off from vibration or a casual bump.  That's why a fiberglass pole would be better than something that may permanently bend or brake.
Another alternative would be to develop a clamp that would slide up the guide rail and be held in place by some big thumbscrew.
With either the clamp or magnetic base,  one could move the gage forward for short logs, if'n you'd want to. ;)
Sawing since '94
Offline psychotic1
  • Earth First   We'll log the other planets later
« Reply #23 on: March 25, 2002, 07:02:56 PM »
you could probably use an old defunct cb antennae.  Seems to me they used to make some of the shorter ones out of fiberglass (or at least an outside covering of it).  Then a little paint with a two inch brush and  Vi-ola.  Bob's your uncle.
Bruce
Patience, hell.  I'm gonna kill something
Offline JoeyLowe
  • "In the German Tradition"
« Reply #24 on: March 25, 2002, 07:14:34 PM »
 :D :D :D My thoughts exactly.  I have an old fiberglass whip antenna from my younger CB radio days.  I thought about putting an orange tennis ball on the tip of it so i could see the end of the mill whenever I was backing into my driveway.  Maybe I could stripe it as well and use it as high water marker.
Joey Lowe
"Working towards perfection has to be a part of anything one does.  You've got to put yourself into it." ... Sam Maloof (chairmaker)
Head cold. Make it stop...make it go away!! Man, I turn into a baby...
Started by maestro on Health and Safety
Last post September 16, 2008, 03:56:29 PM
by Riles
Need Setworks.
Started by BBK on Wanted
Last post May 25, 2006, 05:54:30 AM
by BBK
Setworks
Started by vfauto on Sawmills and Milling
Last post April 30, 2018, 07:22:29 PM
by vfauto
setworks
Started by arnold113 on Sawmills and Milling
Last post December 02, 2013, 08:11:59 AM
by drobertson
